mosen 204 Posted August 19, 2022 Share Posted August 19, 2022 5 minutes ago, steeb said: @mosen Oddly, this did fix the sensors, but not attestation. I feel quite certain it was working when I backed up the image, but unfortunately I dont have time to try re-flashing again this afternoon. Check here for a method to search for the keys in any partition or image: Quote Link to post Share on other sites
mosen 204 Posted August 19, 2022 Share Posted August 19, 2022 @Ivaylo HubanovAnother idea. Since your device boots into the F(x) logo and gets stuck there, it is in a state already where OTA changes can influence the boot process. Can you try sideloading an OTA update via adb in the recovery mode? Download a beta OTA from here (not GMS certified) Please note the beta disclaimer. Set device into recovery mode by holding vol down button on reboot. At the dead droid, push pwr btn and vol buttons to activate the menu. Choose sideload via adb. Push the downloaded .zip file using: adb sideload merged-qssi_bengal-ota.zip And reboot. 1 Quote Link to post Share on other sites
EskeRahn 5,593 Posted August 19, 2022 Share Posted August 19, 2022 1 hour ago, mosen said: @Ivaylo HubanovAnother idea. Since your device boots into the F(x) logo and gets stuck there, it is in a state already where OTA changes can influence the boot process. Can you try sideloading an OTA update via adb in the recovery mode? Download a beta OTA from here (not GMS certified) Please note the beta disclaimer. Set device into recovery mode by holding vol down button on reboot. At the dead droid, push pwr btn and vol buttons to activate the menu. Choose sideload via adb. Push the downloaded .zip file using: adb sideload merged-qssi_bengal-ota.zip And reboot. Unfortunately the default bootloader does not seem to have a recovery image in it - at the least the 'early unit' I have does not, nor does the retail Pro1 (no X) 1 Quote Link to post Share on other sites
mosen 204 Posted August 19, 2022 Share Posted August 19, 2022 Wow, you seem to have a very early version then!? On the testing device i had delivered with 2.0.8, the recovery is reached by holding any volume button during the first seconds of boot. I can not reliably reach fastboot with the volume method, neither on the retail Pro¹-X, not on the testing device. But i always end up at the dead droid recovery start page. To activate the menu of recovery, one has to then press power button and volume up. The menu appears over the dead droid and there we have the option to boot to bootloader and the adb sideload among others. Quote Link to post Share on other sites
Ivaylo Hubanov 13 Posted August 20, 2022 Share Posted August 20, 2022 8 hours ago, mosen said: @Ivaylo HubanovAnother idea. Since your device boots into the F(x) logo and gets stuck there, it is in a state already where OTA changes can influence the boot process. Can you try sideloading an OTA update via adb in the recovery mode? Download a beta OTA from here (not GMS certified) Please note the beta disclaimer. Set device into recovery mode by holding vol down button on reboot. At the dead droid, push pwr btn and vol buttons to activate the menu. Choose sideload via adb. Push the downloaded .zip file using: adb sideload merged-qssi_bengal-ota.zip And reboot. This is what I get: ``` # adb sideload merged-qssi_bengal-ota.zip adb: sideload connection failed: device unauthorized This adb server's $ADB_VENDOR_KEYS is not se Try 'adb kill-server' if that seems wrong Otherwise check for a confirmation dialog on your device adb: trying pre-KitKat sideload method.. adb: pre-KitKat sideload connection failed: device unauthorized This adb server's $ADB_VENDOR_KEYS is not se Try 'adb kill-server' if that seems wrong Otherwise check for a confirmation dialog on your device. Quote Link to post Share on other sites
Ivaylo Hubanov 13 Posted August 20, 2022 Share Posted August 20, 2022 One thing to note here, lsusb says it's in fastboot mode and display shows that under maintenance android with "no command" text... This is when I choose "Recovery mode" from menu Quote Link to post Share on other sites
EskeRahn 5,593 Posted August 20, 2022 Share Posted August 20, 2022 6 hours ago, mosen said: Wow, you seem to have a very early version then!? On the testing device i had delivered with 2.0.8, the recovery is reached by holding any volume button during the first seconds of boot. I can not reliably reach fastboot with the volume method, neither on the retail Pro¹-X, not on the testing device. But i always end up at the dead droid recovery start page. To activate the menu of recovery, one has to then press power button and volume up. The menu appears over the dead droid and there we have the option to boot to bootloader and the adb sideload among others. no no the bootloader is there, but selecting recovery within it fails. I see exactly the same on my retail Pro1 (no X), that has only had OTA updates. 1 Quote Link to post Share on other sites
mosen 204 Posted August 20, 2022 Share Posted August 20, 2022 @Ivaylo Hubanov That is an indicator for the sideload mode not being started in recovery. There should be an option in the recovery menu that says along the lines "sideload using/via adb". If you select that, the screen will change to black and only show some white text saying something like push .zip now and showing the command how to do so. (the adb sideload image.file one) When you start sideloading from your computer using this command, it will show progress on the device screen. Quote Link to post Share on other sites
mosen 204 Posted August 20, 2022 Share Posted August 20, 2022 @EskeRahnbut do you see that dead droid logo at any point when doing different volume buttons on reboot? When seeing that, its vol up and pwr to activate the actual recovery menu. Ok, but since you said you sideloaded OTAs you sure have been in there 😛 Just not fully understanding what you mean. Since i figure from what you say you can only reach fastboot bootloader menu and flash the OTA via fastboot? Btw, why are you not in the TG beta channel? 😅 Its ment for both, pre production units and retail units just to test the latest OTAs. Quote Link to post Share on other sites
