Pro1-X jim 1 Posted October 14, 2024 Share Posted October 14, 2024 (edited) On 10/12/2024 at 10:30 AM, EskeRahn said: ...And just for being clear, this has to be done while it is constantly being connected to some power supply. Thank you I haven't taken it off charge the entire 60+ hours it has been plugged in. I've merely added the rubber band, super tight, removed it, let it sit and attempt to boot, and rinse and repeat. Been at this since 11am Friday morning and it's now 1800 Sunday Australian time.ADD by moderator: I split this out from the original thread on the rubber band trick for charging here. Edited October 19, 2024 by EskeRahn (Moderator split thread) Quote Link to post Share on other sites
Pro1-X jim 1 Posted October 14, 2024 Author Share Posted October 14, 2024 Quote Link to post Share on other sites
Pro1-X jim 1 Posted October 14, 2024 Author Share Posted October 14, 2024 Just now, Pro1-X jim said: I tried doing mpg to show the cycle loop, just vibrate with the red light every cple of seconds. Clip was too large to post. Quote Link to post Share on other sites
Pro1-X jim 1 Posted October 14, 2024 Author Share Posted October 14, 2024 Just now, Pro1-X jim said: I tried doing mpg to show the cycle loop, just vibrate with the red light every cple of seconds. Clip was too large to post. Also - I check the power button was super tight, squeezed in by the rubber bands. There is literally no give. Quote Link to post Share on other sites
jakfish 155 Posted October 14, 2024 Share Posted October 14, 2024 I'm reaching for straws here, but perhaps change chargers? Forum veterans could provide named charger alternatives. I use the slow charge of a computer's USB port (or the stock charger for rare fast charging), but a USB port may not provide sufficient juice. Jake Quote Link to post Share on other sites
Hook 3,364 Posted October 14, 2024 Share Posted October 14, 2024 I suspect that actually your Pro1x has been revived by the rubber band method but your problem is with the display. There is one easy thing you can check. The back of the display can be easily opened (5 screws, no glue) and you can check the ribbon cable to see if it is properly connected and seated. Unfortunately, if that's not it, it is probably a defective display. I wasn't sure whether you said FxTec didn't answer your email or replied saying they couldn't help you (meanng they have no display replacements they could send you). If the former, you may have to wait a bit. They are slow at responding, but sadly, I suspect the latter. I had a screen on my Pro1 that went dark and didn't display anything. That was back in 2021 and FxTec was able to replace it, so I know what you are experiencing can happen and I think it is likely the problem you have. If your previous email presented the problem as with the rubber Band trick, send a new email saying it actually seems to be that the display doesn't work. Maybe they can do something, Don't know, but worth a try, You can get a replacement display here: https://www.aliexpress.us/item/3256804876586192.html?gatewayAdapt=glo2usa4itemAdapt Sadly they are out of the version that comes with the frame. It would involve removing the old display from the frame on the Pro1x (it is lightly glues) and replacing it with the new one. However, there is a problem that doesn't have a solution right now-- the display need a patch or it leaves a wide border on the screen that doesn't respond to touch. The patch doesn't run on anything greater than Android 10 and so, unlike the older Pro1, which runs on stock Android 9 and includes the patch in the OS, there is no way anyone has figured out to get the Alie Express screens patched other than attaching them to a Pro 1 and then moving them to the Pro1x. Sorry, all bad news. And I'm sorry this is happening (as an individual, I don't have any connection to Fxtec). The Pro1x, while not always the best with signals, depending on your location and carrier), it is a fantastic pocket computer. It is sad that after such a long wait, yours doesn't work. That's terribly frustrating. The Fxtec folks only poke in here rarely, but I'll try a call-out to @Casey, just in case. He may indeed have bad news as well about the availability of displays, but I think if you frame it in the email as a problem with the display, they might be able to do something where there isn't much they can do about the rubber band not working. But from your description of sounds and vibrations, I truly believe the rubber band worked. Good Luck 2 2 Quote Link to post Share on other sites
Pro1-X jim 1 Posted October 15, 2024 Author Share Posted October 15, 2024 23 hours ago, Pro1-X jim said: Thanks for the reply. 