lawliett 77 Posted March 4, 2021 Share Posted March 4, 2021 (edited) Where can I buy glass screen protectors for pro1? I feel that they would provide more protection to the screen in case of a drop. I know that Brotect has something called AirGlass screen protector and while they don't provide those for Pro1, they do provide it for elephone U, so I assume I could use those. Are there any other options available for glass screen protectors? Also has anyone used the AirGlass screen protector elephone U version with their pro1, and how has your experience been? Edited March 4, 2021 by lawliett Quote Link to post Share on other sites
CornholioGSM 373 Posted March 4, 2021 Share Posted March 4, 2021 ...nowhere 😞 curved tempered glass does not exists . You can only buy precurved tpu screen protector for elefone. Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 5, 2021 Share Posted March 5, 2021 2 hours ago, CornholioGSM said: ...nowhere 😞 curved tempered glass does not exists . You can only buy precurved tpu screen protector for elefone. They DO exist for BB-Priv, so could be made for the Pro1 & Elephone U also. They are not that hard to make when the screen only curves parallel to the long edges of the device. Quote Link to post Share on other sites
CornholioGSM 373 Posted March 5, 2021 Share Posted March 5, 2021 (edited) Yesss...they can be madded , but does not exists now. Similar glass is for s9+ but is too long Edited March 5, 2021 by CornholioGSM 1 Quote Link to post Share on other sites
_DW_ 628 Posted March 5, 2021 Share Posted March 5, 2021 I have used these https://www.amazon.co.uk/gp/product/B07RWGCG9S/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1 Am sure something cheaper can be found though I only paid £5.99 originally about a year ago. But no glass ones available 😞 But surely there will be around 2000 phones in the wild so maybe a custom one might be made if a supplier was contacted. (not interested in doing that my self though) 1 Quote Link to post Share on other sites
adflau 13 Posted March 6, 2021 Share Posted March 6, 2021 Currently using a curved glass screen protector so can confirm they do exist (s10+). Bit of a process to install but definitely wish there was one for the pro1 before I decided to smash mine on a rock.  1 Quote Link to post Share on other sites
_DW_ 628 Posted March 6, 2021 Share Posted March 6, 2021 Manufacturer of curved screen protectors https://www.mobilephoneguard.com/ 1 Quote Link to post Share on other sites
pebert 98 Posted March 7, 2021 Share Posted March 7, 2021 Any experience in this? And did anyone confirm that elephone U protector works? Quote Link to post Share on other sites
Rob. S. 1,667 Posted March 7, 2021 Share Posted March 7, 2021 14 minutes ago, pebert said: And did anyone confirm that elephone U protector works? Ordered the last package that was available from a marketplace seller through amazon.de (8.88 €) on Friday – I'll report back when I get them... 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 7, 2021 Share Posted March 7, 2021 9 hours ago, pebert said: Any experience in this? And did anyone confirm that elephone U protector works? The protectors for the Elephone U all works perfect as it is (literally) the same BOE-display on both. BUT currently we can only get the real tempered glass ones FLAT (not full coverage), or the elastic type curved - you can get both types for trifles on e.g. AliExpress - I bought a stack, and they work just fine. Quote Link to post Share on other sites
3zet 100 Posted March 8, 2021 Share Posted March 8, 2021 S8 does not fit? Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 8, 2021 Share Posted March 8, 2021 8 hours ago, 3zet said: S8 does not fit? I believe it was for the S8+ I tried (if I remember right), the S8 is too slim. But anyway they are too elongated, and need to be cut (i was unable to do that with the tools I got, but perhaps a plasma cutter or something like that could do the trick. 1 Quote Link to post Share on other sites
CornholioGSM 373 Posted March 10, 2021 Share Posted March 10, 2021 ...maybe with resistor wire and then quick colddown ? ...maybe 1 Quote Link to post Share on other sites
