LineageOS 23.x Official Release for Pro1-X (QX1050)
Lineage 23.0 (Android 16) has been released for the Pro1X. I haven't yet had time to install it bbut will either tonight or tomorrow morning, if you want to let me be the guinea Pig.  😉
https://download.lineageos.org/devices/pro1x/builds
https://wiki.lineageos.org/devices/pro1x/upgrade/
https://wiki.lineageos.org/gapps/
Lineage-23.0-20251013-NIGHTLY-pro1x with October 1st security patch installed smoothly using the Lineage upgrade procedure linked in the OP. It was installed with MindtheGapps 16 and Magisk 29 installed as a zip for SU only.  all data was preserved in the upgrade. I did have to open the Magisk app to let it run an update, but root was established. All went according to plan and everything seems to be working so far.
I went ahead and did this, too.
No issues as yet.
The one hiccup was that I had recently "upgraded" the OS on my PC to Windows 11, and it didn't have a fastboot driver for an Android device, to use with installing the Magisk img file.
The phone shows as an unknown device on the PC when the phone was rebooted into fastboot mode, and when trying to update the driver manually, the default driver list does not show Android Phone.
The default driver list did show "Samsung Android Bootloader Interface" though, and I installed driver version 2.21.0.0 of that. It worked just fine for me.
I figured this was likely a more stable solution for a new W11 PC than trying to force a 2016 era driver into it. God knows my W10 PC was chock full of driver conflicts after 8 years of hard grinding.
Edited by Name_not_avail
  • 2 weeks later...
Lineage-23.0-20251103-NIGHTLY-pro1x with October 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained
A bit late this week (me, not the update) as my son is visiting from Colorado.
Lineage-23.0-20251117-NIGHTLY-pro1x with November 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained
Lol. Maybe I should just have one post and keep adding to the list, 😉
  • 2 weeks later...
I recently successfully updated my Pro1 X to LineageOS 23, starting on 2025-12-08 nightly. When I updated, I installed Magisk as a zip after flashing the image.
Today I successfully updated to 2025-12-15 nightly using OTA. After installing the OTA update, I always re-install Magisk to the inactive slot before rebooting. Is that still necessary to maintain root?
If you are updating the same major version via OTA, you should not have to reflash magisk, I never do for OTA.  Now, I only use Magisk for SU, so maybe it is different if you use different modules. I only ever flash Magisk if I am doing a non-OTA major version upgrade.
Lineage-23.0-20251222-NIGHTLY-pro1x with December 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained
Again, to be clear, when I say "root was maintained" I mean that after OTA, and without reflashinng Magisk or opening the app, I still had root on my phone.
  • 2 weeks later...
Lineage-23.0-20260105-NIGHTLY-pro1x with December 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained
Lineage-23.0-20260112-NIGHTLY-pro1x with January 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained
Lineage-23.0-20260119-NIGHTLY-pro1x with January 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained
  • 2 weeks later...
Warning! ⚠️
Tried to update to Lineage-23.2-20260209-NIGHTLY-pro1x (notice we have jumped from 23.0 to 23.2). It reboots to the bootloader menu. It won't reboot to system and if you go to Recovery, rebooting to recovery does not change the slot. However, doing a shutdown, booting the phone (you still end up in bootloader menu), going to Recovery and doing a System reboot finally boots the older Lineage 23.0  (Future reboots are fine) with 23.2 in the updater labeleed as needing installing.
This problem has been reported in the their Github for two other devices with people having tried updating recovery and sideloading not changing the situation. so I will stay on 23.0 for now and wait and see how they address the problem.  I suspect it's a model independent problem and that their knowing The Pro1x is also affected won't matter that much.
  • Thanks 3
Interesting. I just did this update on one of my Pro 1x phones, and it worked fine.
I did it the usual way that I do to avoid losing root, ie. wait for the update process to require reboot, then open Magisk, select install to vacant slot, then reboot.
All working tickety boo now, version 23.2-20260209-NIGHTLY-pro1x
Of course LTE reception remains unusably bad, but that kinda goes without saying now.
I guess I should wait for the next update for my other 1x.
