Laska 41 Posted March 17, 2024 Share Posted March 17, 2024 23 minutes ago, claude0001 said: Hi @Laska, The keyboard driver for the Pro1 has been completely rewritten by @tdm when he did the original port of LineageOS. The keymap file in LOS 16 is located in /sys/bus/i2c/drivers/aw9523b/6-0058/keymap. However, any changes to that file are not persistent across reboots. If you have root, the easiest way to make changes persistent is the following: Install the app Run Userinit from F-Droid. Execute Run-Userinit once and grant it root privilege. Next, place your modified keymap e.g. in /data/system/keyboard/keymap (you may have to create the "keyboard" folder first). Put an executable script named e.g. 01_install_keymap_mod.sh into /data/local/userinit.d/, with the following content: #!/system/bin/sh # cp /data/system/keyboard/keymap /sys/bus/i2c/drivers/aw9523b/6-0058/ Now Run-Userinit should take care of overwriting the default keymap with your modified one at every boot. Note that @tdm had actually intended keyboard modding to be more user-friendly. On the "keyboard" panel in Settings, you'll find an option named "Custom keymap" that should have automated copying of the keymap, as done above by our script. Unfortunately, the function got broken somewhere along the way after LOS 16 had become official, and was finally fixed only in LOS 18.1. As further changes to keyboard handling had already been introduced add that point, backporting the patch to LOS16 seemed no longer trivial and I did not try it. If possible, get root for your LOS16 (I miss addonsu ...) and use the above boot-script method for automating this. Yes, I'm rooted with Magisk so I think I can put scrpt in post-fs or service.d folder. But I don't understand content of this file -this is not lookng like .kl type file and I don't know how to remap keyboard with those codes. Quote Link to post Share on other sites
claude0001 1,424 Posted March 18, 2024 Share Posted March 18, 2024 (edited) 51 minutes ago, Laska said: But I don't understand content of this file -this is not lookng like .kl type file and I don't know how to remap keyboard with those codes @tdm's driver unfortunately does not come with much documentation outside the source code itself. @Sean McCreary has summarized things in a way I could not best: https://community.fxtec.com/topic/3347-how-to-customize-the-keyboard-layout-on-lineageos-181/?do=findComment&comment=57526 In short: The first column of the keymap is a decimal "key-number" specific to @tdm's driver. The next two columns are the hexadecimal Linux (not Android!) input codes to be generated by that key, either when pressed alone (second column), or together with the "Fn" (yellow arrow) modifier (third column). Edited March 18, 2024 by claude0001 2 Quote Link to post Share on other sites
Laska 41 Posted March 23, 2024 Share Posted March 23, 2024 So after some struggle I've returned to stock. After degoogle it's not bad, it's very fast and clean. And I can confirm now: time resets not happening on stock, even without SIM or any data connection. I've also checked it with my LG V50 -same thing, time and date is always correct. The one problem with stock rom is audio recording, no matter if it's on video ir in only voice in dictaphone app, the sound have cutted higher frequencies. Is there any fix for this? I'm ofcourse rooted. Quote Link to post Share on other sites
claude0001 1,424 Posted March 28, 2024 Share Posted March 28, 2024 Despite my previously announcing the opposite, I did it again. Here are updated builds of good-old LineageOS 16.0 for the SD835 Pro1 (QX1000): https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 The ROM dated "20240327" gives you all backported ASB fixes up to March 2024. As always, my build includes some local modifications specific to the Pro1, as documented in the patch tarball. These have not changed since last year. Credit goes to @Laska for getting me to fire up my old Pro1 again. This made me realise how much LOS 16 was better suited for my use-case compared to recent versions of Android. In consequence, I bought another Pro1 (without defective keyboard) and plan to continue using it with LOS 16 for some time to come. I'll continue to make updated builds with backported ASB patches as long as possible and make them available on my website above. However, considering that this forum is no longer publicly accessible (which is a pity), I doubt that it makes much sense to announce new builds here any more. Anyone knows what is the best place to publish information on the Pro1/Pro1-X now? 1 4 Quote Link to post Share on other sites
