EskeRahn 5,596 Posted September 3, 2022 Author Share Posted September 3, 2022 1 hour ago, dreamflasher said: @EskeRahn What's your experience with AICP on the Pro1? How does it compare to LOS in terms of stability (and features)? Well AICP-R seemed fine, but AICP-S is a bit early. But that apart it is roughly an LOS with a bunch of extra 'options' . I can not really fairly talk on the stability, as I'm not using neither Lineage nor AICP as a daily driver, but for tests only, 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 3, 2022 Author Share Posted September 3, 2022 2 hours ago, dreamflasher said: @EskeRahn What's your experience with AICP on the Pro1? How does it compare to LOS in terms of stability (and features)? PS Be aware that AICP-R is soon gone, so hurry up and download!! See this Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 7, 2022 Author Share Posted September 7, 2022 Flashed aicp_pro1_s-17.1-WEEKLY-20220907.zip on security update 2022-03-05 Seems much the same. Still initial boot-loop after flash, But that aside things seem to work. Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 19, 2022 Author Share Posted September 19, 2022 Flashed aicp_pro1_s-17.1-WEEKLY-20220914.zip on security update 2022-03-05 Seems much the same. Still initial boot-loop after flash, But that aside things seem to work. Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 20, 2022 Author Share Posted September 20, 2022 I must admit that I'm very close to giving up on AICP-S, since no one seems to be working on fixing the basic issues that has been there for over two months of initial release, and security updates over half a year old. So maybe I should look at sailfish instead.... 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 20, 2022 Author Share Posted September 20, 2022 Be aware that AICP-R is gone within about a week, so hurry up and download!! See this Quote Link to post Share on other sites
Hook 3,301 Posted September 20, 2022 Share Posted September 20, 2022 4 hours ago, EskeRahn said: I must admit that I'm very close to giving up on AICP-S, since no one seems to be working on fixing the basic issues that has been there for over two months of initial release, and security updates over half a year old. So maybe I should look at sailfish instead.... Yeah, much as I loved AICP, I'm just not going to trust and depend on it for those very reasons. Having only 1 pro1, I'm staying with Lineage 19 as my daily driver. Once I have my Pro1x, my Pro 1 will become my experimental device to try Droidian, Sailfish, no google Lineage, etc. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 21, 2022 Author Share Posted September 21, 2022 Flashed aicp_pro1_s-17.1-WEEKLY-20220921.zip on security update 2022-03-05 Now I'm completely confused. Still initial boot-loop after flash, But despite the outer file signals aicp-S and 17.1, the inner version is aicp 16.1 and tells it is Android 11???(I downloaded again, did a binary compare, and a re-flash - just to be sure, but....) 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 28, 2022 Author Share Posted September 28, 2022 Flashed aicp_pro1_s-17.1-WEEKLY-20220928.zip on security update 2022-03-05 Still initial boot-loop after flash, And still completely confused! Despite the outer file signals aicp-S and 17.1, the inner version is aicp 16.1 and tells it is Android 11??? Quote Link to post Share on other sites
Hook 3,301 Posted September 28, 2022 Share Posted September 28, 2022 I suspect no one at AICP is using a Pro1 anymore and these are just automated updates with no actual updating being done. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 28, 2022 Author Share Posted September 28, 2022 1 hour ago, Hook said: I suspect no one at AICP is using a Pro1 anymore and these are just automated updates with no actual updating being done. Exactly, it does not make any sense, and R falls out the bottom next Wednesday, So no more AICP to us.... 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted October 6, 2022 Author Share Posted October 6, 2022 Flashed aicp_pro1_s-17.1-WEEKLY-20221005.zip on security update 2022-03-05 Still initial boot-loop after flash, And still completely confused! Despite the outer file signals aicp-S and 17.1, the inner version is aicp 16.1 and tells it is Android 11???So time to give up on AICP on Pro1 I guess!!! ...when I find the time this test-device will likely get Sailfish again... 1 Quote Link to post Share on other sites