48 hours with the rubber band. Super super tight - no tissue to protect the screen, couldn't budge the band by hand! There has been a black screen the entire time No visuals nothing. There is a green light which changes to red indicator light, nothing else. The backlight on the keypad comes on when the phone is opened. I can also hear sounds as though something is happening, in terms of when trying to boot on. When the rubber band was on - there seemed to be a constant cycling loop, from the sounds emanating. The first rubber band attempt was about 26 hours, I then removed the rubber band and let it remain on charge, and tried multiple times to boot it through pressing the power button - nothing. Then I repeated the rubber band process another 26+ hours. No change. Each time I attempt the power button - to load or shutdown - no idea because no visuals - I rely on the vibration kicking in. 15 hours ago, Hook said: I suspect that actually your Pro1x has been revived by the rubber band method but your problem is with the display. There is one easy thing you can check. The back of the display can be easily opened (5 screws, no glue) and you can check the ribbon cable to see if it is properly connected and seated. Unfortunately, if that's not it, it is probably a defective display. I wasn't sure whether you said FxTec didn't answer your email or replied saying they couldn't help you (meanng they have no display replacements they could send you). If the former, you may have to wait a bit. They are slow at responding, but sadly, I suspect the latter. I had a screen on my Pro1 that went dark and didn't display anything. That was back in 2021 and FxTec was able to replace it, so I know what you are experiencing can happen and I think it is likely the problem you have. If your previous email presented the problem as with the rubber Band trick, send a new email saying it actually seems to be that the display doesn't work. Maybe they can do something, Don't know, but worth a try, You can get a replacement display here: https://www.aliexpress.us/item/3256804876586192.html?gatewayAdapt=glo2usa4itemAdapt Sadly they are out of the version that comes with the frame. It would involve removing the old display from the frame on the Pro1x (it is lightly glues) and replacing it with the new one. However, there is a problem that doesn't have a solution right now-- the display need a patch or it leaves a wide border on the screen that doesn't respond to touch. The patch doesn't run on anything greater than Android 10 and so, unlike the older Pro1, which runs on stock Android 9 and includes the patch in the OS, there is no way anyone has figured out to get the Alie Express screens patched other than attaching them to a Pro 1 and then moving them to the Pro1x. Sorry, all bad news. And I'm sorry this is happening (as an individual, I don't have any connection to Fxtec). The Pro1x, while not always the best with signals, depending on your location and carrier), it is a fantastic pocket computer. It is sad that after such a long wait, yours doesn't work. That's terribly frustrating. The Fxtec folks only poke in here rarely, but I'll try a call-out to @Casey, just in case. He may indeed have bad news as well about the availability of displays, but I think if you frame it in the email as a problem with the display, they might be able to do something where there isn't much they can do about the rubber band not working. But from your description of sounds and vibrations, I truly believe the rubber band worked. Good Luck Hey mate, Thanks heaps for the reply and the suggestions. Firstly - I don't have any tools that small to remove the screen to check the display connection, so I'll need to track something down. Considering I was a backer for the Pro1-X, and 2+ years later have only just received the mobile, within the last cple of weeks, am a little concerned about removing a display which has a hinge connecting it to the main body. I will give it a go though, and check. Also appreciate the link for Ali-express, however am not paying anything extra for a brand new mobile. Respectfully, if they wanted me to test out the phone, they could have given me a free one, not have to pay $1200+ (Aussie conversion rate) for an absolute lemon on arrival. I was expecting to load an OS, not use a rubber band on a brand new phone to boot it, and start dissembling the hardware. Yes, support have been ignoring my requests to find solutions to fix this expensive door stop, so please accept I am hugely grateful for your efforts. I agree, with the vibrations and sounds, it seems to elude to a display issue. Will see what transpires when I attempt to remove the display screws. Once again, thank you for your assistance. Hugely grateful. Will get back to you if OK? 1 Quote Link to post Share on other sites
claude0001 1,424 Posted October 15, 2024 Share Posted October 15, 2024 3 hours ago, Pro1-X jim said: I don't have any tools that small to remove the screen to check the display connection, so I'll need to track something down. While buying a miniature Phillips screw driver, make sure to also get some prying tool. Besides the screws, the display frame "clicks" onto the supporting base plate. Especially if it has never been removed before, fingernails are not enough to get it loose. You wont have to mess with the hinge mechanism by the way. However, be careful with the ribbon cable connecting the two halves of the phone: it is just long enough to allow you to reach the connector head. 3 hours ago, Pro1-X jim said: I agree, with the vibrations and sounds, it seems to elude to a display issue. Once the display frame is unmounted (which is quite easy) you can check and re-seat the ribbon cables coming from the bottom half of the phone to the frame, as well as the connector from the frame to the actual screen. This did fix a dead display for me twice (after dropping the phones). Dig deeper (into the bottom half of the phone) only if it doesn't. 3 hours ago, Pro1-X jim said: [...] however am not paying anything extra [...]