pedro4444 36 Posted February 13 Share Posted February 13 (edited) Hello I have strange problem with my pro1 and problem with microphone. When I have basic profile and have call so is heard the blurring of the water in the background... something just rustles... but when I turn on speakerphone everything is fine.. That is still ok because the second microphone is used but what is also strange is that when I switch to another profile for example to guest it is bad a second and after a second it is ok.. The microphones have both been changed and it does the same thing... but is strange even below this because in guest is ok and when I have normal profil a call via the internet application as teams it is ok and I tried turning off volte/lte and nothing helped.. I now have the latest OS LineageOS 22.2. the phone was completely erased and the OS was reinstalled and it is bad on a clean.. Do you have any ideas? I want to try the older 20 please have someone this versions on donwload? thanks Edited February 13 by pedro4444 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted February 16 Share Posted February 16 On 2/13/2026 at 8:31 AM, pedro4444 said: I want to try the older 20 please have someone this versions on donwload? Which version, do you would like to test? LOS 20.x, 21.x, etc. I will check, which one I have 🙂 Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 16 Share Posted February 16 I whined about multiple bugs with 22.2 in the LOS thread here. The 22.1 is fine, so I would suggest to start to go for 22.1, before travelling further backwards. Last 22.1 was: lineage-22.1-20250405-nightly-pro1-signed.zip That can be found here:https://lineage-archive.timschumi.net/build/29528 2 Quote Link to post Share on other sites
