Hook 3,386 Posted May 25 Author Share Posted May 25 Lineage-23.2-20260525-NIGHTLY-pro1x with May 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 1 Quote Link to post Share on other sites
Hook 3,386 Posted June 4 Author Share Posted June 4 Phew! That was close. Didn't get a chance to update until Tuesday night and discovered my Pro1x had been knocked loose from it's magnetic charging cable. It was rebooting and came up with 7% power. Was it in a boot loop because power was so low? Did I need my rubber bands. Apparently not. Don't entirely know why it was spontaneously rebooting, but it didn't start shutting down again. I connected the charging cable and turned off the screen and a couple of hours later it was full (Have it set to not charge over 85%. I think I was lucky. Lol. All's well that ends well. 😄 Lineage-23.2-20260601-NIGHTLY-pro1x with May 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 1 1 Quote Link to post Share on other sites
Hook 3,386 Posted June 8 Author Share Posted June 8 Lineage-23.2-20260608-NIGHTLY-pro1x with June 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
jsreed5 50 Posted June 14 Share Posted June 14 For the past few months, when I update LineageOS, I haven't been able to use Magisk to patch the boot partition directly in the inactive slot. I get an "unable to download bootctl" error, which is a network error according to GitHub, but I the error happens no matter what network I'm connected to. I have to export the update image, patch it, then flash the boot partition to boot_b manually using fastboot. Everything about LOS 23 works perfectly otherwise. Does anyone else have this problem? Quote Link to post Share on other sites
Hook 3,386 Posted June 16 Author Share Posted June 16 Lineage-23.2-20260615-NIGHTLY-pro1x with June 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted June 22 Author Share Posted June 22 Lineage-23.2-20260622-NIGHTLY-pro1x with June 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted June 30 Author Share Posted June 30 Lineage-23.2-20260629-NIGHTLY-pro1x with June 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted July 7 Author Share Posted July 7 Lineage-23.2-20260706-NIGHTLY-pro1x with June 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes Apparently, the June 29th update last week included a major change to the updater. It's fine once you figure it out, but given that all you are doing is downloading and installing, the older, much simpler UI was easier. I hate changes in UI for no other reason than to make things look prettier. This is much better being treated as a terminal app. Sheesh. Lol. I'm just old and crabby. 😄 1 1 Quote Link to post Share on other sites
Hook 3,386 Posted July 14 Author Share Posted July 14 Lineage-23.2-20260713-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted July 20 Author Share Posted July 20 Lineage-23.2-20260720-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes Not a big update, but I always test them. 2 Quote Link to post Share on other sites
Hook 3,386 Posted July 29 Author Share Posted July 29 Lineage-23.2-20260727-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes Another pretty small update, Wonder if they are working on Android 17 or if there's not much left to do because 16 is it. 😉 2 Quote Link to post Share on other sites
Hook 3,386 Posted August 3 Author Share Posted August 3 Lineage-23.2-20260803-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted August 10 Author Share Posted August 10 Lineage-23.2-20260810-NIGHTLY-pro1x with August 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted August 17 Author Share Posted August 17 Lineage-23.2-20260817-NIGHTLY-pro1x with August 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted August 24 Author Share Posted August 24 Lineage-23.2-20260824-NIGHTLY-pro1x with August 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted August 31 Author Share Posted August 31 Lineage-23.2-20260831-NIGHTLY-pro1x with August 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted September 7 Author Share Posted September 7 Lineage-23.2-20260907-NIGHTLY-pro1x with August 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted September 14 Author Share Posted September 14 Lineage-23.2-20260914-NIGHTLY-pro1x with September 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted September 22 Author Share Posted September 22 Lineage-23.2-20260921-NIGHTLY-pro1x with September 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted September 28 Author Share Posted September 28 Lineage-23.2-20260928-NIGHTLY-pro1x with September 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
Hook 3,386 Posted October 5 Author Share Posted October 5 Lineage-23.2-20261005-NIGHTLY-pro1x with September 1st security patch installed smoothly via OTA. MindTheGapps16, and root was maintained. Changelog: https://download.lineageos.org/devices/pro1x/changes 2 Quote Link to post Share on other sites