Laska 41 Posted March 28, 2024 Share Posted March 28, 2024 22 minutes ago, claude0001 said: Despite my previously announcing the opposite, I did it again. Here are updated builds of good-old LineageOS 16.0 for the SD835 Pro1 (QX1000): https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 The ROM dated "20240327" gives you all backported ASB fixes up to March 2024. As always, my build includes some local modifications specific to the Pro1, as documented in the patch tarball. These have not changed since last year. Credit goes to @Laska for getting me to fire up my old Pro1 again. This made me realise how much LOS 16 was better suited for my use-case compared to recent versions of Android. In consequence, I bought another Pro1 (without defective keyboard) and plan to continue using it with LOS 16 for some time to come. I'll continue to make updated builds with backported ASB patches as long as possible and make them available on my website above. However, considering that this forum is no longer publicly accessible (which is a pity), I doubt that it makes much sense to announce new builds here any more. Anyone knows what is the best place to publish information on the Pro1/Pro1-X now? We all shall to thank you. As I wrote before, Android 9 is last OS without major compromises. I like your website very much, it have some ineresting readings. Yes, I was suprised that without log-in one can not view this forum. Maybe XDA is the place? Quote Link to post Share on other sites
Laska 41 Posted March 28, 2024 Share Posted March 28, 2024 According to my previous question, how can I make audio recordings on Pro1 not so horrible and cut-off? Quote Link to post Share on other sites
claude0001 1,424 Posted March 29, 2024 Share Posted March 29, 2024 18 hours ago, Laska said: According to my previous question, how can I make audio recordings on Pro1 not so horrible and cut-off? There is a long thread about this: https://community.fxtec.com/topic/3427-sound-problems-with-no-response-from-fxtec-support-for-45-days-pre-christmas-device/?tab=comments#comment-59239 Unfortunately with no satisfactory solution. The Pro1 applies some aggressive filtering on the built-in mics that seemingly cannot be disabled. You get best results by using a USB microphone or by recording from the 3.5 mm jack. In the latter case, make sure to disable NFC during recording. It will otherwise introduce a low-amplitude, but clearly audible, "clicking" background. 2 Quote Link to post Share on other sites
claude0001 1,424 Posted May 15, 2024 Share Posted May 15, 2024 For the few remaining fans of Pie, I have just uploaded a new build of my unofficial LineageOS 16.0 for Pro1 (SDS835). At http://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 go for the ROM dated "20240515". After many months of near-inactivity on my side, this build again introduces significant improvements (or so I think). As usual, it gives you security patches backported from the ASB up to May 2024. Beyond that, I finally upgraded the bundled version of WebView -- which had not been updated in 2 years -- to Chromium 124.0.636.82 (the version used by recent LOS 21). I also updated the graphics stack to the level of LOS21 (which uses the blobs from the OnePlus 5T). This bumps the OpenGL ES 3.2 subversion from 331.0 to 415.0. As usual, all my modding with respect to the official LOS16 tree is documented at the link above. Have fun. 3 1 Quote Link to post Share on other sites
claude0001 1,424 Posted June 20, 2024 Share Posted June 20, 2024 I've uploaded my latest build of LineageOS 16.0 for Pro1 (SD835) at: http://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 Go for the ROM dated "20240620". Changes since last month: Include backported Android security patches up to the June 2024 ASB. Update bundled version of WebView to Chromium 125.0.6422.165. As usual, the full patchlog with respect to the unmodified, official LOS 16.0 tree is available at the link above. Have fun. 3 1 Quote Link to post Share on other sites
claude0001 1,424 Posted August 7, 2024 Share Posted August 7, 2024 I've uploaded my latest build of LineageOS 16.0 for OG Pro1 (SD835) to https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 The ROM dated "20240807" gives you backported Android security patches up to the July 2024 ASB. There are no other changes since last time. The full patchlog, documenting all my changes relative to unmodified LOS 16.0 is also available, as usual. Have fun. 3 Quote Link to post Share on other sites
claude0001 1,424 Posted August 21, 2024 Share Posted August 21, 2024 (edited) I've just uploaded my latest build of LineageOS16.0 (for SD835 Pro1), dated 20240820, to https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 Changes since last month: Includes backported security patches up to the August 2024 Android Security Bulletins. Updates the bundled system WebView to Chromium 127.0.6533.103 (as shipped with official LOS 20 and 21). Have a lot of fun! Edited August 21, 2024 by claude0001 2 1 Quote Link to post Share on other sites
