own3mall 2 Posted October 24, 2024 Share Posted October 24, 2024 Anyone else have this issue? Basically, if you make a phone call using LineageOS 21, you hear silence until other person picks up. No ringing sound plays. Kind of annoying, but not a show stopper. Looks like it's a bug: https://www.reddit.com/r/LineageOS/comments/15qqjy1/no_outgoing_dialling_tone/ https://gitlab.com/LineageOS/issues/android/-/issues/5916 Has it ever been fixed / is there a fix, or are the rest of you dealing with it as well? Quote Link to post Share on other sites
TeZtdevice 368 Posted October 25, 2024 Share Posted October 25, 2024 I have the same issue with my Pro1 (with LOS 21) since 2 month or more. Quote Link to post Share on other sites
CornholioGSM 370 Posted October 26, 2024 Share Posted October 26, 2024 (edited) yess same problem on pro1 from approx 4months old los builds. ...and same problem on los on another motorola phone. You can test to disable wifi calling and volte Edited October 26, 2024 by CornholioGSM 3 Quote Link to post Share on other sites
nother 0 Posted December 27, 2024 Share Posted December 27, 2024 (edited) Same problem here on a pro1 with just freshly adb sideloaded version 20241221-nightly-pro1 every thing seems to work perfectly, ring tones are there juts when calling no outgoing ringing tones. Its definitely VoLTE as I had not and do not have wifi-calls enabled. And enabling and than again disabling did not change. Disabling VoLTE reenabled or disabled blocking of outgoing ringing tones in the phone app. Might it be that not all carriers do support VoLTE properly or is it just an app issue. Edited December 27, 2024 by nother 1 Quote Link to post Share on other sites
pistikem 86 Posted January 1, 2025 Share Posted January 1, 2025 same here for several years already on my venerable FxTec Pro1 : no dial tone, but just with one single company, that's rebtel.com, and usually only when my phone wasn't rebooted recently. if freshly restarted everything works as expected : LED, ringing, dial tone, alarm tone, volumes. but the longer it's up, frequently months in my case, the likelier it becomes that these functions somehow misbehave or go dead even... i think it's in parts also an issue with the installed Android issue, it's just not the same as a proper linux system, like my rock-stable Slackware boxes. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 3, 2025 Share Posted January 3, 2025 I have no idea if there are any difference, but you could try to upgrade to the brand new 22.1, see the thread by @TeZtdevice here. 1 Quote Link to post Share on other sites
CornholioGSM 370 Posted January 3, 2025 Share Posted January 3, 2025 on 22.0/1 is it same problem 😞 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted April 14, 2025 Share Posted April 14, 2025 Today, I found a solution, for my Pro1, for my situation (Germany). I switch from the network-type: LTE/WCDMA to global. I didn´t change following settings: Wifi-Telefone (off), VoLTE (on) And now, I can hear the call ring 🤗 (LineageOS 22.2) 2 2 Quote Link to post Share on other sites
AndytheNoob 40 Posted April 28, 2025 Share Posted April 28, 2025 On 4/14/2025 at 6:17 PM, TeZtdevice said: Today, I found a solution, for my Pro1, for my situation (Germany). I switch from the network-type: LTE/WCDMA to global. I didn´t change following settings: Wifi-Telefone (off), VoLTE (on) And now, I can hear the call ring 🤗 (LineageOS 22.2) Thanks chief That worked for me too, though now my GPS is all over the place. I got lost while driving round because it couldn't lock onto my location. I use my phone as the sat-nav fairly regularly, so this is a weird one for me. Hoping the sat-nav issue is a Lineage6 22.- update issue rather than a problem with the Network type. 1 Quote Link to post Share on other sites
