Hook 3,313 Posted July 24, 2025 Share Posted July 24, 2025 1 hour ago, Onkel Otto said: But Airplane mode is no solution for me, because I am using the Pro1 not only as little computer, but also as a mobile phone. Just to be clear, I wasn't suggesting not using a Pro 1 as a phone should be a solution for anyone. However, my defect led me to a diagnosis of the possible problem with Airplane Mode being a test. 🙂 I'm just lucky my problem doesn't affect me much because I happen to be weird. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 25, 2025 Share Posted July 25, 2025 On 7/24/2025 at 1:31 PM, Onkel Otto said: my Pro1 was emptying the battery to only 50%. Slight improvement, but still to much to use it during the day at work and so on. Last night I had "Airplane Mode" on and Wifi on too. VoLTE (4G-Anrufe in the phone localized to a German UI) was on. Could you please test if it make any difference over night, if you turn VoLTE temporarily OFF? Just to test if VoLTE is somehow part of the issue. (I know turning VoLTE off will not be a solution, for carriers that shut down their 3G services. So just a test) Quote Link to post Share on other sites
Onkel Otto 10 Posted July 25, 2025 Share Posted July 25, 2025 I will test it tonight with VoLTE off. 1 Quote Link to post Share on other sites
Onkel Otto 10 Posted July 28, 2025 Share Posted July 28, 2025 (edited) I used my Pro 1 with VoLTE off during the past 3 days. At nights I set it to "Airplane Mode" on and Wifi on. For this, VoLTE off made no difference regarding the battery drainage. But during the day - with "Airplane Mode" off and "normal" phone usage, VoLTE off reduced the battery drainage. It is still not as good as with Lineage 22.1, but my Pro 1 survived the days without additional charging in the afternoon. The past two days were weekend days, where my phone usage is different to week days. Therefore I have to observe this a few more days. I also received a new 5G SIM card from my provider (I did not order this - they are changing their system - it is a pity, that the Pro 1 does not use 5G). I put the new SIM card in the phone today, because I have to use it before the end of the month. And I switched VoLTE on. I will check for two or three days and then report here, if the new SIM card has an effect on the battery drainage. After that test I will continue with the VoLTE test. Edited July 28, 2025 by Onkel Otto 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 6, 2025 Share Posted August 6, 2025 Due to the changes @Hook reported here, I tried upgrading to 22.2 (again). Will edit this post in some hours with the result.... ADD: And it is completely USELESS!!! Went from 97% to 47% in short of 8 hours. (Idle overnight, as much as possible uninstalled/disabled,,,,) Will go back to 22.1, or maybe stock and just forget about LineageOS, that (like the AICP project) seems to have F.. itself up to a useless state...Went back to 22.1, though over four months old still much newer than Android 9 in stock...., 1 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 7, 2025 Share Posted August 7, 2025 Spotted a more important bug that could be related with the battery waste as we discussed earlier. With the same sim in the same phone at the same location, and set for LTE only, here VoLTE works just fine on 22.1, but not at all on 22.2. So 22.2 CERTAINLY introduced some important bug in handling of carriers and bands (the sim is TDC in Denmark). 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted September 13, 2025 Share Posted September 13, 2025 I optimistically tried 22.2 again (20250913), still not working VoLTE not supported, 😠 So back on 22.1 - where VoLTE works ☺️ 2 Quote Link to post Share on other sites
CornholioGSM 370 Posted September 16, 2025 Share Posted September 16, 2025 On 9/13/2025 at 6:56 PM, EskeRahn said: I optimistically tried 22.2 again (20250913), still not working VoLTE not supported, 😠 So back on 22.1 - where VoLTE works ☺️ I mean that it is for nothing to crying here 😞 Only way is write to lineage gitlab and wait for result 🙂 Quote Link to post Share on other sites
