kashif 350 Posted September 6, 2019 Share Posted September 6, 2019 I am unable to post or my posts are not getting authorized. can someone tell me why Quote Link to post Share on other sites
vlycop 38 Posted September 6, 2019 Share Posted September 6, 2019 The back is all metal, so won’t do, see rest of the thread Thank's for merging me with the thread i didn't saw ^^ sorry for the noise Quote Link to post Share on other sites
ToniCipriani 194 Posted October 30, 2019 Share Posted October 30, 2019 On 9/6/2019 at 10:41 AM, kashif said: I am unable to post or my posts are not getting authorized. can someone tell me why I had this problem for months where I post and the posts just never show up, until now, lol. That's why three of my posts showed up earlier all at once. Quote Link to post Share on other sites
david 929 Posted October 30, 2019 Share Posted October 30, 2019 (edited) On 9/6/2019 at 9:39 AM, kashif said: I have used QI wireless adapter in the past for my samsung. it really killed the battery in one year. i have since using the magnetic adapter to connect usb cable magnetically. it does save my nokia e7. before that when i used to plug normal usb cable all the times it was breaking my e7 usb port many times and each time you give phone for repair it often get another issue or something else breaks because e7 with keyboard and design wasn't easy to replace battery, but since i am using this magnetic adapter my e7 usb port has never broken. I have thought about getting one of those ever since I saw them several months ago. Can you share which brand you are using? Did you try any other brands? And have you tested with an app that shows the charging rate to see if it is slower with the adapter than a regular cable? Edited October 30, 2019 by david Quote Link to post Share on other sites
kashif 350 Posted October 30, 2019 Share Posted October 30, 2019 8 hours ago, david said: I have thought about getting one of those ever since I saw them several months ago. Can you share which brand you are using? Did you try any other brands? And have you tested with an app that shows the charging rate to see if it is slower with the adapter than a regular cable? Well i tried couple of brands where were available here locally. those were not from Samsung though. and apart from killing battery it used to make phone pretty hot because phone has to stay on qi charger for long. yes qi charging for me was much slower then connecting cable. i was using Galaxy note 8. and not i use usb c magnetic cable where usb c adapter stays in permanently in the phone. so to protect phone usb from damage cause by inserting usb c cable in and out. is there any downside of using magnetic usb cable or keeping adapter in the phone? Quote Link to post Share on other sites
EskeRahn 5,596 Posted October 31, 2019 Share Posted October 31, 2019 I split the part on magnetic cables into a new thread here 1 Quote Link to post Share on other sites
