Combat Wombat 11 Posted January 27, 2020 Share Posted January 27, 2020 Does the slider ever get easier to open like can you do it with one hand? Mine doesn't slide so much as a I have to use both hands to be able to lift the screen off the keyboard. It may be the most awkward keyboard phone I have ever used. Is there a double tap to wake option I have missed somewhere? Anyone found an option in the launcher to change to the "app tray" button instead of the slide gesture to get your full app list? Quote Link to post Share on other sites
Hook 3,368 Posted January 27, 2020 Share Posted January 27, 2020 1 Yes, the slider gets easier and you end up being able to do it one handed. There are discussions of this here including videos. 2. DDtW has been temporarily disabled to work out a bug. 3. Go to Settings, system,gestures and turn off Swipe up on home button. 1 3 Quote Link to post Share on other sites
Combat Wombat 11 Posted January 27, 2020 Author Share Posted January 27, 2020 1 minute ago, Hook said: 1 Yes, the slider gets easier and you end up being able to do it one handed. There are discussions of this here including videos. 2. DDtW has been temporarily disabled to work out a bug. 3. Go to Settings, system,gestures and turn off Swipe up on home button. Thank you Thank you That didn't do quite what I was looking for but its significantly better, Thank you 1 Quote Link to post Share on other sites
netman 1,424 Posted January 27, 2020 Share Posted January 27, 2020 I don't think my phone itself has changed at all at this, but for me opening it went from being quite a fiddle to something that just happens without thinking over time (approx a week or so). I can do it one-handed easily enough but since I type with both hands I often use both. I did also take some time to slowly open and close repeatedly figuring out what's the best approach for me. 1 Quote Link to post Share on other sites
david 929 Posted January 27, 2020 Share Posted January 27, 2020 19 minutes ago, Combat Wombat said: Anyone found an option in the launcher to change to the "app tray" button instead of the slide gesture to get your full app list? 7 minutes ago, Combat Wombat said: That didn't do quite what I was looking for but its significantly better, Thank you I haven't tried it, but you can try this: https://play.google.com/store/apps/details?id=com.sagrcasm.drawer Quote Link to post Share on other sites
Hook 3,368 Posted January 27, 2020 Share Posted January 27, 2020 16 minutes ago, Combat Wombat said: Thank you Thank you That didn't do quite what I was looking for but its significantly better, Thank you Sorry. I've used Nova Launcher for so long, I always forget the app drawer button is not part of Android. 2 Quote Link to post Share on other sites
Combat Wombat 11 Posted January 27, 2020 Author Share Posted January 27, 2020 4 minutes ago, Hook said: Sorry. I've used Nova Launcher for so long, I always forget the app drawer button is not part of Android. Not anymore at least haha going from 6 to 9 is a big jump for me in many ways 3 Quote Link to post Share on other sites
cube48 51 Posted January 27, 2020 Share Posted January 27, 2020 1 hour ago, Hook said: 3. Go to Settings, system,gestures and turn off Swipe up on home button. I wonder if there is a keyboard shortcut to get and stay on app switching view. Single Alt+Tap just switches to previous app, 'continuous' Alt+Tab cycles apps. Would be nice to get to app switching view with a key (or combo) and then scroll apps with arrow keys and selecting again with key. Quote Link to post Share on other sites
Craig 1,435 Posted January 28, 2020 Share Posted January 28, 2020 I've had mine a month and a half, I'm much better at it now, but still find it awkward and difficult. I can close it one handed no problem, but opening isn't something I try very often and I can do it, but haven't practiced that. I certainly never had an issue sliding my photon q, in fact cuz I had slide set to unlock automatically, even when I wanted to use in portrait I'd open/close the slider as I found that quicker. I can't see Pro¹ ever being that easy. 2 Quote Link to post Share on other sites
EskeRahn 5,604 Posted January 28, 2020 Share Posted January 28, 2020 31 minutes ago, Craig said: I've had mine a month and a half, I'm much better at it now, but still find it awkward and difficult. I can close it one handed no problem, but opening isn't something I try very often and I can do it, but haven't practiced that. I certainly never had an issue sliding my photon q, in fact cuz I had slide set to unlock automatically, even when I wanted to use in portrait I'd open/close the slider as I found that quicker. I can't see Pro¹ ever being that easy. The issue is that this strictly ISN'T a "slider". The screen flies like a Dolphin out of the water more than a boat sailing on the surface. And it is so incredible contra-intuitive that we shall NOT just push in a straight line along the keyboard. I remember people had exactly the same problems when Nokia had e.g. the N97. And the crazy thing is that once the fingers 'learnt it', you can not imagine how it was ever complicated. Like riding a bike. 3 1 Quote Link to post Share on other sites
david 929 Posted January 28, 2020 Share Posted January 28, 2020 I haven't played with my phone much yet, but between lifting at the top, pushing down and then up at the bottom, or lifting at the bottom, I find that lifting at the bottom is easiest. It does fly like a dolphin out of the water in more ways than one! (not just the down+up, but also fast and with power!) 1 Quote Link to post Share on other sites
