Hook 3,318 Posted August 12, 2024 Share Posted August 12, 2024 Lineage-21-20240812-NIGHTLY-pro1x with Aug 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. I noticed, btw, that Lineage now points to a Github page for MTG 14 which updates more often than the old Codefire site did. This may not be new, but I hadn't noticed it before. https://github.com/MindTheGapps/14.0.0-arm64/releases I didn't flash a newer MTG 14. Assuming I understand things correctly(not necessarily a safe bet), if you have Gapps, they and the Play services are always being updated by Google, so it should be mostly pointless to update. But if you are doing a new install or factory reset, good to start with the latest. 2 1 Quote Link to post Share on other sites
Hook 3,318 Posted August 19, 2024 Share Posted August 19, 2024 Lineage-21-20240819-NIGHTLY-pro1x with Aug 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 1 Quote Link to post Share on other sites
zegoo 13 Posted August 19, 2024 Share Posted August 19, 2024 58 minutes ago, Hook said: Lineage-21-20240819-NIGHTLY-pro1x with Aug 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. I did the same update via OTA and root was NOT maintained. Weird ! Quote Link to post Share on other sites
Hook 3,318 Posted August 19, 2024 Share Posted August 19, 2024 1 hour ago, zegoo said: I did the same update via OTA and root was NOT maintained. Weird ! I just downloaded cpu-z and it verified that I was rooted still. It may have to do with my method of rooting? I root with Magisk, but I only use it for SU, so I use the depreciated method of flashing it as a zip when I first install LOS. Quote Link to post Share on other sites
zegoo 13 Posted August 19, 2024 Share Posted August 19, 2024 Weird. I'm also using Magisk to flash. But i'm flashing the magisk patched file by using fastboot. Quote Link to post Share on other sites
Hook 3,318 Posted August 19, 2024 Share Posted August 19, 2024 9 minutes ago, zegoo said: Weird. I'm also using Magisk to flash. But i'm flashing the magisk patched file by using fastboot. I don't patch the any file myself. After the first flash, I open the Magisk app once and let it update and/or install (I forget which, but whatever makes the app happy) and then close it and never open it again. 1 Quote Link to post Share on other sites
Hook 3,318 Posted August 26, 2024 Share Posted August 26, 2024 Lineage-21-20240826-NIGHTLY-pro1x with Aug 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. One oddity. I don't have any kind of screen lock on the device. Before this update, aside from swiping with my finger, I could press the space bar to dismiss the lock screen. That no longer works. There isn't a setting, so something internal changed. It's annoying since pressing the space bar is easy and really ingrained. I'm also getting yellow triangles about not being secure, so maybe that's connected. FU Google, It's my decision how secure or not annoyed when my phone times out I want to be. There is no sensitive data on this phone and I've never lost or had a phone stolen (nor any of my PDAs). Offer me options, yes, but shut the F up if I choose not to use them. </rant> :D 4 Quote Link to post Share on other sites
Hook 3,318 Posted September 3, 2024 Share Posted September 3, 2024 Lineage-21-20240902-NIGHTLY-pro1x with Aug 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. Notice, Monday's date as expected, but didn't actually show up until today, Tuesday. And, woo hoo, I can dismiss the lock screen with the space bar again! :D I'm probably the only one here who cared about that ;-) 2 Quote Link to post Share on other sites
Hook 3,318 Posted September 4, 2024 Share Posted September 4, 2024 A bit of a tangent, but in what universe is August 26th 2 weeks before September 3rd? :D 3 Quote Link to post Share on other sites
Hook 3,318 Posted September 9, 2024 Share Posted September 9, 2024 Lineage-21-20240909-NIGHTLY-pro1x with September 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 1 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted September 14, 2024 Share Posted September 14, 2024 (edited) I've forgotten how the state of LineageOS is on the Pro1 X in that regard, I never tried it, but if I might actually get the device that's still outstanding (I won't mess with the one I already have but doesn't work properly anyway at this point), I would be tempted – does it being "official" include the ability to make it pass SafetyNet attestation? (Also, does anyone know what Google's imminent transition from "SafetyNet attestation API" to "Play integrity API" might mean for us in this regard?) Edited September 14, 2024 by Rob. S. Quote Link to post Share on other sites
