SchattengestaIt 563 Posted November 26, 2020 Share Posted November 26, 2020 (edited) Hello there, I've been using my Pro1 now for approximately four months and the input issues (ghost input) seems to get worse and worse. For some time I've been documenting the ghost input and it definitely shows a pattern (list below). It feels like somebody smashed my keyboard every now and then and it occurs very frequently that I have to write a word three times since ghost writing occurs repeatedly. Apart from ghost writing I have tab/alt keys pressed (tab+space is often enter/send since you get tabbed to the next button), key menu popup (í instead of i), missing keys or double space (=punctuation). Thig1s (<-- "This") can be very annoying. And since my browqe (<-- broqw (<-- f*cking browser, not browq+tab!) doesn't support AOSP, it doesn't seem to be a AOSP issue. But it seems to happen much more frequently with AOSP (sticky shift enabled) or under load which tells me that it could be a process or software issue. My questions are: Is anyone else experiencing these issues? Is there any way to prioritize the keyboard process(es)? I don't care if a game runs slower but I do care if my key input is wrong. If it isn't a software issue (considering the patterns I could imagine a hardware issue), is there any way to get a new keymat? I've never had such issues with any other keyboard phone (Droid1, Droid2, Droid4, PhotonQ) although they keyboard failed quite fast due to heavy typing. The problems occurred from day one of using the device but I can't tell if it happened only on LineageOS (I installed it immediately after receiving the phone). I am not willing to send in the device since it's my daily driver and I don't know how long they would take to repair it. I am willing to pay for parts that could solve the problem. And I'm willing to disassemble the phone to replace them.Ghost letter list: an -> asg1an auch -> auc<yh auch -> auchf1 Augen -> Augf1en beispielsweise -> beispielsh1sweise damit -> dhj1amit dann -> hd1ann das -> dj1das deutlich -> deutrlälih die -> dg1die die -> dip2ie diese -> dj1di+2ese dir -> dj1dir du -> dj1du du -> djfadu du -> hd1u du dort -> du. Rt es, die -> es,67m d fahren -> fahd1hren gleich -> glezutich halt -> hasgalt Hand -> Handjgd ich -> ichd1h ich -> ichfj1 ich -> ichfj1 ich -> ichfj1 ich -> ichjg1h ist -> isad1t jederzeit in -> jederzeit IN (random caps lock, nowhere near to the caps lock key) kann -> kasg1ann kann -> kasgann laufende -> laugf1ende leiden -> lezutiden mag -> masg1ag Mehrzahl -> Mehd1hrzahl meine -> mqewine meist -> meish1st müssen -> müsfhgsen nehmen -> neh1hmen nicht -> nichfj1t nicht -> nichfj1t (the attempt of rewriting the word) nicht -> nichjg1ht nicht -> nichjght nicht -> nicycht offen -> offhgfen rücksichtslos -> rücksicfh1tslos schließlich -> sh1schließlich schön -> sh1schön sehr -> sh1sehr shift -> shifgh1t sich -> sic<yvh sicher -> sicvbher sie -> s1aiete sind -> as1ind skeptisch -> sad1ke... so -> sd1so sodass -> sodassad1 sogar -> sogf1ar umsteigen -> umsfh1teigen vorsichtig -> vorsichd1htig wichtig -> wichd1htig Zeit -> Zei+2t 1a[ ]et 67m a[ ]1 ad1 x3 d1h x5 dg1 f1 x3 f1j fj1 x4 fh1 x2 fhg g[ ]1 gh1 h[ ]1 x2 h1 x3 hj1 hgf j1d x3 j1d[ ]+2 jg1 jg1h jgh jgd jfad p2i sd1 sg1a sga sh1 x4 sg1 sg vb r[ ]äl q[ ]w zut <yv <y yc zut Edited November 26, 2020 by SchattengestaIt 1 1 Quote Link to post Share on other sites
jamescarruthers 37 Posted November 26, 2020 Share Posted November 26, 2020 Yeah sometimes the Pro1 sucks big time when it does this. I loathed it at times and now accept that its faults just lie with the awfulness of Android rather than the phone's design. I can tell you that my experience, which was very similar to yours, got much better with the installation on Lineage OS 17. Have you done this upgrade yet? 1 Quote Link to post Share on other sites
SchattengestaIt 563 Posted November 26, 2020 Author Share Posted November 26, 2020 45 minutes ago, jamescarruthers said: I can tell you that my experience, which was very similar to yours, got much better with the installation on Lineage OS 17. Have you done this upgrade yet? Not yet (I'm on the latest LOS 16.x). But I could imagine that it's because of a fresh install? I'll see if I find the time to try it on the weekend. Is there a way to disable AOSP for the keyboard in order to remove any software activities while typing? (this way I'd hope to lower the frequency of the issues) Quote Link to post Share on other sites
Slion 1,201 Posted November 27, 2020 Share Posted November 27, 2020 Sounds like an electrical issue with your keyboard. I had something similar. They replaced my phone. 1 Quote Link to post Share on other sites
SchattengestaIt 563 Posted November 27, 2020 Author Share Posted November 27, 2020 7 hours ago, Slion said: Sounds like an electrical issue with your keyboard. I had something similar. They replaced my phone. How long did it take for them to replace it? As much as I understand many people haven't even received their phone yet so I don't expect them to hurry for replacement phones. I'd feel much more comfortable just opening it myself and maybe change some parts. Also it's strange that it mostly happens when the phone is under load, shouldn't it be a software issue then? 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 27, 2020 Share Posted November 27, 2020 1 hour ago, SchattengestaIt said: How long did it take for them to replace it? 10 weeks. 1 hour ago, SchattengestaIt said: feel much more comfortable just opening it myself and maybe change some parts. Same here. 1 hour ago, SchattengestaIt said: mostly happens when the phone is under load Well if it's a software issue other users should be able to reproduce it. If you have instructions I can give it a go. Quote Link to post Share on other sites