Hook 3,301 Posted October 6, 2022 Share Posted October 6, 2022 Thanks for hanging in there so long. Very disappointing, but Lineage 19 is okay, just underfeatured. 😉 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted October 6, 2022 Author Share Posted October 6, 2022 4 minutes ago, Hook said: Thanks for hanging in there so long. Very disappointing, but Lineage 19 is okay, just underfeatured. 😉 Yup, got LOS 19 on the pre-production unit, and it is not bad at all.. Quote Link to post Share on other sites
fedup 1 Posted October 15, 2022 Share Posted October 15, 2022 On 8/10/2022 at 4:55 PM, EskeRahn said: AICP-S 17.1 for Pro1 New version of AICP-S 17.1 based on Android 12 is available for download here: https://dwnld.aicp-rom.com/ aicp_pro1_s-17.1-WEEKLY-20220810.zip It is VERY important that you do NOT take the boot-image used for the (also android 12 based) Lineage 19.1 as I did. I had a LOT of trouble first as can be seen in this thread. You can use the SAME boot image for AICP-S as for the previous AICP-R!!!! I use one from LineageOS from last year lineage_18.1-20210913-recovery-pro1.img . Others might work too (But the LOS 19.1 does NOT!) The only working Gapps package for android 12 based I know of is MindTheGapps (see this it is a bit 'fat', so hope that OpenGapps will make for 12 too. Their Pico is more than enough to me. Currently using: MindTheGapps-12.1.0-arm64-20220605_112439.zip Make sure to backup everything, as you are likely to need a factory reset for the first time installing AICP-S Once you got the files needed follow the usual procedure for flashing a Boot-image and a zip (see e.g this) Notice that when you reboot after flashing, it seems to go into a boot loop, but not so!! On the seventh boot(!!) after some 2-3 minutes it will actually launch AICP-S. If you are upgrading from AICP-R and (like I did) used the more lean Gapps package OpenGapps, it will request you to do a factory reset wiping everything. If you are NOT using Gapps there is a chance that a pure Gapps-free AICP-R can upgrade gracefully to AICP-S. It might even work if you used MindTheGapps for Android 11 with AICP-R. I have not tested either, but if anyone has and it works, please tell below, and I will update. Upgrading one AICP-S with MindTheGapps to a newer with same MindTheGapps works fine though 🙂 Any chance of installing AIX on it? Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 23, 2022 Author Share Posted November 23, 2022 There have been no new AICP updates in three weeks, and as I have not have found the time to install something else on the unit, I fetched and installed 20221123. Same issues as earlier. (including still reverted to Android 11) Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 2, 2023 Author Share Posted January 2, 2023 as I have not have found the time to install something else on the unit, I fetched and installed 20221228. Same issues as earlier. (including still reverted to Android 11) 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 23, 2023 Author Share Posted January 23, 2023 as I have not have found the time to install something else on the unit, I fetched and installed 20230118. Same issues as earlier. (including finite boot loop, still reverted to Android 11, and despite changelog claims otherwise still old security stamp) Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 27, 2023 Author Share Posted February 27, 2023 On 1/23/2023 at 3:43 PM, EskeRahn said: as I have not have found the time to install something else on the unit, I fetched and installed 20230118. Same issues as earlier. (including finite boot loop, still reverted to Android 11, and despite changelog claims otherwise still old security stamp) "2023022", same..... 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted March 29, 2023 Author Share Posted March 29, 2023 "20230322" A lot of changes in their change-log, so optimistically tried again ..... Same as usual. So got a crazy idea. What would happen if I flashed the same image to BOTH slot A and B, wiped the user-data, and booted?? After the usual 8 x 30s boot-loop, it continues to boot another eight time, and ends back at the at the boot-loader. So what I has seen as wrong package content really most likely was the backup image!! I was never able to actually boot the image after the change they made after a few S-upgrades! So most likely I really need to extract the boot-image from the aicp-package, to get one working. It seems like I need to infect a pc/phone with 'pew' to do that, I'm not quite sure that will ever happen... I've seen various tools with .py code, but none .net based - i would have preferred that. (Before committing this, a 20230329 has become available with few mods only) Quote Link to post Share on other sites
