EskeRahn 5,564 Posted February 14, 2022 Share Posted February 14, 2022 This is a post with links to threads on various tasks. Like installing and repairing. Suggest additions at will. If I find it relevant, I will add it, and plan to remove the suggestions to keep this thread (c)lean. ***Please be aware that guides for Pro1 and Pro1X are NOT interchangeable in general, though much goes for both*** Please: Help keep the forum clean and use the Report function whenever you see some spam or similar irrelevant content. Please: Enter your FxTec Device Information in your Member Title slot under "Edit Profile". See this (So others can easier see if you are writing regarding the Pro1 or Pro1X) For official documentation see the posts in this forum https://community.fxtec.com/?forumId=50 For Official and unofficial community chats, see: https://community.fxtec.com/topic/3922-community-chats/ Other important/older links: How to open/shut the Pro1/Pro1X, @Elysia Pro1X not starting/charging, known fix (without opening)! Various ROMs available to the Pro1/Pro1X available for download, Links Including restoring stock Android. Please Enter Your FxTec Device Information in your Member Title slot under "Edit Profile." Pro1 QWERTZ User Layout Setup, @Waxberry Make SURE to allow your phone to charge when OFF, change crazy default as described e.g. here (if not allowed, a depleted battery might be impossible to charge) Disassembly guides, see this @netman and official videos here and on Vimeo here Help show your Pro1/Pro1X to others, see this How to lock/unlock your bootloader.see this. Pro1X stock, Initial setup. Remove SIM and SD card, to connect to Google. See this. Pro1 rooting.with magisk, see e.g. this. Pro1X rooting with magisk, see e.g. this or this. (thanks @ScarFez for suggesting) 8 Link to post Share on other sites
