brunoais 335 Posted August 17, 2022 Share Posted August 17, 2022 (edited) In this topic, which I'll update every time I find something useful, I will share configurations that are safe and configurations that are risky that you can try yourself on your own PRO¹-X. Everything shown here requires system permissions. The only way for you to get system permissions is by rooting the phone. There's no way around. That's how Android works. Because these are settings using sysfs. By design, they are temporary. Rebooting your phone will reset them to their default values. If you break something and you don't know how or what, one way that usually solves it is shutting down and then booting normally. Reading & writing: The most common ways to read and write to sysfs is by using cat and echo with redirections. You can also use tee for writing, in replacement of echo. Examples: Reading: cat /sys/path/to/attr echo Writing: echo 1 > /sys/path/to/attr tee Writing: <<< "1" tee /sys/path/to/attr The <<< just tells the shell to input that value to the command (tee, in this case). Safe These settings are safe for you to try out. Even if you use large values or out of bounds values, it shouldn't brick or break your phone in any way. Do be careful that next to safe elements to write to, there are unsafe elements. DO NOT TOUCH THOSE IF YOU DON'T KNOW WHAT YOU ARE DOING! With that out of the way, here's the information for sharing: Suspend power input (also, battery charging) You can temporarily suspend battery charging (good use of this feature improves battery life). This suspends power input (and battery charging, by consequence): echo 1 > /sys/class/power_supply/battery/input_suspend This restores power input (its default): echo 0 > /sys/class/power_supply/battery/input_suspend Manually control keyboard light You can manually control the keyboard backlight. Do note that system programs can also control the keyboard backlight. So, they can change this value themselves. Turn on the keyboard backlight: echo 1 > /sys/class/leds/button-backlight/brightness Turn off keyboard backlight: echo 0 > /sys/class/leds/button-backlight/brightness Manually force keyboard backlight to stay off You can manually force the keyboard backlight to stay off. This setting overrides the previous entry of this manual Turn off keyboard backlight and don't allow back on again (reminder: Only lasts until reboot): echo 0 > /sys/class/leds/button-backlight/max_brightness Allow keyboard backlight on again (doesn't necessarily turn brightness on): echo 255 > /sys/class/leds/button-backlight/max_brightness Note: I didn't find a way to force keyboard backlight to stay on. UNSafe These settings are NOT safe for you to try out. Do it at your own risk and don't come crying if it breaks something. If an unsafe option is actually deemed safe, it will be moved to the list above. However, until then, only READ (using cat command) and never write to them. DO NOT TOUCH THESE IF YOU DON'T KNOW WHAT YOU ARE DOING! With that out of the way, here's the information for sharing: Pretend you have battery capacity you don't You can manually pretend to have a different battery capacity than the real one (this also means that any rooted program/app can do the same, be VERY careful which programs/apps you give root access!!!) Unsafe: From what appears like, this value, once set, doesn't update with the status of the battery. This is quite useful to test if automations related to the battery status are working well without having to wait for the battery to actually deppel or recharge. Pretend your phone has 90% capacity left echo 90 > /sys/class/power_supply/battery/capacity Pretend your phone has 10% capacity left: echo 10 > /sys/class/power_supply/battery/capacity Edited August 18, 2022 by brunoais 2 3 Quote Link to post Share on other sites
brunoais 335 Posted August 17, 2022 Author Share Posted August 17, 2022 Keeping this post here just in case Quote Link to post Share on other sites
claude0001 1,424 Posted August 17, 2022 Share Posted August 17, 2022 Awesome findings, thanks. I did not test the (unsafe) battery capacity-faking bit (yet). 😉 The battery charging control works the same on the original (835) Pro1. The keyboard backlight control also works similarly, except that, on the Pro1, the respective sysfs files are located under /sys/class/leds/keyboard-backlight/ rather than "/sys/class/leds/button-backlight/". 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 17, 2022 Share Posted August 17, 2022 I wonder if that suspended battery charging could be related to the issue behind this: 1 Quote Link to post Share on other sites
brunoais 335 Posted August 17, 2022 Author Share Posted August 17, 2022 I don't know but the sysfs I currently show there stops energy input. That means the phone starts working powered by the battery, even though it's connected to the cable. What you point out, is the phone just not charging but still taking power to sustain itself (what I'd rather be turning on there). It can have a relation but they are different in that detail I pointed out Quote Link to post Share on other sites
claude0001 1,424 Posted August 17, 2022 Share Posted August 17, 2022 6 minutes ago, brunoais said: I don't know but the sysfs I currently show there stops energy input. That means the phone starts working powered by the battery, even though it's connected to the cable. Confirmed for the 835 Pro1. Toggling that flag causes the Pro1 to ignore the connected power cable and drain its battery instead. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 18, 2022 Share Posted August 18, 2022 8 hours ago, brunoais said: I don't know but the sysfs I currently show there stops energy input. That means the phone starts working powered by the battery, even though it's connected to the cable. What you point out, is the phone just not charging but still taking power to sustain itself (what I'd rather be turning on there). It can have a relation but they are different in that detail I pointed out Ah I see, so not only suspending battery charging, but suspending power input completely. So the discriptive wording ought to be adjusted slightly. Maybe something like suspending power input (and thus battery charging) Quote Link to post Share on other sites
brunoais 335 Posted August 18, 2022 Author Share Posted August 18, 2022 1 hour ago, EskeRahn said: Ah I see, so not only suspending battery charging, but suspending power input completely. So the discriptive wording ought to be adjusted slightly. Maybe something like suspending power input (and thus battery charging) Fixed 1 Quote Link to post Share on other sites
