Rob. S. 1,667 Posted December 7, 2022 Share Posted December 7, 2022 Does the notification light work on your Pro1X with all apps? I'm struggling with some, most notably Signal, that doesn't turn on the LED for incoming messages no matter what I do. Quote Link to post Share on other sites
--- 129 Posted December 7, 2022 Share Posted December 7, 2022 (edited) @Rob. S. I don't get notifications lights for anything, but the LED does light up when I'm charging. This isn't intentional, and I still get sounds and on screen notifications for a lot of things, so I haven't pursued it too much. 🤔 I've just had a quick look to see if I've disabled notifications with some global setting, dnd, etc, but I can't see anything. I'll have a play, in particular Signal, and see if I can get it working on my PrawnX. Which Signal app are you using? Edited December 7, 2022 by MonCon 1 Quote Link to post Share on other sites
PoongZY 15 Posted December 8, 2022 Share Posted December 8, 2022 didn't notice and lights except when charging. it needs to turn on manually? Quote Link to post Share on other sites
Rob. S. 1,667 Posted December 8, 2022 Author Share Posted December 8, 2022 18 hours ago, MonCon said: I don't get notifications lights for anything, but the LED does light up when I'm charging You're right, it seems like there's no notification light at all except for charging... 18 hours ago, MonCon said: Which Signal app are you using? 6.3.6 from Play Store, currently. 1 Quote Link to post Share on other sites
--- 129 Posted December 8, 2022 Share Posted December 8, 2022 (edited) @Rob. S. fyi: https://community.fxtec.com/topic/2677-how-to-control-notification-light/ Old thread, but maybe still relevant. Edited December 8, 2022 by MonCon Quote Link to post Share on other sites
Rob. S. 1,667 Posted December 8, 2022 Author Share Posted December 8, 2022 Looks like Pro1 stock Android had similar problems, even though, at least at times, some people saw other notifications than just when charging... I never did use the Pro1 with stock, so I never made that experience... Quote Link to post Share on other sites
--- 129 Posted December 8, 2022 Share Posted December 8, 2022 1 hour ago, Rob. S. said: Looks like Pro1 stock Android had similar problems, even though, at least at times, some people saw other notifications than just when charging... I never did use the Pro1 with stock, so I never made that experience... After a bit of recon, bizarrely it seems that a lot of modern slabphones don't have notification lights!! I wonder if maybe the functionality in Android has drifted away as the big manufacturers can't even be bothered to give you an LED in your new $XXXXX iphone or samsung. No wonder a keyboard is out of the question from those pirates (no offence to any real actual pirates who may be reading this). There are a couple of workarounds out there, including setting up your camera flash to scream at you and everybody else in sight, if you remembered to put your phone on the table screen-down camera-up in the first place then 'discreetly' turn it over to see the message. Or there's the option of faking an LED in the screen by lighting up just a few pixels where the LED should be. If you've got a case you would need to drill another hole in it where it lights up, and I think this only works for AMOLED if you value your battery life, which is OK for Prawnsters, but not for some others. Both options seem like 'solutions to a problem that doesn't exist'. If you don't have this Android issue on your Pro1 running LOS then hopefully soon (fingers crossed) that's the solution for your Pro1X. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 9, 2022 Share Posted December 9, 2022 12 hours ago, Rob. S. said: Looks like Pro1 stock Android had similar problems Notifications for SMS from Textra works correctly on Pro1, but NOT on Pro1X it seems. Same goes for e.g. "Light Manager 2 - LED settings" Some apps (e.g. "led colour tester" by Akshit Gupyta - note that there are more than one with that name, not all working!) and mail apps worked on earlier Pro1 stock android -though not latest- and do (still) work on both LineageOS and AICP (Pro1). 2 Quote Link to post Share on other sites
brunoais 335 Posted December 13, 2022 Share Posted December 13, 2022 I don't use signal and don't want to install it but it works with all other apps I tried. 3 Quote Link to post Share on other sites
Rasva 25 Posted December 14, 2022 Share Posted December 14, 2022 On Sailfish I saw that notification LED does something, at least received SMS = blue LED. I cannot test more right now, temporarily I went back to Android. 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted December 14, 2022 Author Share Posted December 14, 2022 @Rasva Thanks, that confirms my suspicion that it's Android-specific... Quote Link to post Share on other sites
