EskeRahn 5,598 Posted February 10, 2025 Share Posted February 10, 2025 4 hours ago, claude0001 said: Anyway, it seems I can find no open bug reported against LOS about this. So, whatever your issue is, I doubt it will ever be resolved "automatically" by an OTA. Indeed, it was broken long ago, then fixed and later broken again, but you are right the chances of a fix seems slim. Quote Link to post Share on other sites
claude0001 1,424 Posted February 11, 2025 Share Posted February 11, 2025 On 2/10/2025 at 4:15 PM, EskeRahn said: Indeed, it was broken long ago, then fixed and later broken again, but you are right the chances of a fix seems slim. OK. I just think: this sounds like a general regression in AOSP, as keyboard support in Android is generally nothing specific to the Pro1 (hence my question whether this is also observed in the Pro1-X port). I just wonder if it could be worthwhile to open a bug against LineageOS because of this. Quote Link to post Share on other sites
Hook 3,315 Posted February 11, 2025 Share Posted February 11, 2025 40 minutes ago, claude0001 said: OK. I just think: this sounds like a general regression in AOSP, as keyboard support in Android is generally nothing specific to the Pro1 (hence my question whether this is also observed in the Pro1-X port). I just wonder if it could be worthwhile to open a bug against LineageOS because of this. I just tested on my Pro1x with LOS. I think it works there. That is (just to confirm I know what is being talked about). I added Dansk (Denmark) to my list of system languages (the main one is US English). When I go to type in an editor, I am typing in English. and then I hold the yellow arrow and press spacebar and I get a notification that I am now typing in Dansk and I can get that weird ae mashup ;-). I can use the yellow arrow spacebar as a toggle between the two. Doesn't work on my Pro1. yellow arrow + spacebar pulls up search. Don't know why. My Pro1 is currently Google Free, though I may be changing that. 2 Quote Link to post Share on other sites
claude0001 1,424 Posted February 12, 2025 Share Posted February 12, 2025 Thanks for the feedback. With my Pro1 still on LineageOS 16.0, this works. I can select multiple layouts under "Keyboard & input methods > Physical keyboard" and then cycle through them on the fly. Pretty cool, actually. I didn't know about this feature. However, on the Pro1 with LOS16, the hotkey for layout switching is Ctrl + Spacebar. Yellow arrow + Spacebar is equivalent to pressing the power button in my case, which is another pretty cool feature introduced by @tdm with his initial port of LOS. Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 12, 2025 Share Posted February 12, 2025 I'm not sure about the timing of when it last worked but think it was under some of the LOS 20 releases. As I remember it, it has been broken for all 22 and 21. I reported it long back, and it was fixed later, working for a not so long period only to break again, and I gave up a bit.... I guess it is a design issue. Some people love to mess up functioning designs (MS are masters in this mess-up-art....). Back in Android 9 it was check-boxes, and though very practical, it does not look good, and for the majority that only can handle one language, the selecting of the active by a simple touch is nice and looks cleaner. So now it works like radiobuttions, but design-obscured by the use of a check-mark (that for decades in windows has signalled that we can select multiple) Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 13, 2025 Share Posted February 13, 2025 On 2/12/2025 at 3:16 PM, EskeRahn said: I reported it long back, and it was fixed later, working for a not so long period only to break again, and I gave up a bit.... I reported it fixed herehttps://community.fxtec.com/topic/3557-lineageos-191-official-release-for-pro1/?tab=comments#comment-61182 Quote Link to post Share on other sites
TeZtdevice 368 Posted February 15, 2025 Author Share Posted February 15, 2025 Lineage-22.1-20250215-nightly-pro1-signed.zip on February 5 (2025) security patch, installed smoothly using OTA 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 15, 2025 Share Posted February 15, 2025 (lineage-22.1-20250215-nightly-pro1-signed.zip on february 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 22, 2025 Share Posted February 22, 2025 (lineage-22.1-20250222-nightly-pro1-signed.zip on february 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted February 23, 2025 Author Share Posted February 23, 2025 Lineage-22.1-20250222-nightly-pro1-signed.zip on February 5 (2025) security patch, installed smoothly using OTA 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 2, 2025 Share Posted March 2, 2025 (lineage-22.1-20250301-nightly-pro1-signed.zip on february 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
