Name_not_avail 75 Posted November 1, 2022 Share Posted November 1, 2022 (edited) So I eventually decided that I might as well root my PrawnX, and tried to follow Casey's instructions here: https://community.fxtec.com/topic/3690-pro1-x-rooting-with-magisk/?tab=comments&_fromLogin=1 I got to the point of flashing the patched boot image back from my PC to the phone, and hit an error: Quote fastboot flash boot ./magisk_patched-25200_r5Hk7.img target reported max download size of 805306368 bytes sending 'boota' (98304 KB)... OKAY [ 2.317s] writing 'boota'... FAILED (remote: (boota_a) No such partition) finished. total time: 2.334s So then I did this: Quote fastboot getvar current-slot current-slot: a finished. total time: 0.003s Made me a bit nervous, because Casey's instructions of the PDF suggest that the file flashes to boot_b automatically. But whatever, I went with what getvar returned, and entered this: Quote fastboot flash boot_a magisk_patched-25200_r5Hk7.img target reported max download size of 805306368 bytes sending 'boot_a' (98304 KB)... OKAY [ 2.320s] writing 'boot_a'... OKAY [ 0.443s] finished. total time: 2.767s Then I did the "fastboot reboot", and voila, the PrawnX booted without problems, and I had superuser access through Magisk. YMMV, but it all looks tickety boo. Now I can get myself into some REAL trouble. 🙂 Edited November 1, 2022 by Name_not_avail fixed the quotes 1 Quote Link to post Share on other sites
Name_not_avail 75 Posted November 1, 2022 Author Share Posted November 1, 2022 (edited) NVM, I fixed it. Edited November 1, 2022 by Name_not_avail Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 1, 2022 Share Posted November 1, 2022 Thanks. let us tag @Casey, so FxTec can check if there is something inaccurate in the guide. (See below comments) 12 hours ago, Name_not_avail said: So then I did this: Quote fastboot getvar current-slot current-slot: a finished. total time: 0.003s Made me a bit nervous, because Casey's instructions of the PDF suggest that the file flashes to boot_b automatically. Quote Link to post Share on other sites
claude0001 1,424 Posted November 1, 2022 Share Posted November 1, 2022 For the record: @Casey's instructions did work for me. It automagically flashed the right slot, which I think was "b" in my case. 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 1, 2022 Share Posted November 1, 2022 Ah! It seems something is/was odd at @Name_not_avail's device as the quote said 'boota' and not 'boot_a' in his first attempt - I have no idea how that could be. Quote Link to post Share on other sites
Jormsen 12 Posted November 1, 2022 Share Posted November 1, 2022 5 hours ago, claude0001 said: For the record: @Casey's instructions did work for me. It automagically flashed the right slot, which I think was "b" in my case. Same for me... I did it twice (before and after upgrading one of the beta versions). No errors for me so far. 1 Quote Link to post Share on other sites
brunoais 335 Posted November 1, 2022 Share Posted November 1, 2022 @Name_not_avail Were you in the wrong fastbootd screen? Quote Link to post Share on other sites
Name_not_avail 75 Posted November 1, 2022 Author Share Posted November 1, 2022 I don't see how I could have been in the wrong fastboot screen. I didn't touch any of the buttons on the phone to change anything. The phone was completely stock, and I followed the PDF instructions to the letter, with one exception: I was using "Minimal ADB and Fastboot" to issue the terminal commands. That's been on this PC for a few years for other Android projects, but I don't see that being likely to change anything. Maybe, I guess. I will be interested to hear from @Casey about the difference between slot a and slot b, and whether I have screwed something up for future phone mods. Seems to work just fine at the moment, though. Quote Link to post Share on other sites
claude0001 1,424 Posted November 1, 2022 Share Posted November 1, 2022 (edited) 45 minutes ago, Name_not_avail said: the difference between slot a and slot b, and whether I have screwed something up I think it is unlikely you damaged anything. As you probably know, the A and B slots are a kind of safety net that (among others) allows the device to keep the previously running OS "in reserve" whenever an update is installed. The active slot basically flips between A and B everytime a new ROM is flashed. So whether A or B is the "right" one for installing Magisk simply depends on the number of previous flashings being even or odd. Edited November 1, 2022 by claude0001 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 1, 2022 Share Posted November 1, 2022 I think the culprit can be identified by the difference here 18 hours ago, Name_not_avail said: sending 'boota' (98304 KB)... OKAY [ 2.317s] writing 'boota'... FAILED (remote: (boota_a) No such partition) versus 18 hours ago, Name_not_avail said: sending 'boot_a' (98304 KB)... OKAY [ 2.320s] writing 'boot_a'... OKAY [ 0.443s] I have never heard of "boota" without an underscore. The big question is how it got in that weird state, but not most likely it was fixed by you changing: 18 hours ago, Name_not_avail said: fastboot flash boot .... to 18 hours ago, Name_not_avail said: fastboot flash boot_a .... Overwriting the weird value it had as read by "boot".... 1 Quote Link to post Share on other sites