Ivaylo Hubanov 13 Posted August 20, 2022 Share Posted August 20, 2022 3 hours ago, mosen said: @Ivaylo Hubanov That is an indicator for the sideload mode not being started in recovery. There should be an option in the recovery menu that says along the lines "sideload using/via adb". If you select that, the screen will change to black and only show some white text saying something like push .zip now and showing the command how to do so. (the adb sideload image.file one) When you start sideloading from your computer using this command, it will show progress on the device screen. @mosenok, so while stuck in the boot logo I was trying to restart the phone, but dropped the button before it actually restart and it seems something triggered in the background and phone booted android properly!!! 🎆🎉🙈 So now I'm on the backup step then going back to try and flash Ubuntu Touch 🥵 2 1 Quote Link to post Share on other sites
EskeRahn 5,593 Posted August 20, 2022 Share Posted August 20, 2022 12 hours ago, mosen said: @EskeRahnbut do you see that dead droid logo at any point when doing different volume buttons on reboot? When seeing that, its vol up and pwr to activate the actual recovery menu. Ok, but since you said you sideloaded OTAs you sure have been in there 😛 Just not fully understanding what you mean. Since i figure from what you say you can only reach fastboot bootloader menu and flash the OTA via fastboot? Btw, why are you not in the TG beta channel? 😅 Its ment for both, pre production units and retail units just to test the latest OTAs. The bootloader menu works fine (whether launched by buttons or adb reboot bootloader) , but when I select the Recovery option, I see the F logo, and then a dead android. Quote Link to post Share on other sites
EskeRahn 5,593 Posted August 20, 2022 Share Posted August 20, 2022 12 hours ago, mosen said: @EskeRahnbut do you see that dead droid logo at any point when doing different volume buttons on reboot? When seeing that, its vol up and pwr to activate the actual recovery menu. Ok, but since you said you sideloaded OTAs you sure have been in there 😛 Just not fully understanding what you mean. Since i figure from what you say you can only reach fastboot bootloader menu and flash the OTA via fastboot? Btw, why are you not in the TG beta channel? 😅 Its ment for both, pre production units and retail units just to test the latest OTAs. No, OTA=Over-The-Air, so only did official update from within adroid (adup´s app on the retail Pro1). If a used the word "sideload" for that, it was a slip of the tongue. On that unit the only thing fastboot I have done wasfastboot oem off-mode-charge 1 Unless my memory completely fails me. ( alsoI got a preproduction Pro1, and a "Final sample" Pro1, that has been flashed with boht sailfish, lineage and aicp in various versions, and can boot into recovery. Holding VolUp+Pwr at the dead icen after attemptied recovery, Works the same if I press shortly or hold to various states of the boot. The Pro1 and the Pro1X acts different here: When holding both do boot-loop until released. The Pro1X then boots into Android, where the Pro1 end in the dead android screen, where only a long (10s?) power-press can bring it back, booting normally. Quote Link to post Share on other sites
steeb 28 Posted August 21, 2022 Author Share Posted August 21, 2022 I wrote a quick and dirty guide on re-flashing the stock ROM for macOS and Linux. It got a little buried in another thread so I thought I'd post it here for posterity. flashing_pro1-x.pdf 3 Quote Link to post Share on other sites
Ivaylo Hubanov 13 Posted August 22, 2022 Share Posted August 22, 2022 7 hours ago, steeb said: I wrote a quick and dirty guide on re-flashing the stock ROM for macOS and Linux. It got a little buried in another thread so I thought I'd post it here for posterity. flashing_pro1-x.pdf 58.51 kB · 3 downloads Nice work just one clarification you might want to update the guide... To me this command doesn't execute: edl --loader=prog_firehose_ddr.elf reset reboot So I use "edl --loader=prog_firehose_ddr.elf reset" instead... I think the reboot at the end is not necessary and I'm not sure if it properly executes on any device at all 🤔 1 Quote Link to post Share on other sites
DillonM 10 Posted October 24, 2022 Share Posted October 24, 2022 (edited) A somewhat novice question here: after running the initial 'sudo edl ....' command, the output stops at "main - device detected :)" . How long should this process take? Is there a way to monitor before I have to hard reboot my pro1x? I can still see the device in lsusb so I am just not sure. And I see an 'edl' process running in 'ps' or 'top' Just nervous about flashing a different OS without backing up my persist partition and this seems to be my roadblock on this process. Edited October 24, 2022 by DillonM Quote Link to post Share on other sites
DillonM 10 Posted October 27, 2022 Share Posted October 27, 2022 On 10/24/2022 at 11:33 AM, DillonM said: A somewhat novice question here: after running the initial 'sudo edl ....' command, the output stops at "main - device detected :)" . How long should this process take? Is there a way to monitor before I have to hard reboot my pro1x? I can still see the device in lsusb so I am just not sure. And I see an 'edl' process running in 'ps' or 'top' Just nervous about flashing a different OS without backing up my persist partition and this seems to be my roadblock on this process. so i think my initial problem was that the 'adb reboot edl' command was not taking the device into a 'full' edl mode. when I used the key combo to enter, my command advanced past the 'device detected' phase, only to stop again at 'trying to read the first storage sector'. How long should that process take? 1 Quote Link to post Share on other sites
