phukfxtec 24 Posted August 30, 2024 Share Posted August 30, 2024 (edited) one user suggests button combo instead of adb to get into edl: what is this "full" mode vs not full mode? I tried with buttons to no difference, still times out. are these guide's / tooling up to date? the information seems a little scattered between threads. is there any official documentation or official tooling from fx for flashing process and proper backing up procedure? please advise as I do not wish to brick my device. it appears it is easy to do so: https://community.fxtec.com/topic/4022-pro1x-is-bricked-is-there-any-way-to-save-it/?do=findComment&comment=69661 Edited August 31, 2024 by phukfxtec Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 31, 2024 Share Posted August 31, 2024 55 minutes ago, phukfxtec said: is there any official documentation or official tooling from fx for flashing process and proper backing up procedure? You could start at the thread pinned to the top in the community, where I keep various links like these.... 1 Quote Link to post Share on other sites
phukfxtec 24 Posted August 31, 2024 Share Posted August 31, 2024 (edited) 23 minutes ago, EskeRahn said: You could start at the thread pinned to the top in the community, where I keep various links like these.... That is where I started. It led me here. Where edl is failing to backup the persist partition. Edited August 31, 2024 by phukfxtec Quote Link to post Share on other sites
phukfxtec 24 Posted September 1, 2024 Share Posted September 1, 2024 (edited) linux host and linux livedvd vm continue to give issue... unknown root cause. tried edl on different machine with windows. hit issue: "NotImplementedError: Operation not supported or unimplemented on this platform"....solution was to reinstall WinUSB driver in Zadig: https://github.com/bkerler/edl/issues/349#issuecomment-2060152724 backup successful. Edited September 1, 2024 by phukfxtec Quote Link to post Share on other sites
phukfxtec 24 Posted September 1, 2024 Share Posted September 1, 2024 (edited) On 8/12/2022 at 7:44 PM, mosen said: tl:dr: Community has not found a safe way to restore backups as of yet. Making below described backups is still highly advised for a future where some wizard found a reliable way to restore those backups. new question: if flash linux, how to go back to android if can't restore backup? op make this note that there is no way to restore? Edited September 1, 2024 by phukfxtec Quote Link to post Share on other sites
FlyingAntero 871 Posted September 1, 2024 Share Posted September 1, 2024 4 hours ago, phukfxtec said: new question: if flash linux, how to go back to android if can't restore backup? op make this note that there is no way to restore? You can flash different OS (like Lineage OS or Sailfish OS) and go back to stock Android just by flashing it IF you do not brick the device during the process. The device is not completely wiped when you flash different OS. Idea of the back up is to save all partitions just in case if some error happens. However, currently there is no way restore those back ups but it does not mean that they are useless or could not be used in the future. So, just be careful when flashing 😉. 1 Quote Link to post Share on other sites
rossko 0 Posted September 1, 2024 Share Posted September 1, 2024 Hello @phukfxtec, I know you're probably going to call me a newbie or something and that I'm asking a lot, but do you think you can do a step-by-step tutorial of your progress? Quote Link to post Share on other sites
phukfxtec 24 Posted September 1, 2024 Share Posted September 1, 2024 (edited) 25 minutes ago, rossko said: I know you're probably going to call me a newbie or something never. we all start somewhere. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ I can't provide much better steps than what is already in the OP. I guess start here: backup persist. try adb method first. requires unlocked and a recovery boot if above doesn't work, install EDL (see readme and OP) edl r persist persist_backup.img edl r modemst2 modemst2_backup.img edl r modemst1 modemst1_backup.img edl r fsc fsc_backup.img edl r fsg fsg_backup.img flash your OS of choice: Edited September 1, 2024 by phukfxtec 3 Quote Link to post Share on other sites
agent008 248 Posted June 30, 2025 Share Posted June 30, 2025 (edited) I have just pulled the backups now. Here's what I did. 1) Unlocked bootloader following this guide --> (ATTENTION, at the end of step 3, after enabling USB Debugging, find another option on the same screen called "OEM unlocking". Enable that option too, else you cannot unlock the bootloader. Then, proceed with the remaining steps on the guide) 2) Installed Magisk and rooted phone following this guide --> 3) Downloaded LineageOS 22.2 recovery.img only at this point. Booted to the bootloader, by issuing the command below: adb reboot bootloader Then flashed the LineageOS Recovery with the command below: fastboot flash recovery recovery.img After flashing was finished, I selected "boot to recovery" on the bootloader. 4) Once on the Lineage Recovery, I selected "enable ADB" and followed Eske's guide found here --> https://eskerahn.dk/?p=4633 One adjustment to Eske's instructions is that I replaced his ls command with: adb ls -lah /dev/block/by-name And, from that list, I could find the device names for the partitions that are recommended that we back up. This is what they were linked to in my particular phone: lrwxrwxrwx 1 root root 15 1970-01-01 00:47 fsc -> /dev/block/sdf5 lrwxrwxrwx 1 root root 15 1970-01-01 00:47 fsg -> /dev/block/sdf4 lrwxrwxrwx 1 root root 15 1970-01-01 00:47 modemst1 -> /dev/block/sdf2 lrwxrwxrwx 1 root root 15 1970-01-01 00:47 modemst2 -> /dev/block/sdf3 lrwxrwxrwx 1 root root 15 1970-01-01 00:47 persist -> /dev/block/sda2 So, I just ran the "adb push <source> <destination_backup.img>" command for each of the above. These are the sizes for each of the images: -rw-r--r-- 1 localuser domain users 131072 jun 30 17:11 fsc_backup.img -rw-r--r-- 1 localuser domain users 2097152 jun 30 17:11 fsg_backup.img -rw-r--r-- 1 localuser domain users 2097152 jun 30 17:10 modemst1_backup.img -rw-r--r-- 1 localuser domain users 2097152 jun 30 17:10 modemst2_backup.img -rw-r--r-- 1 localuser domain users 33554432 jun 30 17:09 persist_backup.img Hopefully my backups are correct? 32M for persist, 2M for modemst1, modemst2 and fsg; and 128K for fsc. EDIT: As I now think further about it, step 2) above (rooting with Magisk) is probably not necessary. I had done it believing I could use adb on a rooted system with the phone booted to Android. It didn't work as the adb pull command would always run internally on the phone as an unprivileged user and didn't have access to the /dev/block devices. I believe it's likely that performing steps 1), 3) and 4) above is sufficient. Edited July 1, 2025 by agent008 Quote Link to post Share on other sites
agent008 248 Posted July 2, 2025 Share Posted July 2, 2025 (edited) Yesterday when I wanted to switch from LineageOS 22.2 to 22.1, I foolishly performed a factory reset/data wipe on LineageOS22.2 Recovery before removing the Google account I had logged on to on 22.2 with MindTheGapps. Now, if I flash MindTheGapps, I cannot login to my google account on the phone -- it fails. I can use the phone if I flash an OS without GMS. But then I cannot st the PIN/screen-lock. I suppose something is amiss on the persist partition? I do have the backup which I took before logging in to Google. Is there still no trustworthy method for flashing the persist backup? Thanks EDIT: solved this by installing the factory, GMS backup via qdl (as in here, can also be done via QFIL); signing on to Google on the stock firmware; removing the Google account from the phone on Stock; then, flashing LineageOS. Edited July 2, 2025 by agent008 1 Quote Link to post Share on other sites
