PokeParadox 62 Posted March 12, 2021 Share Posted March 12, 2021 (edited) Hello all! First the good news, my Pro1 has been repaired and sent back! Unfortunately it needed a new board so I basically lost a few photos which I saved to the internal memory instead of SD.. :( Anyway I have some quirks - I am now on stock Android but I'm not sure if I'm on the latest version. There's a few things that don't seem right: Battery seems to be draining a lot quicker than I remember. I keep getting a "Wireless Update" notification popup fairly frequently and disappear. I'm not able to perform an OTA update even if I go to the menu - it's like it's pointing to the wrong address... It's got a Snapdragon Camera which I don't remember being installed last time. So does that seem right? Is there a stock image I can manually install or should I just slap the latest lineage on there again? Edited March 12, 2021 by PokeParadox Quote Link to post Share on other sites
_DW_ 628 Posted March 12, 2021 Share Posted March 12, 2021 Sounds like the normal stock image to me but I've not used it in a long time. Check what version it says in the "About Phone" screen in options (think its called that lol!) Quote Link to post Share on other sites
ToniCipriani 194 Posted April 26, 2021 Share Posted April 26, 2021 On 3/12/2021 at 5:52 AM, PokeParadox said: I keep getting a "Wireless Update" notification popup fairly frequently and disappear. This always has been since day 1 of the Pro 1, the built-in ADUPS checks for updates whenever you switch wireless networks (mobile vs Wi-Fi), plug and unplug the charger, etc. Many cases will trigger a wireless update check. Quote Link to post Share on other sites
EskeRahn 5,596 Posted April 26, 2021 Share Posted April 26, 2021 Unless you are very much in a hurry to immediately get any new updates on release (last was August 2020), then I would suggest to disable the two System Apps both called "Wireless Update", and when you get information on a new update you want to apply, you can just re-enable them. it iscom.adups.fota and com.adups.privacypolicy Do both a disable AND a stop (!) as described here ADB shell pm disable-user com.adups.fota ADB shell am force-stop com.adups.fota ADB shell pm disable-user com.adups.privacypolicy ADB shell am force-stop com.adups.privacypolicy (You can stop them from the phones apps list (show system apps), but you would need to remember to stop them after every restart) 1 Quote Link to post Share on other sites
