EskeRahn 5,598 Posted December 24, 2023 Share Posted December 24, 2023 (lineage-20.0-20231223-nightly-pro1-signed.zip on Dec 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 31, 2023 Share Posted December 31, 2023 (lineage-20.0-20231230-nightly-pro1-signed.zip on Dec 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 2, 2024 Share Posted January 2, 2024 1 hour ago, oliviersenn6 said: P.S.: any pro1 LOS users have had issues with sending SMS? not the right thread but LOS support doesn't care and neither does my carrier I rarely tried, but it worked when I did, both send and receive. Is it constantly or occasional it fails for you? Quote Link to post Share on other sites
oliviersenn6 47 Posted January 2, 2024 Share Posted January 2, 2024 4 hours ago, EskeRahn said: I rarely tried, but it worked when I did, both send and receive. Is it constantly or occasional it fails for you? constant, both RCS and SMS (but not MMS !) fail to send. LOS devs went "damn that sucks", and my carrier had me try things that went nowhere. at this point if i need to send an SMS i press send, it fails, i take a screenshot and send that as an MMS. Jus throwing it out there in case someone has seen that before but if you haven't heard of it then i'm definitely alone with this. Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 2, 2024 Share Posted January 2, 2024 19 minutes ago, oliviersenn6 said: constant, both RCS and SMS (but not MMS !) fail to send. LOS devs went "damn that sucks", and my carrier had me try things that went nowhere. at this point if i need to send an SMS i press send, it fails, i take a screenshot and send that as an MMS. Jus throwing it out there in case someone has seen that before but if you haven't heard of it then i'm definitely alone with this. We are in the wrong thread for this.... Send an receive of sms works fine using Textra, and even the build in Messaging app - that I never use. Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 2, 2024 Share Posted January 2, 2024 (moved a few posts from another thread) Quote Link to post Share on other sites
Hook 3,313 Posted January 2, 2024 Share Posted January 2, 2024 1 hour ago, oliviersenn6 said: constant, both RCS and SMS (but not MMS !) fail to send. LOS devs went "damn that sucks", and my carrier had me try things that went nowhere. at this point if i need to send an SMS i press send, it fails, i take a screenshot and send that as an MMS. Jus throwing it out there in case someone has seen that before but if you haven't heard of it then i'm definitely alone with this. Don't know if this is the problem, but it sounds like what would happen to me on my Pro1 when I used to try to mule it onto Verizon's network. That is exactly what would break and how it would break. On T-Mobile (USA), which has no problem with the Pro1 or Pro1x being on their network, no problems at all. Quote Link to post Share on other sites
CornholioGSM 370 Posted January 2, 2024 Author Share Posted January 2, 2024 (edited) 7 hours ago, oliviersenn6 said: constant, both RCS and SMS (but not MMS !) fail to send. LOS devs went "damn that sucks", and my carrier had me try things that went nowhere. at this point if i need to send an SMS i press send, it fails, i take a screenshot and send that as an MMS. Jus throwing it out there in case someone has seen that before but if you haven't heard of it then i'm definitely alone with this. Have you tested to set sms center manually for vzw? MMS is working because mms can be sent via data connection too. Edit : dial *#*#4636#*#* - phone information - smsc refresh and reboot ...and maybe turn off in sms settings rcs chats (using data/wifi for texting) Edited January 2, 2024 by CornholioGSM 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 3, 2024 Share Posted January 3, 2024 13 hours ago, CornholioGSM said: Have you tested to set sms center manually for vzw? That is a very good suggestion! Most newer SIMs come with the SMSC set, but it was quite common earlier that we had to do this manually. Quote Link to post Share on other sites
CornholioGSM 370 Posted January 3, 2024 Author Share Posted January 3, 2024 9 hours ago, EskeRahn said: That is a very good suggestion! Most newer SIMs come with the SMSC set, but it was quite common earlier that we had to do this manually. This problem was on some usa phones unlocked for another carriers. But i mean that it is not problem on los. I mean that something was changed by user. Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 15, 2024 Share Posted January 15, 2024 (lineage-20.0-20240113-nightly-pro1-signed.zip on Jan 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 20, 2024 Share Posted January 20, 2024 (lineage-20.0-20240120-nightly-pro1-signed.zip on Jan 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 28, 2024 Share Posted January 28, 2024 (lineage-20.0-20240127-nightly-pro1-signed.zip on Jan 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-13.0.0-arm64-20230808_213316) 2 Quote Link to post Share on other sites
oliviersenn6 47 Posted February 27, 2024 Share Posted February 27, 2024 On 1/3/2024 at 12:25 AM, CornholioGSM said: Have you tested to set sms center manually for vzw? MMS is working because mms can be sent via data connection too. Edit : dial *#*#4636#*#* - phone information - smsc refresh and reboot ...and maybe turn off in sms settings rcs chats (using data/wifi for texting) thanks (and sorry for deadposting but i don't come here often), this fixed it. didn't have to turn off RCS. 3 Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 27, 2024 Share Posted February 27, 2024 PS note that there is an official version 21.0 now. see https://community.fxtec.com/topic/4050-lineageos-210-official-release-for-pro1-qx1000/ Quote Link to post Share on other sites
