EskeRahn 5,595 Posted January 13, 2021 Share Posted January 13, 2021 3 hours ago, DieBruine said: Around €30,- from UK to NL. That's about 10,- too much for me. But thanks for sharing. It would be very nice if I could charge my phone wireless in my car. Hopefully 1300mAh will become more common soon. This 2000mA for €22 might be an interesting alternative for you https://www.amazon.de/dp/B08CBY4LBV EDIT: Sorry too wide, 80mm ADD: This is 2000mA and less wide (about 48mm) https://www.amazon.de/dp/B087TQP4DN (€20), this can be placed acentric aligned with the plug. Add II: Just ordered this https://www.ebay.nl/itm/324428608143 Quote Link to post Share on other sites
DieBruine 397 Posted January 13, 2021 Share Posted January 13, 2021 Yeah, I will wait for your experiences 🤔. I have several pads, all claiming higher current. So, seeing is beleiving. Let us know 😌. 1 Quote Link to post Share on other sites
MickH 212 Posted January 14, 2021 Author Share Posted January 14, 2021 17 hours ago, DieBruine said: Yeah, I will wait for your experiences 🤔. I have several pads, all claiming higher current. So, seeing is beleiving. Let us know 😌. I haven't attempted anything yet, my Pro1 died in November and it's at F(X)Tec for repair. I can't contact them by any means for an update. 1 Quote Link to post Share on other sites
lawliett 77 Posted February 21, 2021 Share Posted February 21, 2021 On 1/13/2021 at 1:04 PM, EskeRahn said: ADD: This is 2000mA and less wide (about 48mm) https://www.amazon.de/dp/B087TQP4DN (€20), this can be placed acentric aligned with the plug. Bought it and tested it out with anker wireless charging pad. Charging led lights up, but no actual charging. 😞 1 Quote Link to post Share on other sites
EskeRahn 5,595 Posted February 21, 2021 Share Posted February 21, 2021 2 minutes ago, lawliett said: Bought it and tested it out with anker wireless charging pad. Charging led lights up, but no actual charging. 😞 Oh, got the one I bought too a while back, but did not test it (yet), As it seems I have misplaced my wireless chargers (and yes have bought more than one varaiant of those too). Could be that it needs a certain amount of clearance to the metal back to actually work? Quote Link to post Share on other sites
lawliett 77 Posted February 21, 2021 Share Posted February 21, 2021 1 minute ago, EskeRahn said: Oh, got the one I bought too a while back, but did not test it (yet), As it seems I have misplaced my wireless chargers (and yes have bought more than one varaiant of those too). Could be that it needs a certain amount of clearance to the metal back to actually work? I used this anker charging pad: https://www.amazon.com/gp/product/B07THHQMHM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 with this adapter: https://www.amazon.com/gp/product/B07GWQ2GJC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 I'm going to buy this other adapter https://www.amazon.com/gp/product/B077HFFLMS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 as it appears to deliver more power and is recommended for use with the charging pad. I'll let you know if it works 2 Quote Link to post Share on other sites
EskeRahn 5,595 Posted February 21, 2021 Share Posted February 21, 2021 1 hour ago, lawliett said: Bought it and tested it out with anker wireless charging pad. Charging led lights up, but no actual charging. 😞 Found one in the car, that I know was able to charge my S8 (and a Priv also), but can not get the Pro1 to pull out more than 5W or less from the supply, that is something in the order of 2.5W to the phone, so with screen on it slows down the discharge, but does not charge, will try tried to let it stay connected a while, It just MIGHT be isn't able to provide a very slow charge.It does not matter if I even give at a huge distanceThe same combo can charge an S8 though, so all four components works (charger, cord station and plate) - five counting the current test, but there must be some negotiation-issues somewhere. I tried in three different chargers, in both ordinary and QC3.0 slots, that all works charging the Pro1 corded. Quote Link to post Share on other sites
BartWuchs 23 Posted February 21, 2021 Share Posted February 21, 2021 I am using my Pro 1 now for weeks with wireless charging and it works pretty fine. I use this Qi Receiver https://www.amazon.de/gp/product/B075L6MXJX/ and it works with nearly every loading pad. Two quite fast ones are these two https://www.amazon.de/gp/product/B0851XWYXK/ and https://www.amazon.de/gp/product/B07N67395S. How much watt it loads I don´t know but it is okay. I guess after (2 to) 3 hours it is fully loaded. I also "tuned" it a little bit by removing one of the layers of plastic coating and use some other foil as protection. Also removed the silver housing of the usb-c plug. 3 Quote Link to post Share on other sites
