TeZtdevice 373 Posted September 14, 2024 Author Share Posted September 14, 2024 Lineage-21.0-20240914nightly-pro1-signed.zip on September 5 (2024) security patch, installed smoothly using OTA BUT with these following issues: no camera no flashlight function 3 Quote Link to post Share on other sites
CornholioGSM 375 Posted September 21, 2024 Share Posted September 21, 2024 (edited) I have message from Nolen Johnson . CAMERA BUG IS FIXED! ...Report on Gitlab is now closed 🙂 Soo fix will be in this or on next week build. https://gitlab.com/LineageOS/issues/android/-/issues/7410#note_2123296136 Edited September 21, 2024 by CornholioGSM 1 3 Quote Link to post Share on other sites
CornholioGSM 375 Posted September 21, 2024 Share Posted September 21, 2024 ....hmmm soo in next build 😞 Today build have same problem 1 1 Quote Link to post Share on other sites
TeZtdevice 373 Posted September 21, 2024 Author Share Posted September 21, 2024 (edited) 1 hour ago, CornholioGSM said: ....hmmm soo in next build 😞 Today build have same problem Edited September 21, 2024 by TeZtdevice 5 Quote Link to post Share on other sites
CornholioGSM 375 Posted September 28, 2024 Share Posted September 28, 2024 Updated via OTA to 21-20240928-NIGHTLY-pro1 without problem. Camera and flashlight function is back 🙂 5 Quote Link to post Share on other sites
EskeRahn 5,604 Posted September 29, 2024 Share Posted September 29, 2024 (lineage-21.0-20240928-nightly-pro1-signed.zip on September 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage.Camera works though 😄 1 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted September 29, 2024 Share Posted September 29, 2024 PS I updated a quite old release, from about three months ago, and it took quite a while but did not ask for factory reset or anything like that. Quote Link to post Share on other sites
AndytheNoob 40 Posted October 2, 2024 Share Posted October 2, 2024 Latest OTA update installed today (2nd October 2024). CAMERA AND TORCH (FLASHLIGHT) NOW WORKING AGAIN! I've been waiting so long for this 😄 2 1 Quote Link to post Share on other sites
TeZtdevice 373 Posted October 3, 2024 Author Share Posted October 3, 2024 A special thanks to @CornholioGSM for opening the ticket about the camera issue ! 2 2 Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 5, 2024 Share Posted October 5, 2024 (lineage-21.0-20241005-nightly-pro1-signed.zip on September 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 1 1 Quote Link to post Share on other sites
TeZtdevice 373 Posted October 6, 2024 Author Share Posted October 6, 2024 Lineage-21.0-20241005nightly-pro1-signed.zip on September 5 (2024) security patch, installed smoothly using local update (sdcard) 2 Quote Link to post Share on other sites
Hook 3,370 Posted October 7, 2024 Share Posted October 7, 2024 Decided after some time to go back to using my Pro1 as a no-Google phone. So,factory reset and flashed Lineage-21-20241005-NIGHTLY-pro1-signed,zip with September 5th security patch and Magisk27.zip. All installed smoothly via ADB sideload. I tested root with TotalCommander and it was successful (I did have to let Magisk update via it's app after the sideload, but it took care of the boot image dance). Quick and easy. 2 Quote Link to post Share on other sites
TeZtdevice 373 Posted October 13, 2024 Author Share Posted October 13, 2024 Lineage-21.0-20241012nightly-pro1-signed.zip on September 5 (2024) security patch, installed smoothly using OTA Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 13, 2024 Share Posted October 13, 2024 (lineage-21.0-20241012-nightly-pro1-signed.zip on September 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 19, 2024 Share Posted October 19, 2024 There is a new mind the gab a few weeks old: MindTheGapps-14.0.0-arm64-20240925_175633https://github.com/MindTheGapps/14.0.0-arm64/releases/tag/MindTheGapps-14.0.0-arm64-20240925_175633 1 1 Quote Link to post Share on other sites
Hook 3,370 Posted October 19, 2024 Share Posted October 19, 2024 4 hours ago, EskeRahn said: There is a new mind the gab a few weeks old: MindTheGapps-14.0.0-arm64-20240925_175633https://github.com/MindTheGapps/14.0.0-arm64/releases/tag/MindTheGapps-14.0.0-arm64-20240925_175633 Maybe you know better. I have been assuming that if you are updating OTA rather than sideloading, flashing the newer Gapps isn't relevant since the Google Apps are updated by Google. 1 1 Quote Link to post Share on other sites
TeZtdevice 373 Posted October 19, 2024 Author Share Posted October 19, 2024 Lineage-21.0-20241019nightly-pro1-signed.zip on October 1 (2024) security patch, installed smoothly using OTA Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 20, 2024 Share Posted October 20, 2024 (lineage-21.0-20241019-nightly-pro1-signed.zip on Octoberr 1 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20240925_175633) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 20, 2024 Share Posted October 20, 2024 9 hours ago, Hook said: Maybe you know better. I have been assuming that if you are updating OTA rather than sideloading, flashing the newer Gapps isn't relevant since the Google Apps are updated by Google. Oh I was unaware of that, But since I always flash the gapps after Lineage, it makes sense that it is not a too old version being flashed, to avoid the need for all being updated. Quote Link to post Share on other sites
TeZtdevice 373 Posted October 25, 2024 Author Share Posted October 25, 2024 https://review.lineageos.org/q/project:LineageOS/android_device_fxtec_pro1+branch:lineage-22.0 ...interessting 🙂 1 1 Quote Link to post Share on other sites
Hook 3,370 Posted October 25, 2024 Share Posted October 25, 2024 1 hour ago, TeZtdevice said: https://review.lineageos.org/q/project:LineageOS/android_device_fxtec_pro1+branch:lineage-22.0 ...interessting 🙂 Nice. For Pro1x as well. Quote Link to post Share on other sites
TeZtdevice 373 Posted October 27, 2024 Author Share Posted October 27, 2024 Lineage-21.0-20241026-nightly-pro1-signed.zip on October 1 (2024) security patch, installed smoothly using OTA 2 Quote Link to post Share on other sites
TeZtdevice 373 Posted November 2, 2024 Author Share Posted November 2, 2024 Lineage-21.0-20241102-nightly-pro1-signed.zip on October 1 (2024) security patch, installed smoothly using OTA 2 Quote Link to post Share on other sites
EskeRahn 5,604 Posted November 4, 2024 Share Posted November 4, 2024 (lineage-21.0-20241102-nightly-pro1-signed.zip on October 1 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20240925_175633) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 1 Quote Link to post Share on other sites
TeZtdevice 373 Posted November 10, 2024 Author Share Posted November 10, 2024 Lineage-21.0-20241109-nightly-pro1-signed.zip on October 1 (2024) security patch, installed smoothly using OTA 1 Quote Link to post Share on other sites