claude0001 1,424 Posted September 24, 2024 Share Posted September 24, 2024 The latest build of LineageOS16.0 (for SD835 Pro1), dated 20240924, is available at https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 (Kind of) full list of features: Backported security patches up to the September 2024 ASB. Improved keyboard behaviour (backported from later LOS releases) as documented in the local patch tarball. Several more improvements with respect to the upstream LOS 16 tree (GPS fix, touchscreen margin control, ...) as documented in that same patch tarball. Updated graphics driver stack (from LOS21). Update of the bundled System WebView and browser to Chromium 128.0.6613.88 (from LOS21). Have a lot of fun! 4 Quote Link to post Share on other sites
claude0001 1,424 Posted October 17, 2024 Share Posted October 17, 2024 The October build of LineageOS16.0 (for SD835 Pro1) is available. Head to https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 and get the ROM dated 20241017. Changes since last month: Backported security fixes up to the October 2024 ASB. Update of the bundled System WebView and browser to Chromium 129.0.6668.70 (from LOS21). Have a lot of fun! 1 1 Quote Link to post Share on other sites
diejuse 1 Posted October 22, 2024 Share Posted October 22, 2024 Can you expla On 10/17/2024 at 7:47 PM, claude0001 said: The October build of LineageOS16.0 (for SD835 Pro1) is available. Head to https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 and get the ROM dated 20241017. Changes since last month: Backported security fixes up to the October 2024 ASB. Update of the bundled System WebView and browser to Chromium 129.0.6668.70 (from LOS21). Have a lot of fun! Can you explain how Devuan is implemented and displayed? Using Termux-X11 or XSDL Xserver? Or only terminal like Termux? Quote Link to post Share on other sites
claude0001 1,424 Posted October 25, 2024 Share Posted October 25, 2024 On 10/23/2024 at 1:06 AM, diejuse said: Can you explain how Devuan is implemented and displayed? Using Termux-X11 or XSDL Xserver? Or only terminal like Termux? Note that the GNU/Devuan system is not part of the ROM as offered for download above. You'll have to set that up yourself. That being said, I still use that same Debian/Devuan setup I once described in this thread: It does not rely on Termux or any similar App-based solution. Rather, it runs in a native (rooted) chroot of LineageOS and starts in parallel to that upon boot. This is done via a Userinit script which you can download from that other post above for reference. All this relies on the native AddonSU root-management solution of LOS16, though you can certainly achieve the same thing via Magisk. AddonSU and native access to the SD-card are the main reasons why I'm still sticking to ancient LOS 16. My GNU/Linux setup is unusual in that I run the X11 server (Xorg) inside the chroot, and just connect to it via XRDP. This works both remotely from a PC (giving you kind of a "convergence" experience) or locally from any Android RDP-viewer App running on the phone itself. Not relying on any Android X11-server makes sure you do not accidentally kill all your Linux programs by inadvertently closing that XServer-App. Also, XRDP makes sure the desktop environment is loaded only when needed, and does not eat up RAM all the time. For most use cases one can just access the Linux CLI in text-only mode (via some SSH client). 1 Quote Link to post Share on other sites
claude0001 1,424 Posted November 18, 2024 Share Posted November 18, 2024 (edited) Newest unofficial LineageOS16.0 (for SD835 Pro1) is available. At https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 get the ROM dated 20241116. Changes since last month: Backported security fixes up to the "1 November 2024" ASB. Update system webview and browser to Chromium 130.0.6723.73. Have fun. Edited November 18, 2024 by claude0001 4 Quote Link to post Share on other sites
diejuse 1 Posted January 8, 2025 Share Posted January 8, 2025 On 11/18/2024 at 7:07 PM, claude0001 said: Newest unofficial LineageOS16.0 (for SD835 Pro1) is available. At https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 get the ROM dated 20241116. Changes since last month: Backported security fixes up to the "1 November 2024" ASB. Update system webview and browser to Chromium 130.0.6723.73. Have fun. I'm having issues with the physical keyboard since I tried installing new versions of LineageOS. I recently reinstalled stock rom but the problems persist (key repetition or no response sometimes). I'm sure it's a hardware issue. Do you notice any issues with the physical keyboard with this modified version of LineageOS? Quote Link to post Share on other sites