lawliett 77 Posted February 22, 2021 Share Posted February 22, 2021 23 hours ago, BartWuchs said: I am using my Pro 1 now for weeks with wireless charging and it works pretty fine. I use this Qi Receiver https://www.amazon.de/gp/product/B075L6MXJX/ and it works with nearly every loading pad. Two quite fast ones are these two https://www.amazon.de/gp/product/B0851XWYXK/ and https://www.amazon.de/gp/product/B07N67395S. How much watt it loads I don´t know but it is okay. I guess after (2 to) 3 hours it is fully loaded. I also "tuned" it a little bit by removing one of the layers of plastic coating and use some other foil as protection. Also removed the silver housing of the usb-c plug. Does it actually say battery charging on the screen? Or does only the notification led light up. Mine also charges with the above setup, but it doesn't say charging on the screen. It goes up like 1% after an hour. Quote Link to post Share on other sites
lawliett 77 Posted February 22, 2021 Share Posted February 22, 2021 (edited) On 2/21/2021 at 10:29 AM, EskeRahn said: Found one in the car, that I know was able to charge my S8 (and a Priv also), but can not get the Pro1 to pull out more than 5W or less from the supply, that is something in the order of 2.5W to the phone, so with screen on it slows down the discharge, but does not charge, will try tried to let it stay connected a while, It just MIGHT be isn't able to provide a very slow charge.It does not matter if I even give at a huge distanceThe same combo can charge an S8 though, so all four components works (charger, cord station and plate) - five counting the current test, but there must be some negotiation-issues somewhere. I tried in three different chargers, in both ordinary and QC3.0 slots, that all works charging the Pro1 corded. I'm having the same issues even with the 18 watt charging adapter I just got. I'm not sure how @BartWuchs got his to charge. I bought the 1A qi receiver he mentioned, but I can't find the 15w charging pad he mentioned, only found a 10w version in us amazon. Would it make sense the 2A qi receiver doesn't work, but the 1A receiver somehow works? Edited February 22, 2021 by lawliett Quote Link to post Share on other sites
BartWuchs 23 Posted February 22, 2021 Share Posted February 22, 2021 Yes for sure it is loading. As mentioned in the post it takes around 3 hours. I also tried different qi receiver but the only one that worked is the Nillkin. Quote Link to post Share on other sites
BartWuchs 23 Posted February 22, 2021 Share Posted February 22, 2021 36 minutes ago, lawliett said: I'm having the same issues even with the 18 watt charging adapter I just got. I'm not sure how @BartWuchs got his to charge. I bought the 1A qi receiver he mentioned, but I can't find the 15w charging pad he mentioned, only found a 10w version in us amazon. Would it make sense the 2A qi receiver doesn't work, but the 1A receiver somehow works? Just to make it more clear: I don´t think the charging pad is important if it loads or not. I am also using it in the car with an quite old one and it works. Other pads I am using are 10w no name pads from a local electronic store. Works too. I don´t think the loading pad is important - the receiver is more important. And the only one that is working (and I tried already 3 of them as I wanted to have replacement parts) is the Nillkin. 1 Quote Link to post Share on other sites
lawliett 77 Posted February 23, 2021 Share Posted February 23, 2021 On 2/21/2021 at 2:18 PM, BartWuchs said: I also "tuned" it a little bit by removing one of the layers of plastic coating and use some other foil as protection. Also removed the silver housing of the usb-c plug. How did you remove the housing of the usb-c plug? I'm not sure how to pry it open without breaking the plug. Quote Link to post Share on other sites
lawliett 77 Posted February 23, 2021 Share Posted February 23, 2021 (edited) Tested out Nilkin and MyMax Qi Receivers. Both work well, albeit slow charging. MyMax: https://www.amazon.com/gp/product/B07XD75XY3/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 Edited February 23, 2021 by lawliett 1 Quote Link to post Share on other sites
BartWuchs 23 Posted February 23, 2021 Share Posted February 23, 2021 (edited) 19 minutes ago, lawliett said: How did you remove the housing of the usb-c plug? I'm not sure how to pry it open without breaking the plug. You have to go with a flat plate along the flat cable into the housing and try to open it with small tilting moves. At some point it will open and it splits. Cable is pretty stable and I did it already 3 times but neverhteless be carefull. You can also use a small screwdriver. But thats one of the reasons why I bought 3 of the Nillkin 😁 And just to make it clear: I only removed the housing on the top - not the housing which goes in the USB port. Edited February 23, 2021 by BartWuchs 1 Quote Link to post Share on other sites
kashif 350 Posted April 19, 2021 Share Posted April 19, 2021 Hi Guys Sorry to ask this question as i am confused. I want to order the qi charging adapter, so can someone tell me the one works best with Pro1. If you can maybe post a amazon or ebay link to that one too. Thanks Quote Link to post Share on other sites
kashif 350 Posted April 27, 2021 Share Posted April 27, 2021 Hi Guys Today i received my qi wireless charger pad it seems to be not charging. when i put phone on pad while its shut down, it wakes up and turn on and get to running mode. the red light also turn on. but there is no indication of charging, and it doesnt show its charging. anyone know what the issue is or if it will work? 1 Quote Link to post Share on other sites
