rejujacob 77 Posted August 28, 2020 Share Posted August 28, 2020 Hi, does anyone else face this problem. It didn't seem to have been discussed before. Since many months, on standby mode when I press power button it automatically activates the camera (say 80% of times). I don't need this. Looks like some bug. How to solve this? Quote Link to post Share on other sites
atfrase 10 Posted August 28, 2020 Share Posted August 28, 2020 Mine is configured to launch the camera when pressing the power button twice in a row, which I find convenient to quickly pull out the phone and snap a photo. I forget where exactly that setting is, but maybe that's what's happening to you? If you don't think you're accidentally pressing it twice, maybe it's a loose connection in the button that makes one press register as two? 1 1 Quote Link to post Share on other sites
Tsunero 215 Posted August 28, 2020 Share Posted August 28, 2020 1 hour ago, atfrase said: launch the camera when pressing the power button twice in a row I can confirm this is the default setting on mine too, I have not touched anything camera related since I got the phone. 1 1 Quote Link to post Share on other sites
FlyingAntero 871 Posted August 28, 2020 Share Posted August 28, 2020 You can disable that feature If you don't like it. It can be found from Settings>System>Gestures>"Jump to camera" 2 Quote Link to post Share on other sites
rejujacob 77 Posted August 29, 2020 Author Share Posted August 29, 2020 7 hours ago, FlyingAntero said: You can disable that feature If you don't like it. It can be found from Settings>System>Gestures>"Jump to camera" This has resolved my issue. Thanks! 1 Quote Link to post Share on other sites
rejujacob 77 Posted August 29, 2020 Author Share Posted August 29, 2020 10 hours ago, atfrase said: Mine is configured to launch the camera when pressing the power button twice in a row, which I find convenient to quickly pull out the phone and snap a photo. I forget where exactly that setting is, but maybe that's what's happening to you? If you don't think you're accidentally pressing it twice, maybe it's a loose connection in the button that makes one press register as two? Yes, maybe something wrong with the button. I must have dropped the phone atleast 10 times from chairs, tables and even pockets. Luckily the display never even got scratched. And without a casing available it maybe only a matter of time.... 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 29, 2020 Share Posted August 29, 2020 9 hours ago, rejujacob said: Yes, maybe something wrong with the button. I must have dropped the phone atleast 10 times from chairs, tables and even pockets. Luckily the display never even got scratched. And without a casing available it maybe only a matter of time.... We got a long thread filled with various suggestions here I got my own with links to where I got the different ones i experimented with here. You can modify most cases for a "Huawei p20 pro" with a small pair of scissors in a few minutes. 1 Quote Link to post Share on other sites