jamescarruthers 37 Posted November 27, 2020 Share Posted November 27, 2020 (edited) I really thoughht mine had a physical fault too as it too used to insert numbers into words or move the cursor around the screen-- it was often unusable. I thought one key was influencing another electronically but now on LOS 17 I would say it is 99.9% fixed with respect to the keyboard. Android is completely new to me and even I managed to do a non-destructive update to my Pro1 and keep all my data! Of course you could still have a physically damaged keyboard causing all of your issues but I would be interested to see if the update to LOS 17 helps your typing issues (I have no idea what AOSP is by the way, so can't answer that one!). Edited November 27, 2020 by jamescarruthers 1 1 Quote Link to post Share on other sites
SchattengestaIt 563 Posted November 27, 2020 Author Share Posted November 27, 2020 @Slion There is no simple way to reproduce it. I've seen those problems happen in huge loads but that's not guaranteed either. What I do very often is to stop any process ii the back which helps a lot. That leads me to the thought that we are talking about a software problem. But you have to stop those processes manually or you have to restart them every time (when switching apps) if you disable background processfhgses (<--processes) in the developer menu. @jamescarruthers That really gives me hope... I'll definitely try updating it over the weekend. AOSP is the software that 'helps' the keyboard to output further letters than the keyboard would do itself. For example sticky shift wouldn't be possible in this kind of keyboard and many shortcuts are custom too. However, I'm already used to using both shift keys so I don't need AOSP anymore. But I'll try LOS17 first! Quote Link to post Share on other sites
Slion 1,201 Posted November 27, 2020 Share Posted November 27, 2020 Seeing as I don't do bitcoins mining on mine it's fair to say I don't have any power hungry background process running 😁 Early on, back in January or February, I had that issue where Gmail sync with ActiveSync was acting up, drain the battery and make the phone run hot but that's been fixed for months now. Is there an app I could run to simulate heavy load? How comes you are running power hungry background processes? Quote Link to post Share on other sites
enPfzr4v 239 Posted November 27, 2020 Share Posted November 27, 2020 Happens to me too. 2 Quote Link to post Share on other sites
SchattengestaIt 563 Posted November 28, 2020 Author Share Posted November 28, 2020 18 hours ago, Slion said: Is there an app I could run to simulate heavy load? How comes you are running power hungry background processes? That's the thing. We aren't talking about bitcoin mining or that kind of power hungry processes, but of an open browser, Whatsapp or a 2D game I often play. Maybe it's a RAM issue instead. When I kill every other app (app drawer), the keyboard usually works fine. I noticed it quite clearly when I start the 2D game and switch apps while it's loading. It seems to save the current (loading) state in the background and this takes more resources (CPU or RAM) than the finalized loaded game. I've also observed it with copying 1GB of files from one part of the phone to the next one, but whenever I wanted to reproduce it, I couldn't... For this message for example I killed every other app that was opened and had no issues at all. Of course, it happens more often with AOSP keyboard enabled (it's not availafable in Kiwi browser) but I would still have some stuttering from the keyboard like missing keys or SOME ghost input. But without background processes it is fine. Quote Link to post Share on other sites
SchattengestaIt 563 Posted February 13, 2021 Author Share Posted February 13, 2021 (edited) I just want to inform you guys, that over two months later I actually updated my OS to LOS 17.1 with Android 10. I was fearing the update since last time I failed miserably and lost all my data. But the fear was unfounded, I didn't have to get confused with A/B slots and it was fast and easy. Now it's my first six hours with the new OS but I haven't had ANY issues so far. It really seems to be fixed now and the system is way more responsive as well (it's actually fascinating how fast it is). Time will tell if it will get slower over time but what I can definitely tell is that this is no hardware issue. Thanks to tdm for working hard on the LineageOS! Edit: indeed it's solved for 99%. Rarely I get some issue like I had before, maybe it's some Cache that gets littered up and cleared after an update. Edited February 22, 2021 by SchattengestaIt 1 1 Quote Link to post Share on other sites
VaZso 1,999 Posted February 13, 2021 Share Posted February 13, 2021 3 hours ago, SchattengestaIt said: Now it's my first six hours with the new OS but I haven't had ANY issues so far. It really seems to be fixed now and the system is way more responsive as well (it's actually fascinating how fast it is). Time will tell if it will get slower over time but what I can definitely tell is that this is no hardware issue. Could you please check if camera also works well? So if there are no focusing problems some members complained about. I don't really know if that was LineageOS related or hardware issue for them. Also, it would be good to know if it is also applies to GCAM mods (if you may use it anyway). Quote Link to post Share on other sites
DieBruine 397 Posted February 13, 2021 Share Posted February 13, 2021 There were 3 people with LoS 16 in my household who experienced ghosting. So yes, it was most certainly LoS 16. I jumped straight to LoS 18.1, rock steady. 1 Quote Link to post Share on other sites
SchattengestaIt 563 Posted February 14, 2021 Author Share Posted February 14, 2021 12 hours ago, VaZso said: Could you please check if camera also works well? So if there are no focusing problems some members complained about. I don't really know if that was LineageOS related or hardware issue for them. Also, it would be good to know if it is also applies to GCAM mods (if you may use it anyway). Yes, I had indeed many problems with LOS 16 and focusing problems, especially in low light scenarios. I installed Open Camera, went to the advanced settings (I don't remember where you set it up) and used the manual focus for low light scenarios. I thought the fault was the hardware. Autofocus is still slow in low light, but definitely improved. But in very low light when it can't focus I'll still use the manual focus. 2 Quote Link to post Share on other sites
