Slion 1,201 Posted August 6, 2020 Share Posted August 6, 2020 (edited) First time on the road with my Pro1. Woke up at five this morning. Spent more than 6 hours on trains going to Paris from Germany. At 10 in the evening battery was still at 60%. Tips: Keep battery saving mode on at all times. Turn off auto-sync. Edited August 7, 2020 by Slion 3 Quote Link to post Share on other sites
jjarmasz 81 Posted August 6, 2020 Share Posted August 6, 2020 I forgot to take my charger with me a few months ago (in The Before Times) on an overnight trip. Put my Pro1 on battery saver mode and made it through until I got home, probably close to 40 hrs round trip door-to-door (gotta say it was pretty low when I got in the door... but it was still on!) 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 7, 2020 Author Share Posted August 7, 2020 3 hours ago, jjarmasz said: 40 hrs round trip door-to-door (gotta say it was pretty low when I got in the door... but it was still on!) That indeed matches my experience. Doing linear interpolation it should go from 100% to zero in 42 hours. Quote Link to post Share on other sites
FlyingAntero 871 Posted August 7, 2020 Share Posted August 7, 2020 I can get 6h SOT without battery saver for 1 day. I posted a battery graph to other thread earlier. Do we need two separate threads for battery talk? 1 Quote Link to post Share on other sites
EskeRahn 5,592 Posted August 7, 2020 Share Posted August 7, 2020 You might consider LineageOS, the 0803 has an idle consumption around roughly 1% per hour But stock is only slightly worse (see the right most part of this over night) ADD: Oh forgot to mention I have NOT turned the Battery saver on.... (don't let the "51%" fool you, I had the phone plugged in between the screenshots a few minutes apart, it was down at 35% an hour ago as the graph tells.) 1 Quote Link to post Share on other sites
tdm 2,322 Posted August 7, 2020 Share Posted August 7, 2020 9 hours ago, EskeRahn said: You might consider LineageOS, the 0803 has an idle consumption around roughly 1% per hour That works out to an average of about 32mA draw. I would expect around half of that for a well behaved device mostly sleeping. Indeed, I just checked my device and it is 91% after 17 hours of sitting. So that is pretty close to ideal. I have not turned on battery saver either. The ROM you are running should not have an appreciable (or any) impact on the battery draw when sleeping. It mostly affects power vs. performance while in use. 1 1 Quote Link to post Share on other sites
agent008 248 Posted August 9, 2020 Share Posted August 9, 2020 On 8/7/2020 at 3:53 AM, EskeRahn said: May I ask how to make such a chart? Is this from settings, or a specific app? 1 Quote Link to post Share on other sites
EskeRahn 5,592 Posted August 9, 2020 Share Posted August 9, 2020 13 hours ago, agent008 said: May I ask how to make such a chart? Is this from settings, or a specific app? 3C Battery Manager, also part of 3C all-in-one tool. Also see some hints on this here 2 Quote Link to post Share on other sites
agent008 248 Posted August 10, 2020 Share Posted August 10, 2020 15 hours ago, EskeRahn said: 3C Battery Manager Tks, do you use the paid version? I can see it looks a bit different from what I got. And it pulled a music ad on me right in the middle of the office, audio volume was on max. Got a few funny looks 😆 1 Quote Link to post Share on other sites
EskeRahn 5,592 Posted August 10, 2020 Share Posted August 10, 2020 20 minutes ago, agent008 said: Tks, do you use the paid version? I can see it looks a bit different from what I got. And it pulled a music ad on me right in the middle of the office, audio volume was on max. Got a few funny looks 😆 Using the paid version of the full all-in-one toolbox. But please note the granted permission (see hints in the link above), and the markers for plug etc are optional but default not on. 1 Quote Link to post Share on other sites
