Slion 1,201 Posted October 13, 2020 Author Share Posted October 13, 2020 (edited) 14 minutes ago, adidas88 said: donˋt have the fn layout you mentioned in the other thread, because I have a qwertz pro1 and have to use finqwerty am I right? I did work on a qwertz layout but it was not completed. The alt layer was missing I believe. Look for the FX QWERTY thread the apk must have been posted there. If you are interested we could work together on improving FX Qwertz layout. Edited October 13, 2020 by Slion Quote Link to post Share on other sites
Slion 1,201 Posted October 13, 2020 Author Share Posted October 13, 2020 16 minutes ago, adidas88 said: simple website blocker with just blocking some words of the url by setting them in the general settings. There is an ad Blocker I guess its functionality could be extended somehow. Quote Link to post Share on other sites
Slion 1,201 Posted October 13, 2020 Author Share Posted October 13, 2020 22 minutes ago, adidas88 said: using back and forth with alt + arrows or ctrl + arrows That's working with FX QWERTY too. You could also try the finqwerty layout. Not sure how that works with Fulgiris though. I'm concerned Fulguris shortcuts won't work well with any qwertz layout. Eventually I want to have customizable shortcuts instead of hardcoded once but it will be a while until we get there. Quote Link to post Share on other sites
Slion 1,201 Posted October 13, 2020 Author Share Posted October 13, 2020 (edited) 38 minutes ago, adidas88 said: creating a new tab should highlight directly the address-bar. I mean why not? What is normally the next step after creating a tab? Actually the workflow in Fulguris is thought out differently. I believe by default doing a search or typing a URL in the toolbar opens a new tab. The idea is that most of the time you don't have to explicitly open a new tab. The trade off is that you should probably close tabs from time to time when you don't need them anymore. Fulguris default configuration should result in a lot more tabs than people are used to. However you can adjust those behaviour from the settings. You can also use tab and shift+tab to move the keyboard focus where you want it to. However not have F11 is somewhat a pain. Edited October 13, 2020 by Slion Quote Link to post Share on other sites
Slion 1,201 Posted October 13, 2020 Author Share Posted October 13, 2020 39 minutes ago, adidas88 said: all in all. good work. like it. Thanks, glad you found the download button 🤣 Quote Link to post Share on other sites
Slion 1,201 Posted October 13, 2020 Author Share Posted October 13, 2020 37 minutes ago, Slion said: There is an ad Blocker I guess its functionality could be extended somehow. @adidas88 The ad blocker can indeed most certainly be used to do just that. I does let you choose a local file listing the hosts to block. I'm not sure what's the format for it though. Maybe look at the Lightning Browser documentation. Quote Link to post Share on other sites
Slion 1,201 Posted November 2, 2020 Author Share Posted November 2, 2020 Pre-registration is opened for the Playstore version: https://play.google.com/store/apps/details?id=net.slions.fulguris.full.playstore 1 Quote Link to post Share on other sites
chippisc 27 Posted November 2, 2020 Share Posted November 2, 2020 Any plans on an F-Droid version? 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 2, 2020 Author Share Posted November 2, 2020 5 minutes ago, chippisc said: Any plans on an F-Droid version? There was an attempt to publish it on F-Droid but it was rejected because it uses Firebase. To be fair an F-Droid release would not give you much over the download variant which has a built-in check for update. You can also disable Firebase from the settings. I'm trying to get it on Playstore in an attempt to monetize to hopefully bring much needed features. F-Droid won't help me with monetizing. 2 Quote Link to post Share on other sites
Slion 1,201 Posted November 9, 2020 Author Share Posted November 9, 2020 (edited) Just published release v1.0.5. Eventually fixed that issue with CTRL+TAB scrolling back to top of the page. Edited November 10, 2020 by Slion Quote Link to post Share on other sites
Slion 1,201 Posted November 10, 2020 Author Share Posted November 10, 2020 (edited) Just published release v1.0.6. History page is now themed. I've also submitted this version to Google Play, see how that goes. Edited November 11, 2020 by Slion 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 11, 2020 Author Share Posted November 11, 2020 Just published release v1.0.7. Fixed an issue where exiting full screen video mode would bring up long press on back button menu. That long press on back button menu was removed. All its functionalities has long been available from the tabs drawer. 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 12, 2020 Author Share Posted November 12, 2020 Now available on PlayStore for free. Five stars reviews are welcome, others not so much 😁 1 Quote Link to post Share on other sites
