LineageOS 22.x Official Release for Pro1 (QX1000)
Official Release: https://download.lineageos.org/devices/pro1/builds
Changelog: https://download.lineageos.org/devices/pro1/changes
First Build: LINEAGE-22.1-20250101-NIGHTLY-PRO1-SIGNED.ZIP
How-To upgrade v.21 to v.22.1: https://wiki.lineageos.org/devices/pro1/upgrade
Gapps (ARM64!) https://wiki.lineageos.org/gapps/
Edited by TeZtdevice
Next update is LineageOS 22.2
  • Replies 184
Official Release: https://download.lineageos.org/devices/pro1/builds Changelog: https://download.lineageos.org/devices/pro1/changes First Build: LINEAGE-22.1-20250101-NIGHTLY-PRO1-SIGNED.ZIP
i have tested reinstall too. Today tested on my friend Skoda Superb 2019 - it works fine on cable. But still not working on my VW Caddy 2017 on MIB2 car stereo ;(   Maybe is it  ol
Lineage-22.2-20250412-nightly-pro1-signed.zip on April 5 (2025) security patch, installed smoothly using OTA BUT I have a bootloop. I think it´s because one of my activated modules in Magisk. UP
Lineage-22.1-20250101-NIGHTLY-pro1 with December 5th security patch installed smoothly. I have not installed MindTheGapps 15 or rooted as I have been experimenting with using my Pro1 Google Free (well, Playstore system free) since my Pro1x is actually my daily driver (as a writer, I like the keyboard tweaks better on the Pro1x).
I did this using the update instructions for the first time. It worked beautifully, leaving all of my data intact.  You are essentially doing an OTA update, except you have to do the update manually.  The instructions are very clear and it's so nice not to have to rebuild the phone after a major version update.
As always, although a Windows user most of the time, I used a Linux laptop (Manjaro) to do this stuff.
So far, everything is working.  Will advise if I find anything that isn't.
Did a dirty flash (no factory reset) from
lineage-21.0-20241228-nightly-pro1-signed.zip on December 1 security patch and MindTheGapps-14.0.0-arm64-20240925_175633
to
lineage-22.1-20250101-nightly-pro1-signed.zip on December 5 security patch and MindTheGapps-15.0.0-arm64-20240928_150548
using adb sideload
And all seems to work as before. 🙂
We still can only select one keyboard layout though, so no easy layout switching, for multilingual usage. 😢
I was unaware they added these nice instructions, but that is almost exactly what I did, having already fetched the MTG package for 15 a month ago, and prepared the batchfiles i usually use with suitably bumped numbers.
Lineage-22.1-20250101-nightly-pro1-signed.zip on December 5 (2024) security patch, installed smoothly using adb sideload (dirty flash over Lineage-21.0-20241228)
Magisk work after patching the boot.img of LineageOS 22.1 and re-flashing it with adb sideload.
(lineage-22.1-20250104-nightly-pro1-signed.zip on December 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548)
And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage.
Note that this is just a few days after the initial 01->04
(lineage-22.1-20250111-nightly-pro1-signed.zip on December 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548)
The only way of "upgrading" is installing LineageOS 22, which will give you the equivalent of Android 15.
Since LIneageOS re-uses most of the device drivers from stock Android 9, it is unlikely that audio or camera quality will be improved. At least I do not know of any such updates.
That being said, a recent LineageOS will give you all those Android security patches since 2020, which is of quite some value in itself ...
to @DoctorClu, I agree with @claude0001, but LineageOS also has it drawbacks, over stock, though for some they might not matter. Pros and cons....
Personally the lack of multiple key-layouts, that was broke a few versions ago, makes it almost useless for me (use it for tests only). And there might be some app that have very high security requirements that might not work.Could e.g. be bank apps, or some apps for putting official papers like drivers licence or similar identification apps on the phone. Some might work fine though, but not all.
(lineage-22.1-20250118-nightly-pro1-signed.zip on January 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548)
EDIT
I had issues with app-updates in the android market. I normally have automatic updates OFF, but even if I (for test) set it ON, I got the same bug, that after most of the download it stalled. I had it for three days, trying all possible remedies I could think of, but
The  bug is GONE four days later. So not a Lineage Issue!
1 hour ago, EskeRahn said:
Is anyone else having issues with app-updates in the android market? I normally have automatic updates OFF, but even if I (for test) set it ON, I get the same bug, that after most of the download it stalls.
It can be a tiny update less than 1MB. It most often stops at 99%, but can be earlier. If earlier putting in and out of aeroplane mode usually get it to 99%.
691007075_Screenshot_20250118-135500_GooglePlayStore_crop.thumb.png.80f00d617a72e64207a41f67ef855d86.png
Google's Updates works just fine on my Pro1 on stock. And my Pro1X on stock yesterday, (all using the same Google account).
Last this one updated was January 3. So that could have been on 21.0 So MIGHT be related to that I did NOT do a factory update, but did flash a new MTG with the 22.1
(I obviously tried to kill the store, and to restart the Pro1, also with long press, but no difference)
NOTE that I have mobile data OFF, so it is supposed to use WiFi ONLY.
Enabling mobile data does not change a thing
Nor does it matter if I only request update of a single app.
Also tried to clear data from cache+storage - no difference.
Removing the sim and restarting does not help either.
Not seeing this at all on my Pro1x.  Currently, my Pro 1 is Google Free so I  can't test there. Have you tried clearing Play Store cache, or a simulated battery pull (hold power until you get a spontaneous reboot, ignoring the normal restart button).  Generally, when something goes flaky on Android, the latter works miracles.
Yup tried both
I will await if anybody else has it, If not, I will try a wipe all the user data, and reinstall everything. (it is my spare/test-device, so tolerable)
(lineage-22.1-20250125-nightly-pro1-signed.zip on January 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548)
(lineage-22.1-20250201-nightly-pro1-signed.zip on January 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548)
(lineage-22.1-20250208-nightly-pro1-signed.zip on January 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548)
I probably missed why you have been including this warning every week for quite some time. Is this problem unique to the Pro1 (as the corresponding qx1050 thread does not mention it)?
Anyway, it seems I can find no open bug reported against LOS about this. So, whatever your issue is, I doubt it will ever be resolved "automatically" by an OTA.
Edited by claude0001
  • TeZtdevice changed the title to LineageOS 22.x Official Release for Pro1 (QX1000)
