david 929 Posted November 19, 2019 Author Share Posted November 19, 2019 2 Quote Link to post Share on other sites
silversolver 849 Posted November 19, 2019 Share Posted November 19, 2019 Oops. I searched for something like that but didn't find it. Go ahead and delete this thread. Quote Link to post Share on other sites
silversolver 849 Posted November 19, 2019 Share Posted November 19, 2019 (edited) On 9/29/2019 at 4:37 AM, Kzin said: Yup, there is a disassembly guide "https://www.ifixit.com/Teardown/Motorola+Droid+4+Teardown/7759", see step 13, the white cover comes off the motherboard, I used isopropyl alcohol on a rag to wipe the motherboard, check the metal contacts in the white part too, but I did not use the alcohol on that. I've torn down several of mine with no guide. Droid 4 is a very serviceable platform, and it appears that Pro1 was made with all the advantages of D4's design. For the record, I'll have D4s around for quite some time still as beater devices. I'm still using one as my daily driver right now. Edited November 19, 2019 by silversolver 1 Quote Link to post Share on other sites
david 929 Posted November 30, 2019 Author Share Posted November 30, 2019 Posting a link here regarding a discussion on screen issues in the production assembly line, which relates to repairability for our home assembly lines of the future: Quote Link to post Share on other sites
david 929 Posted February 19, 2020 Author Share Posted February 19, 2020 Man, the post moves really killed some of the links in this topic. :-) I'd like to know more about the vibration motor in the Pro1. It is too weak. I'm hoping it is of a standard design and can be replaced with something that is the same form factor, but just works better (stronger). Anyone find this in the teardown documentation somewhere and know anything about the replaceability of it? I suppose it could even be a matter of the current motor not being in contact with the frame enough to transmit the vibrations properly. In which case, maybe the motor wouldn't need replacing, but would just need to be glued to something or have a piece of metal glued to it and glued to somewhere else on the frame. I would have to say that this is my number one problem with the Pro1. It hampers my use of the Pro1 as a communications device, which is really its primary purpose for me. I can obviously turn on sounds, but that's just not how I want to use a phone. I've never had a problem with using vibration on any past phones. Quote Link to post Share on other sites
david 929 Posted February 19, 2020 Author Share Posted February 19, 2020 Well, I partly answered my own question. I found the location of the motor. It is up by the headphone jack. And it is the "good kind" of motor -- Linear Motor, not ERM. This is going off information online where people indicated that high end phones use the Linear Motor type vibration motors. So it might just be that this particular brand/model is a dud. It looks like the back reads: 0612 and +9431 to me. Off to search for it. 3 Quote Link to post Share on other sites
david 929 Posted February 19, 2020 Author Share Posted February 19, 2020 Well, I couldn't find it. I guess it wouldn't have to be identical. It would just need to be something that would fit in the space, even if it was the button shaped type motor. It would just need to match the right voltage, which should be easy to measure with a multi-meter. In fact, hopefully that isn't the problem. Hopefully it is being driven with the right voltage, otherwise that's a much more difficult thing to fix. Quote Link to post Share on other sites
david 929 Posted February 19, 2020 Author Share Posted February 19, 2020 Okay, this is a "what if". What if the pad (circled in green) that is probably meant to not allow the case to flex too much *or* is meant to deliver the vibrations from the motor to the case, is too soft? It could be absorbing the vibrations. If so, replacing that soft pad with a firmer material might make the vibrations stronger through the case. Quote Link to post Share on other sites
_DW_ 628 Posted February 19, 2020 Share Posted February 19, 2020 5 hours ago, david said: Well, I couldn't find it. I guess it wouldn't have to be identical. It would just need to be something that would fit in the space, even if it was the button shaped type motor. It would just need to match the right voltage, which should be easy to measure with a multi-meter. In fact, hopefully that isn't the problem. Hopefully it is being driven with the right voltage, otherwise that's a much more difficult thing to fix. Why not try powering it external to check if it's dud before getting another? 1 Quote Link to post Share on other sites
_DW_ 628 Posted February 19, 2020 Share Posted February 19, 2020 5 hours ago, david said: It looks like the back reads: 0612 and +9431 to me. Yeah I agree 1 Quote Link to post Share on other sites
EskeRahn 5,588 Posted February 19, 2020 Share Posted February 19, 2020 10 hours ago, david said: I'd like to know more about the vibration motor in the Pro1. It is too weak. I'm hoping it is of a standard design and can be replaced with something that is the same form factor, but just works better (stronger). It is physics, not the motor... Quote Link to post Share on other sites
