EskeRahn 5,598 Posted March 3, 2024 Share Posted March 3, 2024 (lineage-21.0-20240302-nightly-pro1-signed.zip on Feb 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted March 9, 2024 Author Share Posted March 9, 2024 (edited) Lineage-21.0-20240309-nightly-pro1-signed.zip on February 5 (2024) security patch, installed smoothly* using OTA *Boot time about 3min. (only the first start after update) !! (while the LOS-Update, I stopped all other updates or backups) Edited March 10, 2024 by TeZtdevice 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 9, 2024 Share Posted March 9, 2024 (lineage-21.0-20240309-nightly-pro1-signed.zip on Feb 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 9, 2024 Share Posted March 9, 2024 2 hours ago, TeZtdevice said: *Boot time about 3min. !! This is really weird, as I do NOT see this, I wonder if it is bound to the OTA-method??? Quote Link to post Share on other sites
TeZtdevice 368 Posted March 9, 2024 Author Share Posted March 9, 2024 23 minutes ago, EskeRahn said: This is really weird, as I do NOT see this, I wonder if it is bound to the OTA-method??? Well, I´m not sure. I thought, it´s because Magisk and all the modules. But I´m fine with it.... it works 🙂 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 16, 2024 Share Posted March 16, 2024 (lineage-21.0-20240316-nightly-pro1-signed.zip on Feb 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 3 Quote Link to post Share on other sites
TeZtdevice 368 Posted March 17, 2024 Author Share Posted March 17, 2024 Lineage-21.0-20240316-nightly-pro1-signed.zip on February 5 (2024) security patch, installed smoothly* using OTA *Boot time about 3min. (only the first start after update) (while the LOS-Update, I stopped all other updates or backups) 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 30, 2024 Share Posted March 30, 2024 (Lineage 21 on hold due to qpr2) https://community.fxtec.com/topic/4051-lineageos-210-official-release-for-pro1-x-qx1050/?do=findComment&comment=68456 1 3 Quote Link to post Share on other sites
CornholioGSM 370 Posted April 13, 2024 Share Posted April 13, 2024 i have updated (ota) to 21-20240413 without problem 🙂 3 Quote Link to post Share on other sites
Wheeljack 212 Posted April 14, 2024 Share Posted April 14, 2024 OTA update 20240413 went through without a hitch. First thing I noticed after updating: My preferred SIM card for data, calls, and text is still set. NICE! 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted April 14, 2024 Author Share Posted April 14, 2024 (edited) Lineage-21.0-20240413nightly-pro1-signed.zip on April 5 (2024) security patch, installed smoothly* using OTA *Boot time...no delay 😉 (while the LOS-Update, I stopped all other updates or backups) -> My personally issues: - LSPosed crashed... Solution: Uninstall original LSPosed v.1.9.2 and exchange it with LSPosed v.1.9.3_mod (fork of original LSPosed) - All my Pebble's (smartwatch) are not able to reconnect to these new LOS version (disconnection every 3 sec. ; bt pairing code are invalid) Edited April 14, 2024 by TeZtdevice 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted April 15, 2024 Share Posted April 15, 2024 (lineage-21.0-20240413-nightly-pro1-signed.zip on Apr 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 1 Quote Link to post Share on other sites
Wheeljack 212 Posted April 15, 2024 Share Posted April 15, 2024 23 hours ago, TeZtdevice said: - All my Pebble's (smartwatch) are not able to reconnect to these new LOS version (disconnection every 3 sec. ; bt pairing code are invalid) Can confirm. With a bit of fiddling around, putting my Pebble into pairing mode and reconnecting through the Pebble app (or should I call it Rebble app now?) I get a popup for a pairing request every minute or so. Eventually I am lucky and the pairing is successful and stable until I put too much distance between watch and phone. They won't automatically reconnect. 1 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted April 15, 2024 Author Share Posted April 15, 2024 30 minutes ago, Wheeljack said: Can confirm. With a bit of fiddling around, putting my Pebble into pairing mode and reconnecting through the Pebble app (or should I call it Rebble app now?) I get a popup for a pairing request every minute or so. Eventually I am lucky and the pairing is successful and stable until I put too much distance between watch and phone. They won't automatically reconnect. Yes, 100% correct. I could connect my watches without reset or restart, but if the pebbles are out of distance or standby mode the connection is lost. It is the same situation, if the Pro1 restart or toggle the bluetooth function. Similar feedback on these site: "https://codeberg.org/Freeyourgadget/Gadgetbridge/issues/3596" 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted April 16, 2024 Share Posted April 16, 2024 I also noticed that it repeatedly awakes the screen. I do not know if that is due to an app trying to (re)connect via bluetooth to a watch I'm testing. (both on the table, less than 50cm apart) 1 Quote Link to post Share on other sites
Wheeljack 212 Posted April 20, 2024 Share Posted April 20, 2024 21-20240420-NIGHTLY-pro1 installed smoothly via OTA, I've installed Magisk before reboot to make sure it stays rooted. Didn't notice anything new though. 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted April 20, 2024 Author Share Posted April 20, 2024 (edited) Lineage-21.0-20240420nightly-pro1-signed.zip on April 5 (2024) security patch, installed smoothly using OTA -> I forgot to install Magisk before, so I´ve to repatch the boot.img again -> Still the bluetooth issue with my smartwatch (will be patched with QPR2, I think / read) Edited April 23, 2024 by TeZtdevice 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted April 28, 2024 Author Share Posted April 28, 2024 Lineage-21.0-20240427nightly-pro1-signed.zip on April 5 (2024) security patch, installed smoothly using OTA -> Still the bluetooth issue with my smartwatch (will be patched with QPR2, I think / read) 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted April 30, 2024 Share Posted April 30, 2024 (lineage-21.0-20240427-nightly-pro1-signed.zip on Apr 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. I think I will reduce to something like monthly updates, if development is slowed down anyway.... 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted May 4, 2024 Author Share Posted May 4, 2024 Lineage-21.0-20240504nightly-pro1-signed.zip on April 5 (2024) security patch, installed smoothly using OTA-> Still the bluetooth issue with my smartwatch (will be patched with QPR2, I think / read) 2 Quote Link to post Share on other sites
CornholioGSM 370 Posted May 6, 2024 Share Posted May 6, 2024 One interesting thing. After last los update are all buttons on wired headphones again working 🙂 I mean specially volume and play/pause. Was not working on all android 13 los versions. 2 Quote Link to post Share on other sites
CornholioGSM 370 Posted May 6, 2024 Share Posted May 6, 2024 BUT i still have one big problem on los21. Screen rotate is sometime tooo slow and laggy. Rotating animation freeze on 75% of rotating process for approx 2-4 seconds 😞 It is not launcher problem - tested on original los launcher and then on lawnchair too Quote Link to post Share on other sites
Wheeljack 212 Posted May 11, 2024 Share Posted May 11, 2024 lineage_pro1-userdebug 14 AP1A.240405.002.A1 55d8b5678d My Pebble is connecting all by itself again! 3 Quote Link to post Share on other sites
TeZtdevice 368 Posted May 11, 2024 Author Share Posted May 11, 2024 Lineage-21.0-202405011nightly-pro1-signed.zip on April 5 (2024) security patch, installed smoothly using OTA -> My Peeble are connecting again! (my personally bluetooth issue is fixed) 3 Quote Link to post Share on other sites
TeZtdevice 368 Posted May 18, 2024 Author Share Posted May 18, 2024 Lineage-21.0-202405018nightly-pro1-signed.zip on May 5 (2024) security patch, installed smoothly using OTA 2 Quote Link to post Share on other sites
