Adamyno 13 Posted August 11, 2022 Share Posted August 11, 2022 I opened this topic to talk about multi-boot options. Does anyone have a complete description of how to solve e.g. should the stock ROM be bootable in addition to the UT? Quote Link to post Share on other sites
Xav 5 Posted August 12, 2022 Share Posted August 12, 2022 (edited) You should be able to keep Stock Android on the slot A and flash Ubuntu Touch or something else on the slot B. For example in the following thread replace boot_a by boot_b and set_active a by set_active b. Edited August 12, 2022 by Dread Innacurate 1 Quote Link to post Share on other sites
ducksoup 110 Posted August 12, 2022 Share Posted August 12, 2022 On 8/12/2022 at 2:04 AM, Dread said: You should be able to keep Stock Android on the slot A and flash Ubuntu Touch or something else on the slot B. For example in the following thread replace boot_a by boot_b and set_active a by set_active b. Expand boot_a vs boot_b is the easy part. The hard part is creating two separate userdatas, and is alas somewhat more complicated than a mere "set_active". I'm looking forward to multiboot as well. I'd like to use Sailfish as my almost-fulltime OS, with the ability to boot into Android for occasional must-have Android-only apps (e.g. banking). 2 Quote Link to post Share on other sites
Xav 5 Posted August 12, 2022 Share Posted August 12, 2022 Oh alright my bad then 😅 Haven't played with Android in a while 1 Quote Link to post Share on other sites
brunoais 334 Posted August 12, 2022 Share Posted August 12, 2022 On 8/12/2022 at 5:34 AM, ducksoup said: must-have Android-only apps (e.g. banking). Expand Would it pass Google's attestation? I don't think it would... Quote Link to post Share on other sites
ducksoup 110 Posted August 12, 2022 Share Posted August 12, 2022 On 8/12/2022 at 8:36 PM, brunoais said: Would it pass Google's attestation? I don't think it would... Expand I'm not talking about NFC payment apps, just my bank's mobile app and authenticator app. Both of those work fine without attestation, and with enough poking and prodding, even on a rooted device. 1 Quote Link to post Share on other sites
