KingOfTerrible 69 Posted February 13, 2020 Share Posted February 13, 2020 Is this possible on the pro1? I don't see it anywhere in the settings. I have this functionality on my Priv and my Samsung tablet. It looks like pressing the power button or fingerprint would be the only ways currently? 1 Quote Link to post Share on other sites
Hook 3,345 Posted February 13, 2020 Share Posted February 13, 2020 19 minutes ago, KingOfTerrible said: Is this possible on the pro1? I don't see it anywhere in the settings. I have this functionality on my Priv and my Samsung tablet. It looks like pressing the power button or fingerprint would be the only ways currently? It has been disabled because of some problems it created. They are working on it. Don't know time scale, With the phone closed, yeah, power button or fingerprints. With FinQwerty (not to sound like a broken record) the Sym key will wake. I know the default keyboard started out with the Esc key being wake, but I'm not sure that didn't go away later. Been too long since I used the default layout so I'm fuzzy on some things. 2 Quote Link to post Share on other sites
Craig 1,435 Posted February 13, 2020 Share Posted February 13, 2020 Yeah Esc to wake on stock (and sailfish). 2 Quote Link to post Share on other sites
EskeRahn 5,602 Posted February 13, 2020 Share Posted February 13, 2020 4 hours ago, Hook said: With FinQwerty (not to sound like a broken record) the Sym key will wake. (...and to wake and turn keyboard-light on Alt+Sym) 2 Quote Link to post Share on other sites
Rasva 25 Posted December 1, 2022 Share Posted December 1, 2022 Is this supposed to work also on Pro1x? For me Esc, Sym, or Alt+Sym do not work. I have FinQwerty layout active. 1 Quote Link to post Share on other sites
EskeRahn 5,602 Posted December 2, 2022 Share Posted December 2, 2022 10 hours ago, Rasva said: Is this supposed to work also on Pro1x? For me Esc, Sym, or Alt+Sym do not work. I have FinQwerty layout active. (I see the same, so not just your settings) Quote Link to post Share on other sites
Craig 1,435 Posted December 2, 2022 Share Posted December 2, 2022 Wake on keypress not working on stock Pro¹-x for me either. Quote Link to post Share on other sites
david 929 Posted June 14, 2023 Share Posted June 14, 2023 On 12/1/2022 at 8:40 PM, Craig said: Wake on keypress not working on stock Pro¹-x for me either. I've been looking all over for how I made the esc key turn on the screen on my Pro1, because I wanted to do this on my Pro1X too. So the reality is the esc key turning on the screen was a built in feature for the Pro1, but went missing with the Pro1X? Has anyone found a way to do it? I'm guessing we'd need a way to map the Esc key to the same input provided by the Power button? 1 Quote Link to post Share on other sites
Tim6263 134 Posted July 5, 2023 Share Posted July 5, 2023 On 6/15/2023 at 12:24 AM, david said: Has anyone found a way to do it? What I've done is program MacroDroid with the 'Shake' trigger and an IF/ELSE clause. Now a slightly positive shake toggles the screen either On or Off, depending on it's current status. I had it waking based on the Prox.sensor previously but this needed two macros, & was definitely battery hungry. I'm hoping the 'Shake' trigger will be less of a power drain; I defo find it easier & more intuitive to use. 2 Quote Link to post Share on other sites
david 929 Posted July 6, 2023 Share Posted July 6, 2023 @Tim6263- Does macroDroid allow for key presses to be part of the trigger statement? If so, then the Esc key could be monitored and the screen turned on as the action. Quote Link to post Share on other sites
Tim6263 134 Posted July 6, 2023 Share Posted July 6, 2023 2 hours ago, david said: @Tim6263- Does macroDroid allow for key presses to be part of the trigger statement? I'm only a MacroDroid novice, but I don't think so, sorry. Quote Link to post Share on other sites
david 929 Posted July 6, 2023 Share Posted July 6, 2023 32 minutes ago, Tim6263 said: I'm only a MacroDroid novice, but I don't think so, sorry. Yeah, I installed it and tried to find a keypress action, but didn't see it. I then went online and found the author saying he won't support it. I then installed the Automate app. I did manage to get it to see the escape key press and turn on the screen.....but only when the screen was already on. It can't read keypresses when the screen is off. 😭 I also found out later that Automate apparently has the same conflict as Autoinput (reported by another user on the forums too), where it messes up the keyboard mapping. I has to uninstall Automate to get the keyboard mapping to work correctly again. You would think fxtec would have a checklist of all the features of the Pro1 and make sure they have all those things for the newer phone. 🤔😒 Quote Link to post Share on other sites
david 929 Posted July 6, 2023 Share Posted July 6, 2023 Oh, and I did play around with the shake gesture in Automate (haven't tried yet with MacroDroid). It didn't want to work reliably when the screen is off. It did state it would draw 0.125 amps to monitor for shake. That doesn't seem *too* bad, if that is what MacDroid would draw too. Quote Link to post Share on other sites
Tim6263 134 Posted July 7, 2023 Share Posted July 7, 2023 6 hours ago, david said: Oh, and I did play around with the shake gesture in Automate (haven't tried yet with MacroDroid). It didn't want to work reliably when the screen is off. It did state it would draw 0.125 amps to monitor for shake. That doesn't seem *too* bad, if that is what MacDroid would draw too. To get MacroDroid working when the screen is off, you need to find Trigger Options in Settings. I also increased Sensitivity to 4. I find it pretty reliable now. Quote Link to post Share on other sites
TeZtdevice 372 Posted July 7, 2023 Share Posted July 7, 2023 11 hours ago, david said: @Tim6263- Does macroDroid allow for key presses to be part of the trigger statement? If so, then the Esc key could be monitored and the screen turned on as the action. https://play.google.com/store/apps/details?id=io.github.sds100.keymapper&hl=de&gl=US 😉 Quote Link to post Share on other sites
Tim6263 134 Posted July 7, 2023 Share Posted July 7, 2023 (edited) 5 hours ago, TeZtdevice said: https://play.google.com/store/apps/details?id=io.github.sds100.keymapper&hl=de&gl=US 😉 indeed! I am using Key Mapper to 'correct' some of the seemingly incorrectly labelled keys, such as '?' '/' etc!! But I've no idea how to make this work with the screen off, let alone with the keyboard shut... But MacroDroid + Shake works fine for me. Edited July 7, 2023 by Tim6263 1 Quote Link to post Share on other sites
david 929 Posted July 8, 2023 Share Posted July 8, 2023 17 hours ago, Tim6263 said: indeed! I am using Key Mapper to 'correct' some of the seemingly incorrectly labelled keys, such as '?' '/' etc!! But I've no idea how to make this work with the screen off, let alone with the keyboard shut... But MacroDroid + Shake works fine for me. Does that mean Key Mapper doesn't work with the screen off? Quote Link to post Share on other sites
Tim6263 134 Posted July 9, 2023 Share Posted July 9, 2023 Not so far as I can tell... Quote Link to post Share on other sites
TeZtdevice 372 Posted July 10, 2023 Share Posted July 10, 2023 On 7/8/2023 at 8:23 AM, david said: Does that mean Key Mapper doesn't work with the screen off? I can turn on and off the screen with KeyMapper Quote Link to post Share on other sites
