michael.bosscha 142 Posted August 16, 2020 Share Posted August 16, 2020 Hey guys, I'm on vacation in Greece and noticed that I can't use roaming data. I googled a solution: manually enter the APN settings. Unfortunately, when done and hitting "save", it's not saving. Is there anything I'm doing wrong? I kind of want to be able to use my 4G while on the road... 1 Quote Link to post Share on other sites
DieBruine 397 Posted August 16, 2020 Share Posted August 16, 2020 I'm on LOS, works for me. Just addes a test APN, was able to save it. Unable to test stock at te moment. Quote Link to post Share on other sites
elvissteinjr 362 Posted August 16, 2020 Share Posted August 16, 2020 I've had to enter some APN settings manually to get mobile data on my carrier to begin with. Saved fine on stock, so I'm not sure what you're doing wrong. Perhaps some cache issue? 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 16, 2020 Share Posted August 16, 2020 10 hours ago, michael.bosscha said: Hey guys, I'm on vacation in Greece and noticed that I can't use roaming data. I googled a solution: manually enter the APN settings. Unfortunately, when done and hitting "save", it's not saving. Is there anything I'm doing wrong? I kind of want to be able to use my 4G while on the road... I've had a similar issue back in January the first time I was setting up APNs. I can't recall exactly what I did but I got it working in the end. The UI is a bit weird and if you use it "wrong" it won't save APN changes. Quote Link to post Share on other sites
Slion 1,201 Posted August 16, 2020 Share Posted August 16, 2020 Try changing only one APN property then save then back and do the same for the next APN properties. Quote Link to post Share on other sites
Craig 1,435 Posted August 17, 2020 Share Posted August 17, 2020 I can also also confirm it worked for me fine on stock (and don't recall if I had to set it again when I switched to lineage or not). Perhaps you could describe exactly what's going wrong.... Quote Link to post Share on other sites
michael.bosscha 142 Posted August 17, 2020 Author Share Posted August 17, 2020 Basically as said: I input all the values as described by the APN document (name, APN etc.), hit the three dots, hit "save"... and then nothing. I've done as suggested and fill out a single field, then saving, and going back if that works. I've come to the conclusion that changing the MCC value from 204 to 202 bugs it. I've been able to fill out the values before but am not able to connect to the internet with just those... 1 Quote Link to post Share on other sites
michael.bosscha 142 Posted August 17, 2020 Author Share Posted August 17, 2020 And out of the blue, it started working. That might have something to do with me enabling the "Mobile Data" slider, which is odd, but still... 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 17, 2020 Share Posted August 17, 2020 3 hours ago, michael.bosscha said: And out of the blue, it started working. That might have something to do with me enabling the "Mobile Data" slider, which is odd, but still... Indeed odd, but could make some sort of sense as APN is related to mobile data. I wonder if this is a general Android Pie bug/feature, or specific to the Pro1? Quote Link to post Share on other sites
