zegoo 13 Posted August 5, 2024 Share Posted August 5, 2024 Hi all. A (dumb ?) question 🙄 ... Is there a Pro1x Shortcut keyboard to its backlit when openened ? Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 6, 2024 Share Posted August 6, 2024 None that I know of. (On the Pro1 (not Pro1X) there in settings is a Slider section for stock Android ("Buttons" for LineageOS) where you we can disable backlight, other than that I do not know of any settings related to the keyboard backlight) 1 Quote Link to post Share on other sites
FlyingAntero 871 Posted August 6, 2024 Share Posted August 6, 2024 (edited) In the past I used an app called ButtonLED to use the backlights of the hardware buttons as a notification lights. (Yes, years ago there were phones with hardware keys that had backlights). The app was able control the lights even without root if I remember correctly. Probably it will not work anymore at all or with Pro1(-X) but there might be similar apps still available. https://www.xda-developers.com/buttonled-turns-your-hardware-buttons-into-a-notification-led/ It is possible to regognize the opening of the keyboard with Key Mapper for example. Then you could use some automation app to perform the backlit via other app (if there is an app for that). I am just throwing some ideas. Edited August 6, 2024 by FlyingAntero 2 Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 6, 2024 Share Posted August 6, 2024 Maybe the FxServices by @Slion can do something relevant?https://community.fxtec.com/topic/2842-fx-service-smart-case-for-pro1/ https://slions.net/resources/fx-service.8/ ADD: just checked, does not look like it Quote Link to post Share on other sites
zegoo 13 Posted August 6, 2024 Author Share Posted August 6, 2024 (edited) @EskeRahn, thanks for your reply. I saw this option and i would use Key Mapper (For example) to trigger (Left Ctrl + *) to switch Off/On the backlit when opened. No way for the moment. The only way i found (for now) is to set an Action via Nova Launcher to directly access in "Buttons" section. So i would like something more precise 😄 Edit: I will NOT ask to @Slion if something could be done. @FlyingAntero, thanks for your reply too. I will take a look more deeply in Key Mapper cause i don't really what are the possibilities with it. Edited August 6, 2024 by zegoo 1 Quote Link to post Share on other sites
zegoo 13 Posted August 8, 2024 Author Share Posted August 8, 2024 (edited) Do you know why when I type one character, two are displayed? I'm trying to script a simple function to run with an alias to read /sys/class/leds/button-backlight/brightness and modify it to turn the keyboard on/off via Termux and all at once , my characters are doubled.😤  Edit 1: Code 30 I think 🙄. I made a full reinstall Termux from F-Droid.  For those which could be interested i made that: In my Home a script called toggle_keyboard_backlight.sh #!/data/data/com.termux/files/usr/bin/bash # toggle_keyboard_backlight.sh # Read current value with su -c current_brightness=$(su -c cat /sys/class/leds/button-backlight/brightness) # Switch between 0 and 255 if [ "$current_brightness" -eq "0" ]; then   su -c "echo 255 > /sys/class/leds/button-backlight/brightness" else   su -c "echo 0 > /sys/class/leds/button-backlight/brightness" fi  And don't forget to chmod +x And i had an alias in my bash.bashrc alias kb='~/toggle_keyboard_backlight.sh' And don't forget to 'source' it. Edited August 8, 2024 by zegoo Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 8, 2024 Share Posted August 8, 2024 1 hour ago, zegoo said: Do you know why when I type one character, two are displayed? I'm trying to script a simple function to run with an alias to read /sys/class/leds/button-backlight/brightness and modify it to turn the keyboard on/off via Termux and all at once , my characters are doubled.😤 It is not a situation I have experimented with, so can not say. You might try some software like like e.g. KeyEvent that shows the make and break codes for pressing and releasing each key. 1 Quote Link to post Share on other sites
Hook 3,306 Posted August 8, 2024 Share Posted August 8, 2024 1 hour ago, zegoo said: Do you know why when I type one character, two are displayed? I'm trying to script a simple function to run with an alias to read /sys/class/leds/button-backlight/brightness and modify it to turn the keyboard on/off via Termux and all at once , my characters are doubled.😤 One clarification. Under what conditions is this happening? When you run the script? When you are using the script editor? When you are using anything in Termux? Or is this something that is happening everywhere, whenever you type on the keyboard? I don't have any good answers, btw, but I would think anyone with answers would need to know that. 1 Quote Link to post Share on other sites
zegoo 13 Posted August 8, 2024 Author Share Posted August 8, 2024 (edited) 20 minutes ago, Hook said: One clarification. Under what conditions is this happening? When you run the script? When you are using the script editor? When you are using anything in Termux? Or is this something that is happening everywhere, whenever you type on the keyboard? I don't have any good answers, btw, but I would think anyone with answers would need to know that. @Hook, It was when i tried to save a file in nano with Ctrl+x. IDK why it happens but i have to full exit Termux to recover a working environment. In others Apps, there were not any issue with the Keyboard. So i decided to reinstall Termux from scratch. And, or now, to double char anymore. Wait & See.  Edit: This issue is back. I must exit Termux and clear the cache to get back my keyboard working with Termux as before. Very strange. Edited August 8, 2024 by zegoo 1 Quote Link to post Share on other sites
claude0001 1,424 Posted August 8, 2024 Share Posted August 8, 2024 I cannot reproduce this with my Pro1-X. Not using Termux, though. I'm running Debian 11 in a (rooted) chroot of LOS 20.0 and use ConnectBot as my terminal emulator. Your script works fine (with some trivial changes to match my environment). As, also for you, the keyboard behaves normally in other apps, it seems to me that you are somehow triggering a bug in the terminal emulation of Termux. 1 Quote Link to post Share on other sites
