CornholioGSM 370 Posted August 8, 2020 Share Posted August 8, 2020 (edited) I have special question. Can anyone take a look and made AospExtended rom? Lineage Os is not bad, but have missing some for me important functions. For example is not possible to fully edit and add navigation keys. What i need is menu-home(recents)-back-search...as on my old phones. This modification was possible on older LOS versions...but from 16 isnt 😞 Another what will be good to change is recents menu layout back to oreo style. This all can be changed in AEX rom. OR...will be possible to put these extensions into LOS? thx 🙂 Edited August 23, 2020 by CornholioGSM 2 1 Quote Link to post Share on other sites
tdm 2,322 Posted August 9, 2020 Share Posted August 9, 2020 Are they lineage compatible? If so, it shouldn't be hard to build. Also aokp should have those features. I'll be making pro1 official for aokp soon. 2 3 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 9, 2020 Author Share Posted August 9, 2020 i dont know if is it los compatible 😞 Navigation bar is "Smartbar" madded by dirty unicorns devs i mean. Here is how it looks on my second phone now Quote Link to post Share on other sites
tdm 2,322 Posted August 9, 2020 Share Posted August 9, 2020 Looks like both AospExtended and AICP have Lineage compatible device trees. So I can look into building those. 2 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 10, 2020 Author Share Posted August 10, 2020 wau...you are best 🙂 Maybe will be possible to made only recovery installable zip...it will be goooooood 🙂 Quote Link to post Share on other sites
tdm 2,322 Posted August 10, 2020 Share Posted August 10, 2020 Well that was fast. I'm in the AEX dev group already. 😁 4 1 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 10, 2020 Author Share Posted August 10, 2020 BTW...i am not sure if all of these functions are on android 10 based AEX...i was on android 9 AEX version 6.5 i mean Quote Link to post Share on other sites
agent008 248 Posted August 10, 2020 Share Posted August 10, 2020 On 8/9/2020 at 8:08 AM, CornholioGSM said: Now this was a trip down memory lane for me. Such a long time I didn't see this UI design on a phone! Quote Link to post Share on other sites
CornholioGSM 370 Posted August 10, 2020 Author Share Posted August 10, 2020 maybe it looks old but it is very practic. all navkeys are editable for layout, long press and double tab. Quote Link to post Share on other sites
TeZtdevice 368 Posted August 10, 2020 Share Posted August 10, 2020 (edited) 3 hours ago, CornholioGSM said: maybe it looks old but it is very practic. No, absolutely not! My favourite app was Softkeyz and SoftkeysFadeMod (still works, if you kill the systemUI after every start. I do this with a tasker shortcut) In the last week I played a lot, to change the keys, but no app can do this like Softkeyz. The current best solution for me is: Gravitybox Edited August 10, 2020 by TeZtdevice Quote Link to post Share on other sites
tdm 2,322 Posted August 10, 2020 Share Posted August 10, 2020 Got AICP built but it's not booting properly. Need to investigate, but not right now. I'll try building AEX next. 2 2 Quote Link to post Share on other sites
tdm 2,322 Posted August 10, 2020 Share Posted August 10, 2020 And I'm now an AICP dev also. w00t! 😄 1 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 10, 2020 Share Posted August 10, 2020 37 minutes ago, tdm said: And I'm now an AICP dev also. w00t! 😄 ....I can not help the feeling that you might have put more time into developing software for the Pro1 since autumn than Idealte.... 6 Quote Link to post Share on other sites
tdm 2,322 Posted August 10, 2020 Share Posted August 10, 2020 13 minutes ago, EskeRahn said: ....I can not help the feeling that you might have put more time into developing software for the Pro1 since autumn than Idealte.... I needed a new personal ROM to run anyway. AOKP has been dead for some time, unfortunately. AICP seems to be the closest match out there. 3 Quote Link to post Share on other sites
tdm 2,322 Posted August 11, 2020 Share Posted August 11, 2020 Looks like AICP and AOSPX both have the same FBE decrypt issue. I imagine that once I get this solved, both will boot and run fine. 4 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 11, 2020 Author Share Posted August 11, 2020 yes yes yessss....make it upload it !!! 🙂 1 Quote Link to post Share on other sites
tdm 2,322 Posted August 12, 2020 Share Posted August 12, 2020 (edited) Okay got AEX working... please test and I'll toss up a thread later. http://ota.nwwn.com/roms/aex/9.0/pro1/aosp_pro1-ota-9-test1.zip EDIT: If you need a recovery to flash this with, my latest Lineage test recovery should work... http://files.nwwn.com/android/pro1/lineage-16.0-pro1-test22-boot.img Edited August 12, 2020 by tdm 8 Quote Link to post Share on other sites
tdm 2,322 Posted August 12, 2020 Share Posted August 12, 2020 And here's AICP... http://ota.nwwn.com/roms/aicp/9.0/pro1/aicp_pro1-ota-9.0-test1.zip 6 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 12, 2020 Author Share Posted August 12, 2020 1 hour ago, tdm said: Okay got AEX working... please test and I'll toss up a thread later. http://ota.nwwn.com/roms/aex/9.0/pro1/aosp_pro1-ota-9-test1.zip EDIT: If you need a recovery to flash this with, my latest Lineage test recovery should work... http://files.nwwn.com/android/pro1/lineage-16.0-pro1-test22-boot.img oki superr i will test it within few hours 🙂 thankssss Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 12, 2020 Share Posted August 12, 2020 55 minutes ago, CornholioGSM said: oki superr i will test it within few hours 🙂 thankssss @tdm are providing builds faster than you can test them 🤣 3 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 13, 2020 Author Share Posted August 13, 2020 (edited) Soo installed and booted...but i have madded something wrong becase i dont have gapps ...maybe bad switched slot 🙂 Edited August 13, 2020 by CornholioGSM Quote Link to post Share on other sites
tdm 2,322 Posted August 13, 2020 Share Posted August 13, 2020 19 minutes ago, CornholioGSM said: Soo installed and booted...but i have madded something wrong becase i dont have gapps ...maybe bad switched slot 🙂 That is easy to fix, just boot into recovery, flash gapps, wipe, and go again. 1 1 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 13, 2020 Author Share Posted August 13, 2020 (edited) I must say that i HATE this A\B slot thing...i have flashed and installed hundreds phones and this is always little problematic. Soo all is installed . After first boot i got some apps fc's...but after some reboots all works fine (it looks) 🙂 How about root? flash supersu magisk or... ? EDIT...maybe something is different set on hwkb?...because sometime make button long press EDIT2...maybe more battery drain compare to LOS...but i need few days for more tests EDIT3...after test to play some wav sounds (for test to set it for notifications) whole sound on fx starts to be cracking and ugly....after reboot again fine Edited August 14, 2020 by CornholioGSM Quote Link to post Share on other sites
CornholioGSM 370 Posted August 23, 2020 Author Share Posted August 23, 2020 (edited) So i am now 10 days on AEX....stable as los, no reboots, no freezing...all fine i must say 🙂 Only missing is root....and i am missing TWRP 😞 Edited August 23, 2020 by CornholioGSM 3 Quote Link to post Share on other sites
CornholioGSM 370 Posted March 1, 2021 Author Share Posted March 1, 2021 hello hello @tdm ...will be possible to made new version if AOSPextended rom? i am on a9 based for approx half year and it is really best rom and is best customisable 🙂 Quote Link to post Share on other sites
