TeZtdevice 365 Posted January 2, 2025 Share Posted January 2, 2025 (edited) Official Release: https://download.lineageos.org/devices/pro1x/builds Changelog: https://download.lineageos.org/devices/pro1x/changes First Build: LINEAGE-22.1-20250101-NIGHTLY-PRO1X-SIGNED.ZIP How-To upgrade v.21 to v.22.1: https://wiki.lineageos.org/devices/pro1x/upgrade/ Gapps (ARM64!) https://wiki.lineageos.org/gapps/ Edited March 16, 2025 by TeZtdevice Next update is LineageOS 22.2 2 3 Quote Link to post Share on other sites
Hook 3,293 Posted January 3, 2025 Share Posted January 3, 2025 Lineage-22.1-20250101-NIGHTLY-pro1x with December 5th security patch installed smoothly. MindTheGapps15 was installed, and root was applied using Magisk 28,1 flashed as a zip file. Had to do the usual first time opening the Magisk App to download an update and create it's own modified boot thing. I did this using the update instructions for the first time. It worked beautifully, leaving all of my data intact. You are essentially doing an OTA update, except you have to do the update manually. The instructions are very clear and it's so nice not to have to rebuild the phone after a major version update. As always, although a Windows user most of the time, I used a Linux laptop (Manjaro) to do this stuff. So far, everything is working. Will advise if I find anything that isn't. 3 Quote Link to post Share on other sites
MrPib 33 Posted January 5, 2025 Share Posted January 5, 2025 Thanks, Hook. Worked perfectly for me. I used my Raspberry Pi4, as always, for adb. Windows is too finicky. The update instructions don't have the Gapps link, so: https://wiki.lineageos.org/gapps/ Use the ARM64 version for LOS 22.1. 1 1 Quote Link to post Share on other sites
Hook 3,293 Posted January 5, 2025 Share Posted January 5, 2025 32 minutes ago, MrPib said: Thanks, Hook. Worked perfectly for me. I used my Raspberry Pi4, as always, for adb. Windows is too finicky. The update instructions don't have the Gapps link, so: https://wiki.lineageos.org/gapps/ Use the ARM64 version for LOS 22.1. Actually the link is there but easy to miss... the single word "now" is the link. I'm sure others will miss it so thanks for providing the link here. 2 Quote Link to post Share on other sites
MrPib 33 Posted January 5, 2025 Share Posted January 5, 2025 You are correct, SIr. Even mentions the ARM64 version. Quote Link to post Share on other sites
Hook 3,293 Posted January 6, 2025 Share Posted January 6, 2025 Lineage-22.1-20250106-NIGHTLY-pro1x with December 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
--- 129 Posted January 10, 2025 Share Posted January 10, 2025 Is the 'debounce' a new feature to LOS22, or have I been missing out all this time? 2 Quote Link to post Share on other sites
Hook 3,293 Posted January 10, 2025 Share Posted January 10, 2025 I don't know, but it caught my attention too, which makes me guess it wasn't there before. 2 Quote Link to post Share on other sites
--- 129 Posted January 10, 2025 Share Posted January 10, 2025 Just a minor point, but I think 500msec is a bit too long, at least for the likes of the cursor keys and the backspace keys, but still a massive improvement overall. Only the other day someone mentioned keyboard deterioration over time, and mine has been getting noticeable on certain keys, and this practically cures it. Super. 🙂 2 Quote Link to post Share on other sites
EskeRahn 5,593 Posted January 10, 2025 Share Posted January 10, 2025 Half a second is a very long time for any real intended double strokes for normal users. it would be a daily nuisance for most users. It is placed under accessibility for a reason, it is intended for those with some neural issues affecting their finger control.The default is off, so could well have been there before, but I have not noticed it either. Could be new 1 Quote Link to post Share on other sites
--- 129 Posted January 10, 2025 Share Posted January 10, 2025 (edited) 3 hours ago, EskeRahn said: It is placed under accessibility for a reason I see, I hadn't thought of that, or noticed it was under the accessibility section. I was thinking like an Engineer. @Hook @EskeRahn None of us recalls seeing it before though, so still a new feature so it seems. 3 hours ago, EskeRahn said: The default is off On my PrawnX it was active after the LOS22 upgrade. I noticed the behaviour before I found the setting. p.s. The upgrade went smoothly following the instructions. Edited January 10, 2025 by MonCon Quote Link to post Share on other sites
EskeRahn 5,593 Posted January 11, 2025 Share Posted January 11, 2025 Interesting it was OFF at my Pro1 (note not Pro1X) after upgrade - surprising difference. Quote Link to post Share on other sites
