Slion 1,201 Posted February 23, 2020 Share Posted February 23, 2020 (edited) Anyone else is having issues with the volume rocker? Volume down is working fine but volume up is most unreliable. I need to push at some specific place and angle for it to register reliably. Moreover it's almost flush wit the casing. It would have been easier to get a feel for it if it was sticking out some more. Edited February 23, 2020 by Slion Quote Link to post Share on other sites
elvissteinjr 362 Posted February 23, 2020 Share Posted February 23, 2020 Mine is fine apart from the typical rattle (though that's honestly not something I notice when handling the phone normally). Not flush with the case and both sides of the rocker have the same clicky feedback. Does a fine job and can be pressed down anywhere except the exact middle of it. 2 Quote Link to post Share on other sites
Craig 1,435 Posted February 24, 2020 Share Posted February 24, 2020 mine's fine.. 1 Quote Link to post Share on other sites
cube48 51 Posted September 10, 2020 Share Posted September 10, 2020 (edited) I don't know if this is just coincidence but after the most recent FW update my Volume Down button stopped working. Volume Up is fine. Is anybody else having the same issue? It seems I'll have to open the warranty ticket. 🙄 Edit1: Just found out interesting detail. I had mapped VolDown + Camera = Flash Light On. This mapping still seems to work so the button is not physically dead. Edit2: Disabling the VolDown + Camera buttons mapping doesn't help to solve the issue. Edit3: Key Mapper app is the issue. After disabling it's accessibility service the button works fine. Albeit without Key Mapper with recent FW update. Edited September 10, 2020 by cube48 Quote Link to post Share on other sites
internationaltraitor 84 Posted September 11, 2020 Share Posted September 11, 2020 on my phone, i realize now, that the volume down button is a longer harder press, stays pressed for longer. on the volume up button is is quite instantaneous and doesn't stay pressed down as much as the volume down button. two different kinds of feels. and the volume up "leans" more to inside the casing. slightly. both work fine though. Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 11, 2020 Share Posted September 11, 2020 6 hours ago, internationaltraitor said: on my phone, i realize now, that the volume down button is a longer harder press, stays pressed for longer. on the volume up button is is quite instantaneous and doesn't stay pressed down as much as the volume down button. two different kinds of feels. and the volume up "leans" more to inside the casing. slightly. both work fine though. Hmm, my GUESS would be that e.g. pocket lint has crept in and is preventing the free motion of the button. Quote Link to post Share on other sites
