TeZtdevice 368 Posted July 14, 2025 Author Share Posted July 14, 2025 (edited) 18 hours ago, helder_alemao said: Hi there. I have Lineage 22.2 installed on my Pro 1X and still shows an update to 22.2 about 1Gb. Is it normal? Can i proceed with the update? Thanks Yes, that´s a normal file size for a currently update. Edited July 15, 2025 by TeZtdevice wrong image Quote Link to post Share on other sites
Hook 3,319 Posted July 15, 2025 Share Posted July 15, 2025 6 hours ago, helder_alemao said: Hi there. I have Lineage 22.2 installed on my Pro 1X and still shows an update to 22.2 about 1Gb. Is it normal? Can i proceed with the update? Thanks Remember, the updates are not just what is being added... they are the whole package with the updates integrated. (They don't disturb your settings and data). 1 Quote Link to post Share on other sites
helder_alemao 53 Posted July 15, 2025 Share Posted July 15, 2025 9 hours ago, Hook said: Remember, the updates are not just what is being added... they are the whole package with the updates integrated. (They don't disturb your settings and data). The strange thing to me was having two 22.2 updates of 1Gb each and i was not sure if i should go trough 1 Quote Link to post Share on other sites
claude0001 1,424 Posted July 15, 2025 Share Posted July 15, 2025 (edited) 2 hours ago, helder_alemao said: two 22.2 updates of 1Gb each The point is that the updates are not incremental. The weekly OTAs each time contain the full ROM, even if changes relative to the previous one are minor or non-existing. The idea behind the a/b partitioning scheme is to keep the previous version of the system intact for backup, while flashing a completely new version of the OS to the respective other slot with every update. This is to make sure one of the slots always contains a working OS, even in case of a bad flash or faulty download. Edited July 15, 2025 by claude0001 3 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 16, 2025 Share Posted July 16, 2025 Well it is a choice. They COULD have made the update system as a primary version and then a series of deltas. The flipside of that would be that any reinstalls or new installs would require to first load the old full and then maybe scores of updates, installing all in the same partition, and this could be slow. And it would add some extra complexity in generating and applying the deltas. It is much simpler to just have a source that builds a total, and then distribute that, despite the extra traffic, and slower installs than the delta could have given, if it started by making a copy of the running partition and then applied the delta. 1 Quote Link to post Share on other sites
helder_alemao 53 Posted July 17, 2025 Share Posted July 17, 2025 Had 3 available updates and started from the oldest. Then figured that could update from the most recent one 1 1 Quote Link to post Share on other sites
Hook 3,319 Posted July 21, 2025 Share Posted July 21, 2025 Lineage-22.2-20250721-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,319 Posted July 29, 2025 Share Posted July 29, 2025 Lineage-22.2-20250728-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,319 Posted August 4, 2025 Share Posted August 4, 2025 Lineage-22.2-20250804-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 2 Quote Link to post Share on other sites
Hook 3,319 Posted August 4, 2025 Share Posted August 4, 2025 I don't have any objective way of testing this, but I noticed that the change log for the last update and this one included references to carrier stuff. It seems to me that my phone call clarity has improved. The phone stuff actually worked pretty good for me from the get go. It wasn't perfect but far better than many people were reporting. But it seems, though anecdotal, that it has improved. Unfortunately, I don't really use this phone as a phone, as ironic as that it is for one that mostly works. So I haven't tried in a very long time, which makes this anecdotal report even more suspicious. 😉 2 Quote Link to post Share on other sites
Hook 3,319 Posted August 11, 2025 Share Posted August 11, 2025 Lineage-22.2-20250811-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. I want to note that even though my Pro1x has working phone stuff, it has never demonstrated the battery drain problem on 22.2. 2 Quote Link to post Share on other sites
Hook 3,319 Posted August 18, 2025 Share Posted August 18, 2025 Lineage-22.2-20250818-NIGHTLY-pro1x with July 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. A little slow on getting the Aug security patch. 2 Quote Link to post Share on other sites
Hook 3,319 Posted August 26, 2025 Share Posted August 26, 2025 Lineage-22.2-20250825-NIGHTLY-pro1x with Aug 1st (Finally!) security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,319 Posted September 1, 2025 Share Posted September 1, 2025 Lineage-22.2-20250901-NIGHTLY-pro1x with Aug 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 2 Quote Link to post Share on other sites
Hook 3,319 Posted September 8, 2025 Share Posted September 8, 2025 Lineage-22.2-20250908-NIGHTLY-pro1x with Aug 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,319 Posted September 16, 2025 Share Posted September 16, 2025 Lineage-22.2-20250915-NIGHTLY-pro1x with Aug 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,319 Posted September 22, 2025 Share Posted September 22, 2025 Lineage-22.2-20250922-NIGHTLY-pro1x with September 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,319 Posted September 30, 2025 Share Posted September 30, 2025 Lineage-22.2-20250929-NIGHTLY-pro1x with September 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,319 Posted October 6, 2025 Share Posted October 6, 2025 Lineage-22.2-20251006-NIGHTLY-pro1x with September 1st security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,319 Posted October 14, 2025 Share Posted October 14, 2025 Lineage 23.0 (Android 16) is out for the Pro1x. This conversation continues here: 1 1 Quote Link to post Share on other sites
