TeZtdevice 368 Posted September 12, 2023 Share Posted September 12, 2023 lineage-20.0-20230911-nightly-pro1-signed.zip on August 5 security patch installed smoothly using OTA (while the LOS-Update, I stopped all other updates or backups) Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 2, 2023 Share Posted October 2, 2023 (lineage-20.0-20231002-nightly-pro1-signed.zip on Sep 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) Quote Link to post Share on other sites
TeZtdevice 368 Posted October 9, 2023 Share Posted October 9, 2023 lineage-20.0-20231009-nightly-pro1-signed.zip on September 5 security patch installed smoothly using OTA (while the LOS-Update, I stopped all other updates or backups) Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 9, 2023 Share Posted October 9, 2023 Lineage-20.0-20231009-nightly-pro1-signed.zip KILLED USER PARTITON, FORMAT NEEDED, From there it installed smoothly using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316, ends on on Sep 5 security patch. Quote Link to post Share on other sites
Hook 3,315 Posted October 9, 2023 Share Posted October 9, 2023 18 minutes ago, EskeRahn said: Lineage-20.0-20231009-nightly-pro1-signed.zip KILLED USER PARTITON, FORMAT NEEDED, From there it installed smoothly using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316, ends on on Sep 5 security patch. For clarification, was that because your user partition had a problem or because this Lineage update needed it? Coincidentally, I just returned my Pro 1 to Lineage this afternoon, but I was coming from Droidian, so user partition was already freshly formatted. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 9, 2023 Share Posted October 9, 2023 Just now, Hook said: For clarification, was that because your user partition had a problem or because this Lineage update needed it? Coincidentally, I just returned my Pro 1 to Lineage this afternoon, but I was coming from Droidian, so user partition was already freshly formatted. It was working fine, until seconds before I did the update. It seems to have crashed the user partition either during the flash of the boot.img, or the following attempted boot into recovery mode (That failed requesting a reformat). (I did retry several times, and also aborted and booted to fastboot-mode and retried the flashing - after doing a new download just to be sure, but the partition was smashed) 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 16, 2023 Share Posted October 16, 2023 (lineage-20.0-20231016-nightly-pro1-signed.zip on Oct 6 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 1 Quote Link to post Share on other sites
Kzin 33 Posted October 22, 2023 Share Posted October 22, 2023 (edited) Hi, I just started to setup for install of LOS 20 with these instructions: "https://wiki.oddsolutions.us/devices/pro1/install" When I enter "fastboot oem enable-charger-screen" I get "FAILED (remote: unknown command)". Phone is on stock at the moment. Edited October 22, 2023 by Kzin Quote Link to post Share on other sites
--- 129 Posted October 22, 2023 Share Posted October 22, 2023 (edited) Deleted, misread the question. Oops. Edited October 22, 2023 by MonCon 1 Quote Link to post Share on other sites
Hook 3,315 Posted October 22, 2023 Share Posted October 22, 2023 2 hours ago, Kzin said: Hi, I just started to setup for install of LOS 20 with these instructions: "https://wiki.oddsolutions.us/devices/pro1/install" When I enter "fastboot oem enable-charger-screen" I get "FAILED (remote: unknown command)". Phone is on stock at the moment. Just so you know, Odd Solutions is not official Lineage, though I don't think there is anything wrong with it. I'm not sure, but I seem to think I recall that n.p. Johnson may be involved with it. However, since most here use the official Lineage, you probably need to pose your questions to them. Here is their explanations of the difference. https://wiki.oddsolutions.us/faq.html#what-is-the-difference-between-odd-solutions-builds-and-official-lineageos The instructions do seem to be cloned from the official site. Here is official Lineage for the Pro1 (first link is downloads, the second link is for instructions: https://download.lineageos.org/devices/pro1/builds https://wiki.lineageos.org/devices/pro1/ 1 Quote Link to post Share on other sites