elvissteinjr 362 Posted March 3, 2025 Share Posted March 3, 2025 Late to the party, but being lazy (and traumatized from the camera breaking before) I take a more relaxed approach to installing updates. Can at least confirm dirty flashing worked fine. From a slightly older LineageOS 21 build (November or October I think it was). Everything seems to be in order, GApps + Magisk too. On 1/4/2025 at 5:59 PM, TeZtdevice said: Magisk work after patching the boot.img of LineageOS 22.1 and re-flashing it with adb sideload Had to use fastboot to flash the patched boot image myself. This tripped me up for a few minutes, after not having done it in a while. Are you sure you used adb sideload there? 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 3, 2025 Share Posted March 3, 2025 44 minutes ago, elvissteinjr said: Are you sure you used adb sideload there? Well though I do use fastboot flash boot xxxxxx to flash the boot image it is followed by (re)flashing the main image with adb sideload yyyyyyy (and also for flashing the gapps) Quote Link to post Share on other sites
TeZtdevice 368 Posted March 8, 2025 Author Share Posted March 8, 2025 Lineage-22.1-20250308-nightly-pro1-signed.zip on February 5 (2025) security patch, installed smoothly using OTA 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 8, 2025 Share Posted March 8, 2025 (lineage-22.1-20250308-nightly-pro1-signed.zip on February 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted March 16, 2025 Author Share Posted March 16, 2025 Lineage-22.1-20250315-nightly-pro1-signed.zip on February 5 (2025) security patch, installed smoothly using OTA 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted March 16, 2025 Author Share Posted March 16, 2025 Info: next week, LineageOS 22.2 will be released. 1 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 16, 2025 Share Posted March 16, 2025 (lineage-22.1-20250315-nightly-pro1-signed.zip on February 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted March 22, 2025 Author Share Posted March 22, 2025 Lineage-22.1-20250322-nightly-pro1-signed.zip on March 1 (2025) security patch, installed smoothly using OTA (til now not updated to 22.2) 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 23, 2025 Share Posted March 23, 2025 (lineage-22.1-20250322-nightly-pro1-signed.zip on March 1 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20240928_150548) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 29, 2025 Share Posted March 29, 2025 (lineage-22.1-20250329-nightly-pro1-signed.zip on March 1 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20250214_082511) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted March 29, 2025 Author Share Posted March 29, 2025 Lineage-22.1-20250329-nightly-pro1-signed.zip on March 1 (2025) security patch, installed smoothly using OTA (til now not updated to 22.2) 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted April 5, 2025 Share Posted April 5, 2025 (lineage-22.1-20250405-nightly-pro1-signed.zip on March 1 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20250214_082511) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted April 12, 2025 Author Share Posted April 12, 2025 (edited) Lineage-22.2-20250412-nightly-pro1-signed.zip on April 5 (2025) security patch, installed smoothly using OTA BUT I have a bootloop. I think it´s because one of my activated modules in Magisk.UPDATE-1: The problem is: Iconify v.7.2.0 Not the app itself, it is one of my settings, like different colors, different lock clock, etc. (Perhaps, because I import my last settings for LineageOS 22.1 ?!) UPDATE-2: I have touchschreen issues with activate app called "Round Screen Corners & Hide Notch" v.1.2.9. Not the whole screen, but most of them. But no issues when I swipe through the system menu. UPDATE-3: I fixed the issue with Iconify v.7.2.0 with a full reinstall of these app (incl. reboot, reactive the module). After the reboot I import my last backup and now it works! Edited April 12, 2025 by TeZtdevice 1 1 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted April 12, 2025 Share Posted April 12, 2025 (lineage-22.2-20250412-nightly-pro1-signed.zip on April 5 security patch installed smoothly using adb sideload and MindTheGapps-15.0.0-arm64-20250214_082511) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