EskeRahn 5,598 Posted September 16, 2025 Share Posted September 16, 2025 12 hours ago, CornholioGSM said: I mean that it is for nothing to crying here 😞 Only way is write to lineage gitlab and wait for result 🙂 I previously tried to report a bug - and frankly I do not want to to try that again. With neither calls on 4G nor multilingual keyboard working, and combined with ridiculous stamina, It is unusable as a daily driver for me anyway. for 22.1 it is only the keyboard that is messed up. And has been since perhaps 20.1 or even older. So more reporting the state here so others do not waste their time with it, than actually expecting anyone that can fix it to read it here, 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 16, 2025 Share Posted October 16, 2025 As LOS 23.0 is now available for the Pro1X (see this), we can expect it for the Pro1 as well in a few days. Will try it ASAP and report back, if it is as useful as 22.1 or as useless as 22.2. Quote Link to post Share on other sites
elvissteinjr 362 Posted October 16, 2025 Share Posted October 16, 2025 3 hours ago, EskeRahn said: we can expect it for the Pro1 as well in a few days Very optimistic. Android 16 comes with additional eBPF feature requirements to the kernel, which the 4.4 version the Pro1 is stuck on doesn't fulfill, but the Pro1X's 4.19 kernel version does. Or rather, those have been backported down to that version, but nobody has done this for 4.4 yet. See the LineageOS announcement for some details: https://lineageos.org/Changelog-30/ It may happen, but not within a few days if it does. 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 18, 2025 Share Posted October 18, 2025 On 10/16/2025 at 10:55 AM, elvissteinjr said: It may happen, but not within a few days if it does. Ah thanks for the info! I optimistically tried 22.2 again (20251011), still not working VoLTE not supported, 😠 (expecting the 23 I thought this might be the last 22.2, so wanted to test before 23) So going back on 22.1 (20250405)- where VoLTE works ☺️ 1 1 Quote Link to post Share on other sites
Onkel Otto 10 Posted October 30, 2025 Share Posted October 30, 2025 On 7/28/2025 at 4:00 PM, Onkel Otto said: I will check for two or three days and then report here, if the new SIM card has an effect on the battery drainage. Hi Everybody, I am sorry for the late response. I was to busy for almost 2 month and forgot to answer here. Today I updated to lineage-22.2-20251022-microG-NO-PI-PATCH, and that did remind me that I have an open promise here. On my Pro1 the new SIM card almost solved the battery drainage problem. The phone is still consuming a little bit more battery than it did before the update to LOS 22. That time I had to charge it every second day only. Now with the new SIM card the battery works for a full day again. That makes the Pro1 use-able for me. 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 24, 2025 Share Posted November 24, 2025 (Still no 23.0 for Pro1, so likely not going to happen, and as 22.2 is borked use 22.1 or earlier) 1 Quote Link to post Share on other sites
paul 9 Posted November 30, 2025 Share Posted November 30, 2025 (edited) Hello all, As @elvissteinjr correctly stated, Pro1 needs a kernel patch to be supported in LOS 23. in the concrete case that the ebpf backport will not be available for the kernel 4.4, I googled for msm8998 devices and there are one or two shipped or updated with kernel 4.14. maybe trying to update the kernel to that version is the way to. Also thinking that some hardware is shared with pro1x that is shipped with 4.19 will make easier the compilation. Do we have the kernel sources for pro1? Edited November 30, 2025 by paul reference 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 1, 2025 Share Posted December 1, 2025 10 hours ago, paul said: Do we have the kernel sources for pro1? As I understood it one of the reasons for the Pro1X sort of 'reinventing the wheel' was that those that swindled FxTec where the ones with almost all the drawings and source code. I could be mistaken though. Quote Link to post Share on other sites
claude0001 1,424 Posted December 1, 2025 Share Posted December 1, 2025 On 11/30/2025 at 8:42 PM, paul said: Hello all, As @elvissteinjr correctly stated, Pro1 needs a kernel patch to be supported in LOS 23. in the concrete case that the ebpf backport will not be available for the kernel 4.4, I googled for msm8998 devices and there are one or two shipped or updated with kernel 4.14. maybe trying to update the kernel to that version is the way to. Also thinking that some hardware is shared with pro1x that is shipped with 4.19 will make easier the compilation. Do we have the kernel sources for pro1? I think that for an OS like Lineage, which is supposed to be just Android-without-the-Google-bits, upgrading the major Kernel version will be next to impossible. The proprietary vendor blobs compiled for 4.4. will not load with 4.14 or later. That's just not how Linux works. Yes, there may be some other ms8998 devices out there using later Android kernels. So it may boot somehow. But what's the good of that if your LTE-modem, camera, and touchscreen no longer work? 2 Quote Link to post Share on other sites