claude0001 1,424 Posted January 8, 2025 Share Posted January 8, 2025 6 hours ago, diejuse said: I'm having issues with the physical keyboard since I tried installing new versions of LineageOS. I recently reinstalled stock rom but the problems persist (key repetition or no response sometimes). I'm sure it's a hardware issue. Do you notice any issues with the physical keyboard with this modified version of LineageOS? Those are hardware issues, unfortunately. All recent releases of Lineage (including mine) have a workaround implemented in the keyboard driver that suppresses unwanted multiple keystrokes (https://review.lineageos.org/c/LineageOS/android_kernel_fxtec_msm8998/+/318274). For the undetected keypresses, there is unfortunately no software fix. I have three Pro1s. One (the oldest) has that issue to the point where the keyboard is almost unusable, the second has one or two keys that sometimes need two presses to react. Only my most recent device has a flawless keyboard. All three run the same version of my LOS16 ROM. So it must be hardware issues, I think. 3 Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 8, 2025 Share Posted January 8, 2025 1 hour ago, claude0001 said: All three run the same version of my LOS16 ROM. So it must be hardware issues, I think. I can confirm that the keyboard deteriorate over time. My daily driver (stock android) has several keys that have become unreliable, giving 0,1,2 or even 3 chars when pressed once. Quote Link to post Share on other sites
TeZtdevice 368 Posted January 8, 2025 Share Posted January 8, 2025 4 hours ago, EskeRahn said: I can confirm that the keyboard deteriorate over time. My daily driver (stock android) has several keys that have become unreliable, giving 0,1,2 or even 3 chars when pressed once. Yes, I can absoute comfirm this... sadly (ok, my daily driver is 5 years old) 😔 Quote Link to post Share on other sites
claude0001 1,424 Posted January 9, 2025 Share Posted January 9, 2025 The latest unofficial LineageOS 16.0 (for qx1000) is available at https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 Go for the build dated 20250108. Changes since last month: Backported fixes up to the "1 December 2024" Android Security Bulletin. Updated system WebView and browser to Chromium 131.0.6778.200. Have fun. 2 Quote Link to post Share on other sites
claude0001 1,424 Posted February 3, 2025 Share Posted February 3, 2025 Another unofficial build of LineageOS 16.0 (for qx1000) is here, celebrating 3 years of support beyond its AOSP EOL. 🥳 At https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 Go for the ROM dated 20250203. Changes since last release: Backported fixes up to the "1 January 2025" Android Security Bulletin. Updated system WebView and browser engine to Chromium 132.0.6834.122. Have fun. 5 1 Quote Link to post Share on other sites
claude0001 1,424 Posted March 10, 2025 Share Posted March 10, 2025 I've just uploaded build '20250309' of LineageOS 16.0 for OG Pro1 (qx1000) to https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 Changes since last release: Backported fixes up to the "February 2025" Android Security Bulletin. Updated system WebView and browser to Chromium 133.0.6943.137. Have fun. 2 2 Quote Link to post Share on other sites
claude0001 1,424 Posted March 26, 2025 Share Posted March 26, 2025 Here's another one. The ROM dated '20250326', available at https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 gives you my latest unofficial build of LineageOS 16.0 for Pro1 (qx1000). To make the thread more accessible, I'll recapitulate the full list of enhancements with respect to official every few months. So here it comes: Backported AOSP fixes up to the "1 March 2025" ASB (official LOS 16.0 stopped updating in January 2022). Improved keyboard behaviour, partly backported from later LOS releases (code changes can be found in my local patch tarball). Several more improvements with respect to the upstream LOS 16 tree (GPS fix, touchscreen margin control, ...) as documented in that same patch tarball. Updated graphics driver stack (using the same blobs as LOS21 & 22). Updated bundled WebView to Chromium 134.0.6998.95 (important for those running without Gapps). Have a lot of fun. 3 Quote Link to post Share on other sites
claude0001 1,424 Posted May 5, 2025 Share Posted May 5, 2025 An updated build of LineageOS 16.0 for OG Pro1 (qx1000) is available for download at: https://findus.zwergenschaenke.net/~puma/linux.html#lineagepro1 The build dated '20250504' gives you backported security fixes from the Android Security Bulletin up to the "1 April 2025" patchlevel, and updates the bundled WebView to Chromium 135.0.7049.100. Otherwise no changes with respect to last month's upload. Have fun. 3 Quote Link to post Share on other sites
