Brettjames22 1 Posted July 21, 2020 Share Posted July 21, 2020 My phone is becoming closer and closer to being a completely useless brick on Verizon. 1. Verizon changes to SMS has disabled all text message sending unless I am on WiFi. (Even the workaround of marking a SMS urgent to turn it into MMS does not work.) 2. Verizon will no longer allow me to call forward the Pro1 line (but will allow me to forward other lines). This is particularly important due to no cell service at home and #3 below. 3. Call over WiFi will not work without being a Verizon Branded phone. 4. Voicemail indicator will not work. I am very tempted to drop this piece of s--t phone on the railroad tracks and see what happens when a train hits it unless anyone has any fixes for the above? 1 Quote Link to post Share on other sites
tdm 2,322 Posted July 21, 2020 Share Posted July 21, 2020 11 minutes ago, Brettjames22 said: I am very tempted to drop this piece of s--t phone on the railroad tracks and see what happens when a train hits it unless anyone has any fixes for the above? The phone works perfectly fine on reasonable GSM carriers. Verizon is neither reasonable nor GSM. Your fix is to switch to another carrier. T-Mobile, AT&T, or any of their MVNOs work perfectly fine. I'm on PureTalk which is an AT&T MVNO. Paying $80/mo for four lines. Or, if you insist on being abused by Verizon, I'm sure someone would be happy to buy the phone from you. 2 1 Quote Link to post Share on other sites
Tsunero 215 Posted July 21, 2020 Share Posted July 21, 2020 Your problem is Verizon, not the phone. 4 Quote Link to post Share on other sites
Hook 3,317 Posted July 21, 2020 Share Posted July 21, 2020 Indeed, what @tdm and @Tsunero said. I ended up leaving Verizon and going to AT&T. Hope you have such an option. 2 Quote Link to post Share on other sites
internationaltraitor 84 Posted July 25, 2020 Share Posted July 25, 2020 i think there is a workaround for that on verizon on this thread second and third page Quote Link to post Share on other sites
D1ggs 141 Posted July 25, 2020 Share Posted July 25, 2020 I've been running the latest version of stock on Verizon for well over three months now without issue. Are you on the latest update? Quote Link to post Share on other sites
