pedro4444 36 Posted April 16 Share Posted April 16 Does anyone have MS teams running on LineageOS 22.1 with root? I tried everything but it doesn't work, I read on another forum that it must be old teams and older lineage only.. did anyone succeed? 2) I tried that teams will run on a VM with Windows and will only send me notifications, but pushbullet and aiurdriod only send notifications from mobile to PC... I didn't find anything that would work from PC to mobile, does anyone have any tips? thanks Quote Link to post Share on other sites
TeZtdevice 373 Posted April 16 Share Posted April 16 I have LOS 22.1 and root. Just now, I installed Teams v.1416/1.0 and I could start the app. When you have the issues? Right after start or later? I don´t have a microsoft account to test it further. Quote Link to post Share on other sites
pedro4444 36 Posted April 16 Author Share Posted April 16 Hi yes app. teams normall install and run but when you want login to ms teams and authorizet via company portal so write me that i have root mobile.. Do you test login to ms teams? Quote Link to post Share on other sites
TeZtdevice 373 Posted April 16 Share Posted April 16 I installed the app, but can not login, because I have no account, sorry!! Quote Link to post Share on other sites
puppymang 13 Posted April 29 Share Posted April 29 (edited) using los 22.1 with qx1000 and teams for work chat. it has never complained about root using magisk with play integrity fix inject, rezygisk, and tricky store+tricky store addon as the only modules. its not even on my denylist. all i did was install it from the google play store and it just worked. i did have to get rid of ms authenticator and switch to google authenticator. no idea if they ever resolved ms authenticator catching root but i figured using google authenticator was easier anyway. Edited April 29 by puppymang Quote Link to post Share on other sites