. if they wanted me to test out the phone [...] absolute lemon on arrival [...] support have been ignoring [...] expensive door stop [...] hugely grateful for your efforts. Much appreciated how you manage to lead a nice and polite discussion despite your understandable frustration. Not joking. Too many tend to forget that on this forum you are 1) mostly just talking to other users, not F(x)tec, and that 2) many of us have been through very similar troubles. Keep going! 👍 1 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 15, 2024 Share Posted October 15, 2024 On 10/14/2024 at 8:51 AM, Pro1-X jim said: I tried doing mpg to show the cycle loop, just vibrate with the red light every cple of seconds. Just to add that this is something of a good sign, as this is how it behaves if I do it on a working Pro1X. But as it does not display a splash screen also in the loop, I agree with others that it is most likely a display issue. 1 Quote Link to post Share on other sites
Pro1-X jim 1 Posted October 18, 2024 Author Share Posted October 18, 2024 On 10/16/2024 at 3:26 AM, EskeRahn said: Just to add that this is something of a good sign, as this is how it behaves if I do it on a working Pro1X. But as it does not display a splash screen also in the loop, I agree with others that it is most likely a display issue. Thanks for your input, this helps with the frustration. I can only base my level of sanity on the experience of others, as they've tread the path before me. Quote Link to post Share on other sites
Pro1-X jim 1 Posted October 18, 2024 Author Share Posted October 18, 2024 On 10/15/2024 at 8:49 PM, claude0001 said: While buying a miniature Phillips screw driver, make sure to also get some prying tool. Besides the screws, the display frame "clicks" onto the supporting base plate. Especially if it has never been removed before, fingernails are not enough to get it loose. You wont have to mess with the hinge mechanism by the way. However, be careful with the ribbon cable connecting the two halves of the phone: it is just long enough to allow you to reach the connector head. Once the display frame is unmounted (which is quite easy) you can check and re-seat the ribbon cables coming from the bottom half of the phone to the frame, as well as the connector from the frame to the actual screen. This did fix a dead display for me twice (after dropping the phones). Dig deeper (into the bottom half of the phone) only if it doesn't. Much appreciated how you manage to lead a nice and polite discussion despite your understandable frustration. Not joking. Too many tend to forget that on this forum you are 1) mostly just talking to other users, not F(x)tec, and that 2) many of us have been through very similar troubles. Keep going! 👍 Quote Link to post Share on other sites
Pro1-X jim 1 Posted October 18, 2024 Author Share Posted October 18, 2024 Thanks heaps for the walk through. Not sure which screws or which mobile you're referring to :-) as the screws are beyond the smallest I've ever seen - no fingernail would have a chance. Anyway, I removed the screws, and backed out because even with (maybe too fragile effort) my effort, I couldn't budge the plate. There was no give in the plate to assure me, so I returned the screws and may be better off taking the mobile to a repair shop. Am just not confident to remove the plate without breaking the phone - I tend to break stuff - lessons learned the financially painful way - so am somewhat shy on new overpriced junk. An old phone - wouldn't care, as have done many times before. To think that if I manage to get past these hurdles - I am still left with loading the OS which may throw other surprises like hardware/software conflicts - dodgey camera etc. Once again. thanks for your effort to reply and suggest options - every small step forward is a plus. Quote Link to post Share on other sites
claude0001 1,424 Posted October 18, 2024 Share Posted October 18, 2024 23 minutes ago, Pro1-X jim said: Not sure which screws or which mobile you're referring to 🙂 as the screws are beyond the smallest I've ever seen - no fingernail would have a chance. I was saying that even after you remove the screws, the screen will still cling to the base plate. Detaching it requires some prying tool to insert between the screen frame and the base plate. 1 1 Quote Link to post Share on other sites
Pro1-X jim 1 Posted October 18, 2024 Author Share Posted October 18, 2024 Roger that!! Maybe I will have a go at the prying bit. And def no glue? Either way, appreciate your effort to reply and guide. support@fx has closed their email - tried from multiple email accounts. Super pisd that I need to rely on someone like yourself that has no connection for suggestions and advice - talk about a scam business. Thanks again, will try your suggs - most grateful! Quote Link to post Share on other sites
claude0001 1,424 Posted October 19, 2024 Share Posted October 19, 2024 No glue between the screen frame and the baseplate. There is some holding the actual screen to the frame, but you won't have to touch that to test the connectors. Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 19, 2024 Share Posted October 19, 2024 I Split this into a separate thread, as it was moving too far from the original thread on the rubber band trick for charging. 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 19, 2024 Share Posted October 19, 2024 Here a couple of disassembly guides, taken from the Start here FAQ. Disassembly guides, see this @netman and official videos here and on Vimeo here 1 Quote Link to post Share on other sites
