VaZso 1,999 Posted September 28, 2020 Share Posted September 28, 2020 35 minutes ago, archseraphim said: Does the version on aliexpress with frame also work with the pro1? If so that would eliminate the need for that step. They are different. I have also bought an Elephone display with frame by mistake which I had to remove the display from. It was full metal anyway but Pro1's frame is at least mostly plastic (I don't know if any metal at the outside of display frame or not, but other parts are plastic). Also, Elephone is a one-piece hardware and its display frame also includes USB connector cutout and also otherwise different from Pro1's frame. 1 Quote Link to post Share on other sites
Slion 1,201 Posted September 28, 2020 Share Posted September 28, 2020 6 hours ago, archseraphim said: Aside from that it all went very smoothly. New display is indistinguishable from my original as far as I can tell. How did you glue it back together? Quote Link to post Share on other sites
internationaltraitor 84 Posted September 29, 2020 Share Posted September 29, 2020 2 hours ago, Slion said: How did you glue it back together? well, based on whats included, in the lower right hand side of the picture, there's some tape, adhesive. not sure what he used though... or what kind of glue FxTec used... would be nice a more quality glue. 1 Quote Link to post Share on other sites
Slion 1,201 Posted September 29, 2020 Share Posted September 29, 2020 2 hours ago, internationaltraitor said: well, based on whats included, in the lower right hand side of the picture, there's some tape, adhesive. not sure what he used though... or what kind of glue FxTec used... would be nice a more quality glue. Yes I have the same kit and I was wondering if the tape provided was good enough. Having some tips on how to apply it would be great too. Quote Link to post Share on other sites
internationaltraitor 84 Posted September 30, 2020 Share Posted September 30, 2020 23 hours ago, Slion said: Yes I have the same kit and I was wondering if the tape provided was good enough. Having some tips on how to apply it would be great too. yes, i am also interested if there is some type of high quality glue that maybe, some repair technicians can recommend? and tips are greatly appreciated,, since there was one guy who explicitly stated there is no need for a heat gun , and now he's saying he definitely needed a heat gun. am very interested since i have to change my cracked screen... its not so bad,, maybe waiting until its fully cracked lol.😁 1 Quote Link to post Share on other sites
archseraphim 50 Posted October 5, 2020 Author Share Posted October 5, 2020 I used the included two sided tape from the kit. It's been holding just fine. I don't have any real tips for applying it beyond "be careful". 2 Quote Link to post Share on other sites
EvilDragon 164 Posted October 8, 2020 Share Posted October 8, 2020 I will also have replacement screens in my shop including a replacement service soon. Also, if you use a case which covers the screen (I can take some pictures of it), then the screen is perfectly safe. Cracked mine a few times before I got the case, after that, it never happened again. 6 Quote Link to post Share on other sites
VaZso 1,999 Posted October 8, 2020 Share Posted October 8, 2020 7 minutes ago, EvilDragon said: I will also have replacement screens in my shop including a replacement service soon. Also, if you use a case which covers the screen (I can take some pictures of it), then the screen is perfectly safe. Cracked mine a few times before I got the case, after that, it never happened again. What will be the source of the displays you will sell? Will it be the same as F(x)tec source (directly from BOA if I write their name correctly) or another company or reseller? Will you sell these displays separately? If so, will you have a chance for testing these displays? What I have ordered at Aliexpress works perfectly but it has missing pixels at one of the corners (it bites out of the display at one of the corners a similar curve what the corners look like but in a mirrored shape). Could you write me an approximate selling price of it (if you have an idea of now)? Do I understand well you have cracked your screen a few times before you found a case for it? If you have a case, could you share a photo of it? May you sell a case for Pro1 later? Sorry for these questions, I am curious. 1 1 Quote Link to post Share on other sites
silversolver 849 Posted October 9, 2020 Share Posted October 9, 2020 5 hours ago, EvilDragon said: I will also have replacement screens in my shop including a replacement service soon. Also, if you use a case which covers the screen (I can take some pictures of it), then the screen is perfectly safe. Cracked mine a few times before I got the case, after that, it never happened again. In what country is your business located? Were you the guy who rescued a device that someone bricked and returned? Quote Link to post Share on other sites
EvilDragon 164 Posted October 9, 2020 Share Posted October 9, 2020 7 hours ago, silversolver said: In what country is your business located? Were you the guy who rescued a device that someone bricked and returned? We're based in Germany. And yes, that unbricking was me (with help from tdm :)) 3 Quote Link to post Share on other sites
Slion 1,201 Posted October 9, 2020 Share Posted October 9, 2020 12 hours ago, EvilDragon said: I will also have replacement screens in my shop including a replacement service soon. Where is your shop? Quote Link to post Share on other sites
TeZtdevice 365 Posted October 9, 2020 Share Posted October 9, 2020 4 minutes ago, Slion said: Where is your shop? Ingolstadt 2 Quote Link to post Share on other sites
