CornholioGSM 375 Posted December 28, 2021 Share Posted December 28, 2021 (edited) hello all, ....i still have little problem of no internet connection on some apps - mainly on gmaps, translator and sometime on messenger. I really dont known what to check...maybe it is problem on battery optimization but i dont known. After reboot phone all works fine for maybe one day...and then again no internet connection. I can be on lte or wifi but problem same.....and sometime same problem on updater too. Any idea? Edited December 28, 2021 by CornholioGSM Quote Link to post Share on other sites
Jacob_S 128 Posted December 28, 2021 Share Posted December 28, 2021 (edited) 20 minutes ago, CornholioGSM said: hello all, ....i still have little problem of no internet connection on some apps - mainly on gmaps, translator and sometime on messenger. I really dont known what to check...maybe it is problem on battery optimization but i dont known. After reboot phone all works fine for maybe one day...and then again no internet connection. I can be on lte or wifi but problem same.....and sometime same problem on updater too. Any idea? I think I actually have the same/a similar problem on LineageOS 18.1 Edit: Observed it so far on Google Maps and the app "MVG Fahrinfo" (for public transport in Munich) and I think on a few more apps, which I currently cannot recall. But everytime it happened, it was only concerning some apps and was fixed by a reboot. Edited December 28, 2021 by Jacob_S 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted December 29, 2021 Share Posted December 29, 2021 Update to December 29, with December 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted January 5, 2022 Share Posted January 5, 2022 Update to January 5 2022, with December 5 2021 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted January 12, 2022 Share Posted January 12, 2022 Update to January 12 2022, with December 5 2021 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted January 19, 2022 Share Posted January 19, 2022 Update to January 19 2022, with December 5 2021 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted January 26, 2022 Share Posted January 26, 2022 Update to January 26, with January 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted February 2, 2022 Share Posted February 2, 2022 Update to February 2, with January 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
Arn 4 Posted February 2, 2022 Share Posted February 2, 2022 On 11/3/2021 at 8:54 PM, Hook said: Updated to the 03 November weekly via OTA. All went smoothly and root was maintained, October security patch. (This seems to be the last post that states root was maintained, hence replying to it). So how does one retain root access. Is there something special you need to do? Or is it not possible anymore? I've installed aicp_pro1_r-16.1-WEEKLY-20220126.zip a couple of days ago, and just applied the OTA to aicp_pro1_r-16.1-WEEKLY-20220202.zip, which 'uninstalled' Magisk. I had to jump through the payload_dumper hoops again, which is rather annoying to do after every update 😉 Quote Link to post Share on other sites
Hook 3,365 Posted February 2, 2022 Share Posted February 2, 2022 1 hour ago, Arn said: (This seems to be the last post that states root was maintained, hence replying to it). So how does one retain root access. Is there something special you need to do? Or is it not possible anymore? I've installed aicp_pro1_r-16.1-WEEKLY-20220126.zip a couple of days ago, and just applied the OTA to aicp_pro1_r-16.1-WEEKLY-20220202.zip, which 'uninstalled' Magisk. I had to jump through the payload_dumper hoops again, which is rather annoying to do after every update 😉 Keep in mind that I only use Magisk for SU. I flash the apk as a zip. I don't "install it" (it places Magisk Manager on the phone but I never even open it). Of course, right now I don't know if anything has changed with the updates since my Pro1 is in the shop at FxTec for repairs. 😉 Quote Link to post Share on other sites
EskeRahn 5,604 Posted February 10, 2022 Share Posted February 10, 2022 Update to February 9, with January 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted February 16, 2022 Share Posted February 16, 2022 Update to February 16, with January 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted February 25, 2022 Share Posted February 25, 2022 Update to February 23, with Februrary 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted March 2, 2022 Share Posted March 2, 2022 Update to March 2, with Februrary 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted March 10, 2022 Share Posted March 10, 2022 Update to March 9, with Februrary 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
CornholioGSM 375 Posted March 16, 2022 Share Posted March 16, 2022 (edited) Hmm...because i dont have problem with charging for approx 14 days....was this problem solved? ...it looks like all is without problem...i can charge without reboot Edited March 16, 2022 by CornholioGSM 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted March 16, 2022 Share Posted March 16, 2022 4 hours ago, CornholioGSM said: Hmm...because i dont have problem with charging for approx 14 days....was this problem solved? ...it looks like all is without problem...i can charge without reboot Interresting. I have never found a pattern to actively provoke it, so could not tell if it is luck you did not see it or if fixed. But let us hope it has been fixed. Quote Link to post Share on other sites
EskeRahn 5,604 Posted March 16, 2022 Share Posted March 16, 2022 Update to March 16, with March 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted March 25, 2022 Share Posted March 25, 2022 Update to March 23, with March 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted March 30, 2022 Share Posted March 30, 2022 Update to March 30, with March 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) Quote Link to post Share on other sites
EskeRahn 5,604 Posted April 6, 2022 Share Posted April 6, 2022 Update to April 6, with March 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) This thread seems rather stale, so perhaps I should stop reporting every weekly update? 1 Quote Link to post Share on other sites
Hook 3,365 Posted April 6, 2022 Share Posted April 6, 2022 4 hours ago, EskeRahn said: Update to April 6, with March 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) This thread seems rather stale, so perhaps I should stop reporting every weekly update? It is appreciated. Unfortunately, my Pro1 is still in the shop so I'm out of the loop right now (not suprisingly, nor unexpected—knew it would take time when I sent it in). I'm always happy to see it is still going. Looking forward to getting back and hoping, maybe, there might be an AICP for the Pro1x eventually. 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted April 13, 2022 Share Posted April 13, 2022 On 3/30/2022 at 5:20 PM, EskeRahn said: Update to April 13, with March 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The download stage is substantially faster than LineageOS, But the stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted April 20, 2022 Share Posted April 20, 2022 Update to April 20, with March 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The download stage is substantially faster than LineageOS, But the stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted April 27, 2022 Share Posted April 27, 2022 Update to April 27, with March 5 security patch using OTA went smoothly. Known keyboard bug still there (see lineage thread) (The download stage is substantially faster than LineageOS, But the stage after download and install called "Finalising package installation" is surprising slow though - like it is on LineageOS) 1 Quote Link to post Share on other sites