david 929 Posted February 19, 2020 Author Share Posted February 19, 2020 4 hours ago, _DW_ said: Why not try powering it external to check if it's dud before getting another? Well, once the phone is apart, it would be nice to have something ready to try. They don't cost a lot. I am not sure if you can drive them externally though. I believe the LRA style motors need the driver to monitor for the resonate frequency and adjust the power accordingly. Quote Link to post Share on other sites
david 929 Posted February 19, 2020 Author Share Posted February 19, 2020 2 hours ago, EskeRahn said: It is physics, not the motor... That is possible. If so, then we need a bigger motor. Or stack 2 or 3 of these on top of each other and drive them in parallel. I don't know if they are consistent enough in their resonant frequencies for that to work perfectly, but hopefully they would each be close enough to work. I am still thinking those pads between the motor and the case might be dampening the vibration too. I hate to mess with the hardware, but I am never going to know when the phone is receiving a phone call or when a message comes in when the phone is in my belt holster. They do make Bluetooth wrist bands with vibration devices on them and Android apps. I don't like the idea of wearing one on my wrist, but maybe they could be attached to a belt or holster or simply carried in a pocket. Quote Link to post Share on other sites
david 929 Posted February 20, 2020 Author Share Posted February 20, 2020 The other thing we need is something to replace the stickers with that cover the screws. Does anyone have any ideas for something that will be very similar to what came with the phone? Quote Link to post Share on other sites
EskeRahn 5,588 Posted February 20, 2020 Share Posted February 20, 2020 6 hours ago, david said: The other thing we need is something to replace the stickers with that cover the screws. Does anyone have any ideas for something that will be very similar to what came with the phone? e.g. these ? Quote Link to post Share on other sites
david 929 Posted February 20, 2020 Author Share Posted February 20, 2020 10 hours ago, EskeRahn said: e.g. these ? Have you tried them? Are they paper or more like a plastic material? The ones on the phone, from photos on here, seemed to be thicker. Oh, I just saw they mentioned vinyl in the description. Those sound promising. Quote Link to post Share on other sites
EskeRahn 5,588 Posted February 20, 2020 Share Posted February 20, 2020 1 minute ago, david said: Have you tried them? Are they paper or more like a plastic material? The ones on the phone, from photos on here, seemed to be thicker. Oh, I just saw they mentioned vinyl in the description. Those sound promising. Well this particular seller has only mentioned shipping to the UK as an option, so will have to ask the shipping price, or find them elsewhere. Quote Link to post Share on other sites
netman 1,424 Posted February 20, 2020 Share Posted February 20, 2020 (edited) 10 hours ago, EskeRahn said: e.g. these ? They say 5mm, the circle stickers we need are ~4mm. I was wrong! 5mm is correct. Edited February 20, 2020 by netman Quote Link to post Share on other sites
EskeRahn 5,588 Posted February 20, 2020 Share Posted February 20, 2020 3 minutes ago, netman said: They say 5mm, the circle stickers we need are ~4mm Are you sure? I haven't taken one out, but measuring it looks like 5mm in a 5.5mm hole. 1 Quote Link to post Share on other sites
david 929 Posted February 20, 2020 Author Share Posted February 20, 2020 (edited) 10 minutes ago, EskeRahn said: Well this particular seller has only mentioned shipping to the UK as an option, so will have to ask the shipping price, or find them elsewhere. I tried to buy on the USA ebay and they would not ship to my address. Not sure why they are listed there. I did find a different seller. They did not mention vinyl and did not allow picking color or finish, but I bought some. Edited February 20, 2020 by david Quote Link to post Share on other sites
netman 1,424 Posted February 20, 2020 Share Posted February 20, 2020 1 minute ago, EskeRahn said: Are you sure? I haven't taken one out, but measuring it looks like 5mm in a 5.5mm hole. I just re-measured and they are 5mm indeed. I had measured this earlier today and was fully confident but obviously I'm cross-eyed :-D. 3 Quote Link to post Share on other sites
silversolver 849 Posted February 20, 2020 Share Posted February 20, 2020 (edited) 1 minute ago, david said: They did not......allo Well clearly they're not French. :P Edited February 20, 2020 by silversolver 1 Quote Link to post Share on other sites
david 929 Posted February 20, 2020 Author Share Posted February 20, 2020 Just now, silversolver said: Well clearly they're not French. 😛 Fixed. Typed on the Pro1. 🙂 1 Quote Link to post Share on other sites
silversolver 849 Posted February 20, 2020 Share Posted February 20, 2020 Just now, david said: Fixed. Typed on the Pro1. 🙂 Just making translingual dad jokes. Not picking on you. :) 2 Quote Link to post Share on other sites
david 929 Posted February 20, 2020 Author Share Posted February 20, 2020 Ugh. I just noticed there are no black stickers in what I ordered. Lol 3 Quote Link to post Share on other sites
