lzb 43 Posted October 9, 2020 Share Posted October 9, 2020 I have noticed that the two bottom corners of the Pro1 now have these small "blob" protrusions (see attached). Has anyone encountered these before? 1 Quote Link to post Share on other sites
VaZso 1,999 Posted October 9, 2020 Share Posted October 9, 2020 (edited) 21 minutes ago, lzb said: I have noticed that the two bottom corners of the Pro1 now have these small "blob" protrusions (see attached). Has anyone encountered these before? I didn't have such things with my original display, but I have a smaller one at one corner and a huge one at another corner on my replaced screen which I have bought at Aliexpress. Do you have this problem from the start or have they been appeared recently? Edited October 9, 2020 by VaZso Quote Link to post Share on other sites
lzb 43 Posted October 9, 2020 Author Share Posted October 9, 2020 Just now, VaZso said: I didn't have such things with my original display, but I have a smaller one at one corner and a huge one at another corner on my replaced screen which I have bought at Aliexpress. Do you have this problem from the start or they have been appeared recently? I just noticed them recently Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 9, 2020 Share Posted October 9, 2020 2 hours ago, lzb said: Has anyone encountered these before? Never noticed it bwfore, but looking carefully, I got it too on the "Final Sample" unit, (but not the Retail unit). Quote Link to post Share on other sites
Hook 3,317 Posted October 9, 2020 Share Posted October 9, 2020 I don't have it. It took me a while to find a way to check because I use a black wall paper and most of my apps are black or dark themed, but I finally found an app that gave me a bright white background. 😂 Quote Link to post Share on other sites
lzb 43 Posted October 9, 2020 Author Share Posted October 9, 2020 (edited) I suppose I can ignore it, as long as it doesn't get any worse. It's a retail unit that I've had for awhile, and the issue has only started now (or at least I've only noticed now). Of course if it gets worse the screen will become unusable. The scary scenario is that it's an ongoing issue that gets worse over time, and I've only noticed it now because the spots have "grown" past the boundaries of the screen Edited October 9, 2020 by lzb Quote Link to post Share on other sites
VaZso 1,999 Posted October 9, 2020 Share Posted October 9, 2020 12 minutes ago, lzb said: I suppose I can ignore it, as long as it doesn't get any worse. It's a retail unit that I've had for awhile, and the issue has only started now (or at least I've only noticed now). Of course if it gets worse the screen will become unusable. The scary scenario is that it's an ongoing issue that gets worse over time, and I've only noticed it now because the spots have "grown" past the boundaries of the screen I have a feeling it should have been there but you haven't noticed it before - or at least I hope so. The display what I have bought at Aliexpress had these problems from the beginning but I have noticed the big one only, then the smaller one later. It is an AMOLED problem anyway and it is not uncommon (look at this for example) and I think it is a manufacturing issue. The one which I have at one corner is huge, the other one is acceptable and also yours seems to be relatively good. Quote Link to post Share on other sites
hka 131 Posted October 9, 2020 Share Posted October 9, 2020 The replacement screen I got from fxtec has a similar bump in the corner. Didn't notice before. Quote Link to post Share on other sites
CornholioGSM 370 Posted October 9, 2020 Share Posted October 9, 2020 (edited) ...i have this same on two corners...fxtec have posted me display replacement, but "new" display was in worse condition than mine ( was not new - pulled from phone ) 😞 Good is that you can make more curved edges with application Edited October 9, 2020 by CornholioGSM Quote Link to post Share on other sites
