agent008 248 Posted June 25, 2021 Share Posted June 25, 2021 (edited) I took the plunge and installed AICP Q yesterday (coming from LOs 17). I can't however check for updates. Did I do something wrong? EDIT: It means I'm now on the Feb 6th 2021 version. Checking for updates gives the error message below (Failure while trying to check for updates. Please check your Internet connection and try again later) Thanks Edited June 25, 2021 by agent008 Quote Link to post Share on other sites
Hook 3,368 Posted June 25, 2021 Share Posted June 25, 2021 5 hours ago, agent008 said: I took the plunge and installed AICP Q yesterday (coming from LOs 17). I can't however check for updates. Did I do something wrong? EDIT: It means I'm now on the Feb 6th 2021 version. Checking for updates gives the error message below (Failure while trying to check for updates. Please check your Internet connection and try again later) Thanks IIRC, there never was OTA updates. This was an unofficial version maintained by @tdm, He has currently dropped off the radar, here at least. I have moved over to Lineage 18.1, which is too bad because I much prefer AICP. 3 2 Quote Link to post Share on other sites
agent008 248 Posted June 26, 2021 Share Posted June 26, 2021 (edited) oh no! I should've asked around before jumping ship to AICP. I'm liking it too. Battery life's great. I hope all's well with @tdm , that this might be temporary, and that he keeps doing his great work on the ROM. Edited June 26, 2021 by agent008 punctuation 2 Quote Link to post Share on other sites
agent008 248 Posted June 28, 2021 Share Posted June 28, 2021 By the way. Whatsapp notifications don't make any sound for me. No matter what I choose on the settings, it just doesn't play any sound. The visual notification works ok, though. Has anybody had the same issue? Quote Link to post Share on other sites
agent008 248 Posted July 1, 2021 Share Posted July 1, 2021 On 6/28/2021 at 7:33 AM, agent008 said: Whatsapp notifications don't make any sound for me. Update on this. I use FairEmail as my email client. Also doesn't play any notification sounds. I use QkSMS for texts and it's notifications work fine. Whatsapp calls do work - phone plays repeatedly the sound that was meant to be played for incoming messages. Did anybody have the same problem? Quote Link to post Share on other sites
Hook 3,368 Posted July 5, 2021 Share Posted July 5, 2021 So @tdm Just curious, not trying to bug you. Is this project dead? Any possibility of AICP picking it up officially so it can get regular updates? I obviously would like it to be resurrected, but "no" or "hell, no" are fine. I just would like to know. 🙂 Whatever the answer is, thanks for all you did! 7 1 Quote Link to post Share on other sites
CornholioGSM 375 Posted July 24, 2021 Share Posted July 24, 2021 ...it looks like whole development of new roms is dead 😞 3 Quote Link to post Share on other sites
Hook 3,368 Posted July 24, 2021 Share Posted July 24, 2021 I hope he's okay. Seems strange that @tdm would just completely stop communicating. 😕 2 Quote Link to post Share on other sites
EskeRahn 5,604 Posted August 20, 2021 Share Posted August 20, 2021 Well I have for now given up on AICP and replaced it with LOS 18. Though I liked AICP, and definitely will reconsider if something new is happening. 2 1 Quote Link to post Share on other sites
