Using the Pro1 as a daily device - what hinders you?
Poll: using the Pro1 as a daily driver
81 members have voted
  1. 1. Do you use it as your daily device yet?
  2. 2. If you answered NO to the above question, what prevents you from using it as your daily device?
    • Nothing - I answered yes!
    • I'm waiting for stable Lineage OS
    • I'm waiting for stable Sailfish OS
    • I'm waiting for stable Maemo (? halp?)
    • I'm waiting on more case options
    • I'm waiting on my phone network to certify the Pro1
      0
    • I'm waiting to see if the masses like the phone before I order one
    • Android - I'm waiting for FinQwerty updates
    • Android - I'm waiting for Keyboard Mapper import & export
    • Other - I didn't get mine yet...
9 hours ago, Wikiwide said:
Unfortunately, currently the device is unable to go into bootloader mode. Yes, I have tried pressing vol-down+power button when the phone is either not connected to anything, plugged into the charger, or plugged into the laptop. Nothing. "fastboot devices" doesn't give a single line.
You could try this trick I used for flashing, not sure if it will work:
  1. Turn off (that should not be an issue for your case)
  2. Insert the usb cable in the PC but NOT the phone yet
  3. Hold both volume keys while 'immediately' inserting the usb-plug
  • Replies 54
I switched from my Huawei P30 Pro after trying and configuring it for 5 days. Before making the jump I had to tackle the following issues: Find a premium book case that fits: using Snakehive H
Using it as my daily driver. Works fine and whenever I have both hands free and going to type a long text, switching to landscape mode. Without 4G (I have an old contract here in Germany, which d
I’ll admit that the first day I did not use the pro1 because I was too scared😂 but I’ve had it with me for two days now and really love this phone. My biggest hinder is not having a proper screen prot
21 hours ago, D1ggs said:
I just wish I could figure out how to remap the camera button to the pixel camera.
You mean to set which app starts automatically with the button? I guess the standard camera app should start with the button, so it would be easy to change it by installing a secondary or third app which will cause the popup menu to open. There you can select what you prefer.
Otherwise, try to go to Settings -> Apps -> gear symbol -> there are some settings, although the camera setting isn't always there.
Actually, it's a known issue that camera button launches the snapdragon camera, not default camera.  One can use something like keymapper to change that behavior for now.
But, using the button as a shutter doesn't seem to work for any camera app I've tried.  The half-press for focus does work on open camera.  But no shutter.
Thank you for the recommendation. It seems there are lots and lots of tricks with these buttons... Wish there was a full list somewhere, with detailed instructions.
However, it seems that there is no change: fastboot devices doesn't give a single line, lsusb says Bus 006 Device 076: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode)
As for marshall's similar experience... Yes, it does sound quite similar - discharging from 21% to entirely flat battery within a few hours does sound implausible.
Nevertheless, I don't know why warming up could make a difference, except for possibly affecting state/voltage of the battery? And I did try warming the device up for a few hours against laptop's ventilation vent (while having the phone plugged into 5V 3A charger) - the Pro1 got quite warm, but still didn't react to any attempts to switch it on.
Thank you. Best wishes.
Per aspera ad astra...
Hooray! The problem seems to be solved, after flashing some of the partitions, as described in thread of Factory Restore Tool, with command-line tool qfpkg_cli .
Apparently, Sailfish OS makes it very easy for user to format internal phone partitions, under mistaken belief of them being memory card partitions... In short: don't go and format a partition just because GUI recommends to do so - it is not necessarily a good enough reason.
Thank you! Best wishes.
  • Like 4