claude0001 1,422 Posted March 29, 2023 Share Posted March 29, 2023 (edited) 13 hours ago, EskeRahn said: It seems like I need to infect a pc/phone with 'pew' to do that Your aversion to python is obviously still going strong. 😄 Can't really understand why, but then, I'm into scientific computing where there has hardly been a way around that language for 15 years or so ... That being said, there are standalone payload extractors, like this one or that one. I haven't tested them though, as I have a lineage build environment anyway, which includes the official 'extract.py' tool. Edited March 29, 2023 by claude0001 1 Quote Link to post Share on other sites
Adrienspawn 126 Posted April 2, 2023 Share Posted April 2, 2023 Still on 16.1 pending more recent alternative.... Quote Link to post Share on other sites
EskeRahn 5,596 Posted April 2, 2023 Author Share Posted April 2, 2023 2 hours ago, Adrienspawn said: Still on 16.1 pending more recent alternative.... Well if you fiddle extracting the boot image from the newest S image, as e.g. claude0001 suggests, I guess it is likely that it will work with that as boot-loader. Quote Link to post Share on other sites
EskeRahn 5,596 Posted April 5, 2023 Author Share Posted April 5, 2023 OK, I tried TLDR: Waste of time, AICP-S is BROKEN for Pro1!!! I gave AICP a final chance by infesting a windows-pc with Phewton (it was already infested with GIT) and extracted the boot.img from the zip. Following this guide https://wiki.lineageos.org/extracting_blobs_from_zips#extracting-proprietary-blobs-from-payload-based-otas (adjusted as needed...) Infested a PC with Python,https://www.python.org/ Downloads Download for Windows, Python 3.11.2 Found pip.exe and installed packages needed C:\Users\Administrator\AppData\Local\Programs\Python\Python311\Scripts\pip install protobuf C:\Users\Administrator\AppData\Local\Programs\Python\Python311\Scripts\pip install six (the second will be missing later in step 9 if not installed) I already had the PC infested with GIT, if you have not you will need to install that as well Clone repository C:\git\lin>git clone https://github.com/LineageOS/scripts.git Download the zip fromhttps://dwnld.aicp-rom.com/ (selecting FxTec and picked latest) Extracted Payload.bin from zip, and put it in C:\git\lin\scripts\update-payload-extractor, (where extract.py is) CD C:\git\lin\scripts\update-payload-extractor Made a workdir WRK Set PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION=python It will complain in step 9 if not set Found python.exe and ran C:\Users\Administrator\AppData\Local\Programs\Python\Python311\python.exe extract.py payload.bin --output_dir WRK renamed WRK\boot.img to something suitable and moved it to the PC used for flashing, and tried to use this flashed to boot_a, the usual way, including a factory reset. ...Did not work, after bootloop it ended in the bootloader again. Tried to flash the boot image to BOTH boot_a and boot_b, and retried (without gapps) - still no luck, same as above. So installed Lineage, and gave up on AICP-S as completely broken for Pro1!!!! But YES it is technically possible to extract the boot-image from a zip, but it is a lot of tedious steps to do so - slightly less if you already got Phewton obviously.That it was all in vain did not help my mood on the whole thing.... 1 Quote Link to post Share on other sites
claude0001 1,422 Posted April 5, 2023 Share Posted April 5, 2023 (edited) 2 hours ago, EskeRahn said: But YES it is technically possible to extract the boot-image from a zip, but it is a lot of tedious steps to do so - slightly less if you already got Phewton obviously.That it was all in vain did not help my mood on the whole thing.... 😄 ... as I already hinted above, you could have avoided python and git -- and thus most of those tedious steps -- by using one of the standalone extractor tools I linked to above: On 3/29/2023 at 11:46 AM, claude0001 said: That being said, there are standalone payload extractors, like this one or that one. I just tested payload-dumper-go. It works well and has no dependencies whatsoever. Edited April 5, 2023 by claude0001 1 Quote Link to post Share on other sites
