Slion 1,201 Posted February 14, 2020 Share Posted February 14, 2020 13 minutes ago, 3zet said: That's sad What is? Actually I find Android pretty awesome in respect to key mapping cause it allows us to customise it the way we want without having to wait for FxTec to integrate changes. 1 Quote Link to post Share on other sites
3zet 100 Posted February 14, 2020 Share Posted February 14, 2020 18 minutes ago, Slion said: What is? The situation when application in 2020 is less functional than its 2006 equivalent. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 14, 2020 Share Posted February 14, 2020 1 hour ago, 3zet said: The situation when application in 2020 is less functional than its 2006 equivalent. The more functionality they would add, the longer we would have to wait. But sure I too hope that more functionality is coming in later OTA updates. 1 1 Quote Link to post Share on other sites
Slion 1,201 Posted February 14, 2020 Share Posted February 14, 2020 6 hours ago, 3zet said: That's sad, I remember for Symbian was app called MagicKey which was allowing change key mapping for different applications, so there was no need to change layouts manually. 6 hours ago, 3zet said: The situation when application in 2020 is less functional than its 2006 equivalent. I'm a Symbian fan, having worked for them in London in 2002, but calling any Symbian phone more functional than Pro1 is a bit of an overstatement 😁🤣 just a bit. 1 Quote Link to post Share on other sites
Slion 1,201 Posted February 14, 2020 Share Posted February 14, 2020 Attached is a modified version of FinQwerty adding two new US international layouts for Qwerty keyboards. They are prefixed "Alpha Slion" so that they show on top of that long list of layouts. They are more WYSIWYG than the original layouts from FinQwerty cause they use the Fn key to actually output keys yellow prints instead of the Alt key. Sym key is left as Sym modifier. Alt+Left: back Alt+Right: forward Alt+Down: Power (lock or wakeup) Alt+Up: F6 (which turns the keyboard backlight on somehow) Alt+ 1 to = : F1 to F12 The original FinQwerty US international QWERTY layouts were also modified to add Alt+Left and Alt+Right for Back and Forward. finqwerty-debug.apk Quote Link to post Share on other sites
Slion 1,201 Posted February 14, 2020 Share Posted February 14, 2020 New version same as above plus: Alt + Space: brings up android character picker dialog which is rather useless as it is Fn + Space: launch default browser Shift + Space: launch search application Fn + Tab: Opens up app switcher Sym: Launches google assistant It looks like for whatever reason the sym modifier is really not working as a normal modifier. Same with meta_left which is now mapped to Sym but in fact just launches google assistant, go figure. finqwerty-debug.apk Quote Link to post Share on other sites
Craig 1,435 Posted February 27, 2020 Share Posted February 27, 2020 On 2/7/2020 at 8:34 PM, peter.s.fidelman said: To force Portrait when keyboard is stored and Landscape when keyboard is deployed In "Slider Settings" make sure that "Landscape Orientation Lock" is on. Install "Lock Screen Rotation": <https://play.google.com/store/apps/details?id=it.ale32thebest.lockscreenrotation> and select "Landscape Mode". Contrary to what you may expect, this works! Apps are now forcibly confined to portrait/landscape mode depending on keyboard state. I have never seen an app that can escape this restriction, but note that apps that really wanted to be laid out the "other" way may not work well. I tried this under lineage, which handles it a little differently already. With landscape lock, it does indeed force apps landscape that wouldnt do it before (games, hangouts). However, I have to stop service or set it to force portrait to get portrait, even with keyboard closed. I imagine this is how its supoosed to work, but something funky in stock lets it go both ways. 1 Quote Link to post Share on other sites
Rud 123 Posted October 31, 2020 Share Posted October 31, 2020 (edited) As a sort of tip: I set "Smallest width" to 550 dp in Developer Options and everything looks stunning, if you want your apps to display more info. Also, I have a DELL 1080p monitor with USB-c and USB 3 ports and the phone works great with it, with just one cable you get: Video out Charging Any device plugged into monitor's USB ports is seen by the phone Also, with the 550 dp smallest width, apps look way better on the monitor. I tried various desktop layout apps but they are all pretty buggy. This seems like the cleanest compromise. Edited October 31, 2020 by Rud 1 1 Quote Link to post Share on other sites