Hook 3,318 Posted September 14, 2024 Share Posted September 14, 2024 8 hours ago, Rob. S. said: I've forgotten how the state of LineageOS is on the Pro1 X in that regard, I never tried it, but if I might actually get the device that's still outstanding (I won't mess with the one I already have but doesn't work properly anyway at this point), I would be tempted – does it being "official" include the ability to make it pass SafetyNet attestation? (Also, does anyone know what Google's imminent transition from "SafetyNet attestation API" to "Play integrity API" might mean for us in this regard?) I can't answer either of your questions, but you might want to make the second question a new thread. It has been discussed some on Discord and form my brief skim, it looks like the new API is something developers can use for individual apps. Not clear why they would or what pressure Google might apply to have them do it, but it doesn't yet seem to be "you can't sideload anything" and I suspect, using mostly older apps, it won't present a big problem to me, but I really don't know. It's a good question, if anyone here knows. 1 Quote Link to post Share on other sites
Hook 3,318 Posted September 16, 2024 Share Posted September 16, 2024 Lineage-21-20240916-NIGHTLY-pro1x with September 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,318 Posted September 23, 2024 Share Posted September 23, 2024 Lineage-21-20240923-NIGHTLY-pro1x with September 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,318 Posted September 30, 2024 Share Posted September 30, 2024 Lineage-21-20240930-NIGHTLY-pro1x with September 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 2 1 Quote Link to post Share on other sites
Hook 3,318 Posted October 7, 2024 Share Posted October 7, 2024 Lineage-21-20241007-NIGHTLY-pro1x with September 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 3 Quote Link to post Share on other sites
Hook 3,318 Posted October 14, 2024 Share Posted October 14, 2024 Lineage-21-20241014-NIGHTLY-pro1x with October 1st security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 2 Quote Link to post Share on other sites
Hook 3,318 Posted October 21, 2024 Share Posted October 21, 2024 Lineage-21-20241021-NIGHTLY-pro1x with October 1st security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 2 1 Quote Link to post Share on other sites
Hook 3,318 Posted October 25, 2024 Share Posted October 25, 2024 Thanks to a heads up from @TeZtdevice, some evidence that Android 15 might be coming (not necessarily soon, but being worked on, as long as they don't hit any show stoppers). https://review.lineageos.org/q/project:LineageOS/android_device_fxtec_pro1x+branch:lineage-22.0 1 2 Quote Link to post Share on other sites
Hook 3,318 Posted October 28, 2024 Share Posted October 28, 2024 Lineage-21-20241028-NIGHTLY-pro1x with October 1st security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 2 1 Quote Link to post Share on other sites
Hook 3,318 Posted November 4, 2024 Share Posted November 4, 2024 Lineage-21-20241104-NIGHTLY-pro1x with October 1st security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 1 1 Quote Link to post Share on other sites
Hook 3,318 Posted November 12, 2024 Share Posted November 12, 2024 Lineage-21-20241111-NIGHTLY-pro1x with November 1st security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 2 1 Quote Link to post Share on other sites
Hook 3,318 Posted November 18, 2024 Share Posted November 18, 2024 Lineage-21-20241118-NIGHTLY-pro1x with November 1st security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. 2 1 Quote Link to post Share on other sites
Hook 3,318 Posted November 26, 2024 Share Posted November 26, 2024 Lineage-21-20241125-NIGHTLY-pro1x with November 1st security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. Despite the date, if it showed up on Monday, it wasn't until I went to bed, but it was there this morning. Last weeks was similar, but it did show up before I went to bed. NBD, but just odd to release it so late in the day. 3 Quote Link to post Share on other sites
Hook 3,318 Posted December 3, 2024 Share Posted December 3, 2024 Lineage-21-20241202-NIGHTLY-pro1x with November 1st security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. On time this time, just me who was late getting here. :D 2 Quote Link to post Share on other sites