VaZso 1,999 Posted March 10, 2021 Share Posted March 10, 2021 On 3/7/2021 at 11:05 PM, EskeRahn said: The protectors for the Elephone U all works perfect as it is (literally) the same BOE-display on both. BUT currently we can only get the real tempered glass ones FLAT (not full coverage), or the elastic type curved - you can get both types for trifles on e.g. AliExpress - I bought a stack, and they work just fine. I have also ordered screen protectors from Aliexpress for Elephone U Pro which worked well for my Pro1. However, these screen protectors are disappearing... ...do you currently see them on Aliexpress? Anyway, they are relatively good - the only problem is they start to peel up at curves which they still good for a while, but getting more and more dirty at that place and there will be a point where dirt goes too much inside and you can easily peel it up occasionally... I have also cut earlier a strong material ordered from the USA which worked for a relatively short while but it also peeled up and got dirty mostly when I put it into my pocket (starting at top or bottom side at one of the corners). The screen protectors ordered from Aliexpress were much better as they are less elastic and don't start peeling off at short sides, only at left/right sides. So it is not easy to find a really good screen protector for curved screens, especially as screen protectors for Elephone U Pro seem to be practically disappeared. Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 10, 2021 Share Posted March 10, 2021 1 minute ago, VaZso said: So it is not easy to find a really good screen protector for curved screens, especially as screen protectors for Elephone U Pro seem to be practically disappeared. Thanks for the warning, I was not aware. so we better go and collect a stock of what is left... 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 10, 2021 Share Posted March 10, 2021 7 minutes ago, EskeRahn said: Thanks for the warning, I was not aware. so we better go and collect a stock of what is left... ...it seems we are already too late.... 😲 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 10, 2021 Share Posted March 10, 2021 19 minutes ago, EskeRahn said: ..it seems we are already too late.... 😲 At the least some are still available at amazon, though at a substantially higher price.... Quote Link to post Share on other sites
_DW_ 628 Posted March 10, 2021 Share Posted March 10, 2021 (edited) https://www.amazon.de/dipos-Screen-Protector-Elephone-Pro/dp/B07BFW8LJ3/ref=sr_1_6?dchild=1&keywords=Elephone+U+Screen+Protector&qid=1615399201&s=electronics&sr=1-6 Edited March 10, 2021 by _DW_ 2 Quote Link to post Share on other sites
_DW_ 628 Posted March 12, 2021 Share Posted March 12, 2021 On 3/10/2021 at 6:01 PM, _DW_ said: https://www.amazon.de/dipos-Screen-Protector-Elephone-Pro/dp/B07BFW8LJ3/ref=sr_1_6?dchild=1&keywords=Elephone+U+Screen+Protector&qid=1615399201&s=electronics&sr=1-6 Just noticed in the picture they flipped the image wrong 😄 Quote Link to post Share on other sites
lawliett 77 Posted April 10, 2021 Author Share Posted April 10, 2021 On 3/10/2021 at 1:01 PM, _DW_ said: https://www.amazon.de/dipos-Screen-Protector-Elephone-Pro/dp/B07BFW8LJ3/ref=sr_1_6?dchild=1&keywords=Elephone+U+Screen+Protector&qid=1615399201&s=electronics&sr=1-6 I got this because I thought it was a glass screen protector according to description, but it appears to be regular plastic. Is it actually glass? Does it shatter if you drop it and protect the screen underneath? Quote Link to post Share on other sites
Rob. S. 1,667 Posted April 11, 2021 Share Posted April 11, 2021 @lawliett No, that's definitely not glass, it's a flexible plastic, just like the one I ordered earlier – the delivery of which has been been postponed, with the new estimated period already nearly over, too. (If it was specifically designed for the Pro1 instead of the Elephone, one might suspect that might be to better fit the specific device.) Quote Link to post Share on other sites
EskeRahn 5,598 Posted April 11, 2021 Share Posted April 11, 2021 2 hours ago, Rob. S. said: (If it was specifically designed for the Pro1 instead of the Elephone, one might suspect that might be to better fit the specific device.) No, it is the same BOE display unit so the protector will fit exactly as good/bad on one or the other. Quote Link to post Share on other sites
Rob. S. 1,667 Posted April 11, 2021 Share Posted April 11, 2021 4 hours ago, EskeRahn said: No, it is the same BOE display unit so the protector will fit exactly as good/bad on one or the other. Sorry, forgot the irony tags. I was commenting on the "postponed" aspect there... 1 Quote Link to post Share on other sites
_DW_ 628 Posted April 12, 2021 Share Posted April 12, 2021 @lawliettyeah there plastic poor description on item. I don't think there are any glass protectors for this screen Quote Link to post Share on other sites
EskeRahn 5,598 Posted April 12, 2021 Share Posted April 12, 2021 1 hour ago, _DW_ said: @lawliettyeah there plastic poor description on item. I don't think there are any glass protectors for this screen Well yes and no. There ARE tempered glass protectors BUT I have only found flat ones, thus not fully covering.... What we would like would be similar to the ones for e.g. the BB Priv, or Samsung S8(+/-) & S9(+/-) that are flat in the long direction and curved in the short. (Technically MUCH simpler to make than doubled-curved ones) Quote Link to post Share on other sites