Hook 3,367 Posted November 12, 2020 Share Posted November 12, 2020 1 hour ago, Slion said: Now available on PlayStore for free. Five stars reviews are welcome, others not so much 😁 Notice, not surprising, the play store version is one version behind the version I have, Just curious, what is/are the in-app purchase(s). Just a support option? It doesn't have ads, right? 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 12, 2020 Author Share Posted November 12, 2020 (edited) 10 minutes ago, Hook said: Notice, not surprising, the play store version is one version behind the version I have, Just curious, what is/are the in-app purchase(s). Just a support option? It doesn't have ads, right? I just pushed the newest version there too so it should turn up soon I hope. No ads no, the in-app purchase is not being used actually. I'm planning to add a very low yearly subscription fee that may enable some features. Maybe I'll limit the number of tabs or something. Anyway this is still work in progress and it could be a while until any of that is implemented. I'm thinking one time in-app purchase to sponsor development of some features could be nice too. Edited November 12, 2020 by Slion 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 13, 2020 Author Share Posted November 13, 2020 I pushed that newer version last night and this morning it was already available. So Play Store update was pretty fast. Quote Link to post Share on other sites
Hook 3,367 Posted November 13, 2020 Share Posted November 13, 2020 (edited) I've never used it before, but the export and import bookmarks seems broken. When I go to "Export bookmarks to backup" I get "Error Sorry, bookmarks could not be exported!" with an OK button. I tried it on my Moto G8 as well, so it isn't just the Pro1 nor is not being on stock. Edited November 13, 2020 by Hook 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 13, 2020 Author Share Posted November 13, 2020 (edited) 40 minutes ago, Hook said: I've never used it before, but the export and import bookmarks seems broken. When I go to "Export bookmarks to backup" I get "Error Sorry, bookmarks could not be exported!" with an OK button. I tried it on my Moto G8 as well, so it isn't just the Pro1 nor is not being on stock. Odd, it works here on stock, it saves it to the download folder. Maybe you need to give the app storage permission. It could be it is trying to save it to a folder that does not exists for some reason. I would need to take a closer look in the code if you can't get it to work. Edited November 13, 2020 by Slion Quote Link to post Share on other sites
Hook 3,367 Posted November 13, 2020 Share Posted November 13, 2020 26 minutes ago, Slion said: Odd, it works here on stock, it saves it to the download folder. Maybe you need to give the app storage permission. It could be it is trying to save it to a folder that does not exists for some reason. I would need to take a closer look in the code if you can't get it to work. Odd. It has storage permission on both phones. The only other thing I can think of is both phones are on versions of Android 10. Have you tested on Android 10? 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 13, 2020 Author Share Posted November 13, 2020 30 minutes ago, Hook said: Odd. It has storage permission on both phones. The only other thing I can think of is both phones are on versions of Android 10. Have you tested on Android 10? Good point, I'll try it out tonight. 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 13, 2020 Author Share Posted November 13, 2020 @Hook I can indeed reproduce that issue on Android 10. I'll try and find some time to fix it. 2 Quote Link to post Share on other sites
Slion 1,201 Posted November 13, 2020 Author Share Posted November 13, 2020 Just published release v1.0.8 tackling bookmarks export issue on Android 10 and some keyboard shortcuts update as mentioned above. @Hook your bookmarks export should work then, it lands in a folder below that path Main Storage \ Android \ data \ net.slions.fulguris... 1 1 Quote Link to post Share on other sites
Hook 3,367 Posted November 14, 2020 Share Posted November 14, 2020 3 hours ago, Slion said: Just published release v1.0.8 tackling bookmarks export issue on Android 10 and some keyboard shortcuts update as mentioned above. @Hook your bookmarks export should work then, it lands in a folder below that path Main Storage \ Android \ data \ net.slions.fulguris... Works fine now. Thanks for the quick response. 1 1 Quote Link to post Share on other sites
Slion 1,201 Posted November 14, 2020 Author Share Posted November 14, 2020 25 minutes ago, Hook said: Works fine now. Thanks for the quick response. I'm jealous you already run Android 10 on your Pro1 😁 2 Quote Link to post Share on other sites
Slion 1,201 Posted November 14, 2020 Author Share Posted November 14, 2020 (edited) Could use your upvote there 😁 Edited November 14, 2020 by Slion Quote Link to post Share on other sites
