mangled 26 Posted October 19, 2023 Share Posted October 19, 2023 Hi, Pro1x is now supported. Check link below https://doc.e.foundation/devices/pro1x 3 Quote Link to post Share on other sites
guest03847 9 Posted October 19, 2023 Share Posted October 19, 2023 Congratulations for those of you that have received your Pro1 X, this is a teriffic OS. It is what I would have run on mine, if I ever received it. Quote Link to post Share on other sites
Hook 3,355 Posted October 19, 2023 Share Posted October 19, 2023 37 minutes ago, mangled said: Hi, Pro1x is now supported. Check link below https://doc.e.foundation/devices/pro1x Actually, the Pro1 as well. https://doc.e.foundation/devices/pro1 1 Quote Link to post Share on other sites
mangled 26 Posted October 19, 2023 Author Share Posted October 19, 2023 2 hours ago, Hook said: Actually, the Pro1 as well. https://doc.e.foundation/devices/pro1 Hey, Pro1 has been there for a while now. But yes its great to see both devices supported officially. Quote Link to post Share on other sites
ducksoup 110 Posted October 30, 2023 Share Posted October 30, 2023 If only an alternate ROM could change the Pro1-X into an actually usable device, but you can only polish a turd so much. Quote Link to post Share on other sites
Tomatoman29 11 Posted November 23, 2023 Share Posted November 23, 2023 (edited) I'm testing it for like a week or so on my Pro1 and at the moment that's the best android based OS I ever used. Even banking apps are working with microG. Later after changing my server I will host my own cloud for synchro. Edited November 23, 2023 by Tomatoman29 4 Quote Link to post Share on other sites
eorg 11 Posted August 3, 2024 Share Posted August 3, 2024 (edited) Hey there, I just came across this Version of a degoogled LineageOS port with integtated MicroG for support most of the google features. The /e foubdation seams to be a nonprofit organisation wich aims to give a privacy centered alternative to the Google environmelnt, they also host a cloud service called murena which may provide many services to compete with Thema of Google. Haven't tried it yet, but plan to do, as soon as I'm back from vacation. Has anyone already experience with it? @EskeRahnwould you mind adding this to the OS collection? Edited August 3, 2024 by eorg Quote Link to post Share on other sites
EskeRahn 5,604 Posted August 3, 2024 Share Posted August 3, 2024 Done, Please use this this thread for pros and cons of this build for the Pro1X (note that there is another LineageOS with MicroG also, see this: https://download.lineage.microg.org/pro1x/ ) 1 Quote Link to post Share on other sites
mangled 26 Posted August 5, 2024 Author Share Posted August 5, 2024 There is already a thread posted previously in the past about this. You can locate it below: 1 1 Quote Link to post Share on other sites
eorg 11 Posted August 5, 2024 Share Posted August 5, 2024 Thanks, and sorry, I've checked, but the search didn't brijg up the thread you posted. Quote Link to post Share on other sites
EskeRahn 5,604 Posted August 6, 2024 Share Posted August 6, 2024 On 8/5/2024 at 4:50 AM, mangled said: There is already a thread posted previously in the past about this. Thanks, merged 🙂 Quote Link to post Share on other sites
EskeRahn 5,604 Posted August 6, 2024 Share Posted August 6, 2024 16 hours ago, eorg said: Thanks, and sorry, I've checked, but the search didn't brijg up the thread you posted. Search in here can be a real challenge, as we can not search on short words... Quote Link to post Share on other sites
eorg 11 Posted August 6, 2024 Share Posted August 6, 2024 On 8/3/2024 at 11:48 PM, EskeRahn said: Done, Please use this this thread for pros and cons of this build for the Pro1X (note that there is another LineageOS with MicroG also, see this: https://download.lineage.microg.org/pro1x/ ) yes, I know of this OS. Using it since a year now. It works quite good, but some apps keep crashing and I don't know why, so I give the /e a try, I guess. Quote Link to post Share on other sites
