claude0001 1,424 Posted November 3, 2022 Share Posted November 3, 2022 (edited) @IMD seems to be absolutely right. The speaker failures occur only when /sys/class/power_supply/battery/voltage_now exceeds approx. 4100000 µV. This explains naturally why the phenomenon is more apparent when connected to a charger. The question remains whether F(x)tec will indeed be able to fix this by a firmware update, or not ... 😞 Edited November 3, 2022 by claude0001 1 Quote Link to post Share on other sites
IMD 3 Posted November 4, 2022 Share Posted November 4, 2022 (edited) I doubt of something like over-voltage protection in speaker driver LSI. By measuring of oscilloscope, I found it has a charge-pomp booster to make 2x vbat. Output voltage may down when louder volume or battery discharged. (But why only right speaker?) (Parameters of the protection were not initialized only on right-speaker driver?) I want schematics... Edited November 4, 2022 by IMD 2 Quote Link to post Share on other sites
claude0001 1,424 Posted November 4, 2022 Share Posted November 4, 2022 3 hours ago, IMD said: I want schematics... Before we tear our phones apart any further it would be good to know whether F(x)tec are indeed aware of this problem and are planning a fix via firmware update. The (initial) October update can be interpreted in that way, but the wording is quite vague ... 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 4, 2022 Share Posted November 4, 2022 25 minutes ago, claude0001 said: Before we tear our phones apart any further it would be good to know whether F(x)tec are indeed aware of this problem and are planning a fix via firmware update. The (initial) October update can be interpreted in that way, but the wording is quite vague ... @Casey can you help us with info here? 1 Quote Link to post Share on other sites
Casey 321 Posted November 4, 2022 Share Posted November 4, 2022 1 hour ago, claude0001 said: Before we tear our phones apart any further it would be good to know whether F(x)tec are indeed aware of this problem and are planning a fix via firmware update. The (initial) October update can be interpreted in that way, but the wording is quite vague ... I've relayed this issue back to our dev team and they will look into it. I'll update here when there's progress. Thanks for bringing this up. 2 3 Quote Link to post Share on other sites
brunoais 335 Posted November 4, 2022 Share Posted November 4, 2022 Tried to reproduce and I still cannot. Battery at 80% (4.108V), both when charging and not charging. Volume ranging from 10% to 60% (in intervals of 10) and for min 1 min in each. I'm using OS V. 2.1.5 non-GMS. 1 Quote Link to post Share on other sites
claude0001 1,424 Posted November 7, 2022 Share Posted November 7, 2022 On 11/4/2022 at 10:56 PM, brunoais said: I'm using OS V. 2.1.5 non-GMS. 2.1.5-GMS-less also here. And the problem is definitely there. So whatever fix they prepare, it's not in that ROM. 2 Quote Link to post Share on other sites
claude0001 1,424 Posted November 14, 2022 Share Posted November 14, 2022 (edited) On 11/3/2022 at 8:01 AM, IMD said: I think it is not related with temp or charging state. So I started playing around with my Pro1-X again. After the device being shelved for ~1.5 weeks, the battery is now at 61% and /sys/class/power_supply/battery/voltage_now never exceeds 3870000 µV. In this state, I cannot reproduce the speaker issue! So, maybe, it indeed occurs only on brand-new devices (and batteries) where the voltage exceeds 4.1 V significantly after charge ... ? This might explain why the problem goes away after some time of using the Pro1-X. edit: Re-charging the Pro1-X now, to check whether the problem comes back with battery full. Edited November 15, 2022 by claude0001 3 Quote Link to post Share on other sites
claude0001 1,424 Posted November 16, 2022 Share Posted November 16, 2022 So, the speaker issue is definitely improving. With the battery fully charged (and /sys/class/power_supply/battery/voltage_now >~ 4100000 µV), the tapping sound reappeared sometimes while changing the volume of a playing youtube video, though not to the extend to make the video unwatchable. Now, with the battery charge at 72% (/sys/class/power_supply/battery/voltage_now ~ 4000000 µV), I'm back to "cannot reproduce" ... I am now quite confident that this problem will quickly go away with ageing of the battery, as others have observed, and I regret opening the Pro1-X for this (breaking a grand total of three of the tiny grounding springs surrounding the board in the process - do not insert your spudger to deep while opening the bottom shell!). 4 Quote Link to post Share on other sites