Hook 3,293 Posted January 13, 2025 Share Posted January 13, 2025 Lineage-22.1-20250113-NIGHTLY-pro1x with January 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,293 Posted January 20, 2025 Share Posted January 20, 2025 Lineage-22.1-20250120-NIGHTLY-pro1x with January 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 2 Quote Link to post Share on other sites
Hook 3,293 Posted January 28, 2025 Share Posted January 28, 2025 Lineage-22.1-20250127-NIGHTLY-pro1x with January 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Name_not_avail 71 Posted February 1, 2025 Share Posted February 1, 2025 (edited) I just did the January 27 OTA on my first pro1x, and root was NOT maintained. This is the first time I tried an OTA after the manual installation of this version of LOS. I had followed the normal Magisk install instructions in the app, instead of initially sideloading the patched boot file or whatever deprecated method it was that I had done to initially root the last version of LOS. Now I forget exactly what secret sauce it was, but it was the only thing preserving root with OTA for me in the last version of LOS. I remember Hook rubbished me for it as being unnecessary when I posted about it in the last Official LOS thread, but clearly it was not unnecessary in some cases, like mine. For updating my second pro1x, not wanting to go through all the Magisk adb jazz again to re-root after OTA, I followed the instructions on a reddit thread, "How to update OTA and keep root!" Essentially you start the OTA process, but do NOT hit "reboot" when prompted at the end. Instead, start the Magisk app, hit "install", then "install to inactive slot". Then go back to the OTA "reboot?" prompt and go ahead and reboot. Root will be preserved on reboot. It worked great on my second pro1x. I will be doing this for every OTA on these boat anchors in future, as my standard operating procedure to avoid the chance of the tedious Magisk re-root. Pretty easy insurance to avoid root preservation problems in future. Edited February 1, 2025 by Name_not_avail 1 Quote Link to post Share on other sites
Hook 3,293 Posted February 1, 2025 Share Posted February 1, 2025 I doubt I "rubbished" you as that is generally not my style. All I see in that thread is us kind of agreeing on what works. Lol. Basically, what works for me (and I can only vouch for me) is that I side load Magisk as a zip when I first install a full version of LOS, then open the app and let it do the automatic install which takes care of the whole patching the boot sector. After that, OTA always maintains root. But as long as you have found a method that works for you, that's great. 1 Quote Link to post Share on other sites
Name_not_avail 71 Posted February 1, 2025 Share Posted February 1, 2025 Rubbished may be overstating it, I don't recall exactly. And it sounds like you and I installed Magisk differently. I installed the apk normally on the phone like any other app, then downloaded the boot image corresponding to the current version of LOS, then had the Magisk app patch that boot image, then used a PC with adb to fastboot flash the patched image back to the pro1x. If anyone else here did Magisk that way, then to preserve root with OTA updates of LOS, I recommend doing the "interrupted OTA and install to inactive slot" trick that I mentioned above. It saves a bunch of hassle. 1 Quote Link to post Share on other sites
Hook 3,293 Posted February 3, 2025 Share Posted February 3, 2025 Lineage-22.1-20250203-NIGHTLY-pro1x with January 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Benni 192 Posted February 3, 2025 Share Posted February 3, 2025 I suspect, you don't need to go the Magisk App OTA path for every update once you have Magisk in both slots, but I still always to it. Quote Link to post Share on other sites
Hook 3,293 Posted February 10, 2025 Share Posted February 10, 2025 Lineage-22.1-20250210-NIGHTLY-pro1x with February 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,293 Posted February 17, 2025 Share Posted February 17, 2025 Lineage-22.1-20250217-NIGHTLY-pro1x with February 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,293 Posted February 25, 2025 Share Posted February 25, 2025 Lineage-22.1-20250224-NIGHTLY-pro1x with February 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,293 Posted March 4, 2025 Share Posted March 4, 2025 Lineage-22.1-20250303-NIGHTLY-pro1x with February 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,293 Posted March 10, 2025 Share Posted March 10, 2025 Lineage-22.1-20250310-NIGHTLY-pro1x with February 5th security patch installed smoothly via OTA. MindTheGapps15, and root was maintained. 3 Quote Link to post Share on other sites