Kzin 33 Posted October 22, 2023 Share Posted October 22, 2023 4 hours ago, Hook said: Just so you know, Odd Solutions is not official Lineage, though I don't think there is anything wrong with it. I'm not sure, but I seem to think I recall that n.p. Johnson may be involved with it. However, since most here use the official Lineage, you probably need to pose your questions to them. Here is their explanations of the difference. https://wiki.oddsolutions.us/faq.html#what-is-the-difference-between-odd-solutions-builds-and-official-lineageos The instructions do seem to be cloned from the official site. Here is official Lineage for the Pro1 (first link is downloads, the second link is for instructions: https://download.lineageos.org/devices/pro1/builds https://wiki.lineageos.org/devices/pro1/ I guess My question is about fastboot. as I'm not close to flashing yet, seems to me the instructions Linked, are the same for everyone, just not sure why I get the error. "Fastboot devices" sees the phone, debugging is on, it's in Boot loader mode... thanks. Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 22, 2023 Share Posted October 22, 2023 2 hours ago, Kzin said: I guess My question is about fastboot. as I'm not close to flashing yet, seems to me the instructions Linked, are the same for everyone, just not sure why I get the error. "Fastboot devices" sees the phone, debugging is on, it's in Boot loader mode... thanks. Working with Fastboot tends to be extremely picky on the connection. I have had good experiences with inserting a hub between the computer and the phone. Or to select a USB 2.0 port Fastboot can work with USB 3.0 but is really picky. When I go through my thunderbolt connected docking, and use a USB 3.0 port on that it works smoothly, but not directly connected to the laptop.... ...On windows it can also be quite picky on the driver... 1 Quote Link to post Share on other sites
Kzin 33 Posted October 23, 2023 Share Posted October 23, 2023 15 hours ago, EskeRahn said: Working with Fastboot tends to be extremely picky on the connection. I have had good experiences with inserting a hub between the computer and the phone. Or to select a USB 2.0 port Fastboot can work with USB 3.0 but is really picky. When I go through my thunderbolt connected docking, and use a USB 3.0 port on that it works smoothly, but not directly connected to the laptop.... ...On windows it can also be quite picky on the driver... Yup, tried 5 different USB cables and the last one worked...thanks 3 Quote Link to post Share on other sites
Kzin 33 Posted October 23, 2023 Share Posted October 23, 2023 (edited) 16 hours ago, Kzin said: Yup, tried 5 different USB cables and the last one worked...thanks Actually, had to go to a different PC, before it would work properly, now on 20, only cannot make or receive calls, data/sms are working. working now Edited October 23, 2023 by Kzin 1 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 24, 2023 Share Posted October 24, 2023 Last update 20231016 seems to have thrown the Developer options setting away, but can be reenabled, so adb connection works.. lineage-20.0-20231021-nightly-pro1-signed.zip on Oct 6 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316 This update preserved the Developer options setting, as usual. Note the date, Not the usual Monday - not that it matters. 2 Quote Link to post Share on other sites
Hook 3,315 Posted October 24, 2023 Share Posted October 24, 2023 Just noting that losing Developer options also happened on my Pro1 with the earlier update, but it has not happened with any of the updates on the Pro1x. Wonder what specifically got changed with the Pro1 to create that result? 2 Quote Link to post Share on other sites
Hook 3,315 Posted October 30, 2023 Share Posted October 30, 2023 Lineage-20.0-20231028-nightly-pro1 with Oct 6th security patch installed smoothly via OTA. MindTheGapps13. This is now a backup phone, so I'm not rooted on the Pro1 like I am on the Pro1x. The official release date for the Pro1 seems to have changed from Monday to Saturday. The Pro1x updates are now being released on Monday. Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 30, 2023 Share Posted October 30, 2023 (lineage-20.0-20231028-nightly-pro1-signed.zip on Oct 6 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316)Updates seem to have changed from Mondays to Saturdays for the Pro1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 8, 2023 Share Posted November 8, 2023 (lineage-20.0-20231104-nightly-pro1-signed.zip on Oct 6 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 11, 2023 Share Posted November 11, 2023 (lineage-20.0-20231111-nightly-pro1-signed.zip on Oct 6 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) (Did another one OTA, worked smooth too) 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 19, 2023 Share Posted November 19, 2023 (lineage-20.0-20231118-nightly-pro1-signed.zip on Nov 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 27, 2023 Share Posted November 27, 2023 (lineage-20.0-20231125-nightly-pro1-signed.zip on Nov 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 3, 2023 Share Posted December 3, 2023 (lineage-20.0-20231202-nightly-pro1-signed.zip on Nov 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) Quote Link to post Share on other sites
Wheeljack 212 Posted December 17, 2023 Share Posted December 17, 2023 Installed 20-20231216-NIGHTLY-pro1 last night via OTA. Running fine so far. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 19, 2023 Share Posted December 19, 2023 (lineage-20.0-20231216-nightly-pro1-signed.zip on Dec 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 2 Quote Link to post Share on other sites