claude0001 1,424 Posted December 1, 2025 Share Posted December 1, 2025 13 hours ago, EskeRahn said: As I understood it one of the reasons for the Pro1X sort of 'reinventing the wheel' was that those that swindled FxTec where the ones with almost all the drawings and source code. I could be mistaken though. The base kernel source is of course available as per the GPL2. Also, e.g., the keyboard-driver source is available as part of LineageOS. However, much of the device drivers that make up basic mobile-phone functionality are not. The project of mainlining the Pro1 got stuck on such profane things like the touchscreen driver requiring some non-disclosed firmware magic to be usable in the first place. Device drivers not being open-sourced is pretty standard in the Android world, though. Nothing specific to the Pro1 here. 👎 2 Quote Link to post Share on other sites
paul 9 Posted December 5, 2025 Share Posted December 5, 2025 My first idea was to start with pro1x kernel 4.19, maybe the compiled proprietary blobs are the same or mostly the same as pro1. But I never found a 4.19 kernel built for msm8998... Maybe one of the guru of the company can help us with the driver sources? unless @EskeRahn is correct and the sources were part of the swindle, though. 1 Quote Link to post Share on other sites
claude0001 1,424 Posted December 5, 2025 Share Posted December 5, 2025 (edited) 4 hours ago, paul said: unless @EskeRahn is correct and the sources were part of the swindle, though. F(x)tec never had all the driver sources. And even if they did, they would not have been allowed to publish them. A prominent exception is the keyboard, which is the one hardware component they developed themselves. The rest of the hard- and software came from a Chinese OEM. The idea that f(x)tec ever wanted to make the Pro1/Pro1X "open" phones is a misconception introduced by some media and bloggers. F(x)tec never publicly corrected that misunderstanding, presumably as they hoped to profit from all that "Linux-phone" hype. In reality, the Pro1 was designed as a pretty standard, proprietary Android device and is not any more "Linux" than your random Galaxy. Edited December 5, 2025 by claude0001 3 Quote Link to post Share on other sites
CornholioGSM 370 Posted December 7, 2025 Share Posted December 7, 2025 (edited) Hi all 🙂 I have problem on my pro1 with Android auto and i want to know , if is it problem only with my device or on all. Display on car stereo is like pulsing and blurring. It was tested on 3 (vw and toyota)cars and on all is it same. I am now on latest LOS and android auto version 15.8.15404. Tested on wireless and cable connection. Edited December 7, 2025 by CornholioGSM 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 8, 2025 Share Posted December 8, 2025 16 hours ago, CornholioGSM said: I am now on latest LOS and android auto version 15.8.15404. Have you tried going back to 22.1? I would not be surprised if there are more regressions with 22.2... Quote Link to post Share on other sites
CornholioGSM 370 Posted December 8, 2025 Share Posted December 8, 2025 48 minutes ago, EskeRahn said: Have you tried going back to 22.1? I would not be surprised if there are more regressions with 22.2... Oh - nono...it will be too much work for me 🙂 Maybe more simple way will be downgrade AA to latest working 14.x.x version. 1 Quote Link to post Share on other sites
CornholioGSM 370 Posted December 9, 2025 Share Posted December 9, 2025 ...but question is still I am only one with this problem with Android Auto? Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 9, 2025 Share Posted December 9, 2025 21 hours ago, CornholioGSM said: ...but question is still I am only one with this problem with Android Auto? I think we are very few users left here, so would be pure luck if some with the same problem spotted your post... Quote Link to post Share on other sites
