sevs 1 Posted November 23, 2019 Share Posted November 23, 2019 (edited) Hi, I'm wanting to buy a Pro1. Is there a hook for a wrist strap (wiimote type wrist strap, etc) somewhere on the phone? Edited November 23, 2019 by sevs 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 23, 2019 Share Posted November 23, 2019 No strap-holes,, sorry. I suggest to go for a case that got it, if it is a 'must' Quote Link to post Share on other sites
Parhelion 114 Posted November 23, 2019 Share Posted November 23, 2019 Upon seeing the topic title, before reading the request, I just imagined a bracelet connected to a case, using the Pro1 as a HUGE smartwatch. Another gadget to find. Kinda like the cyborg-style idea.. 🙂 2 Quote Link to post Share on other sites
Craig 1,435 Posted November 24, 2019 Share Posted November 24, 2019 it could be like mounted to left forearm. have to learn to type one handed, but might work.... something like 1 2 Quote Link to post Share on other sites
Craig 1,435 Posted November 24, 2019 Share Posted November 24, 2019 (edited) maybe it could even include one of those chargers that works by motion. if your battery gets below 10% and no handy charger, do jumping jacks. Could help with physical fitness too. Edited November 24, 2019 by Craig spelling 4 Quote Link to post Share on other sites
FlyingAntero 871 Posted November 24, 2019 Share Posted November 24, 2019 Maybe you could try Pluggy Lock? Never tried by myself but it looks like a decent solution. https://www.pluggylock.com/ Quote Link to post Share on other sites
Parhelion 114 Posted November 24, 2019 Share Posted November 24, 2019 3 hours ago, FlyingAntero said: Maybe you could try Pluggy Lock Honestly I'd be afraid of that thing damaging the (rather delicate) headphone jack, spreading/chocking itself in, and the force of whatever attached (plus initial tension) taken partly by the SoC. 3.5mm-jacks tend to lose contact over lifetime just by plugging in and out. 3 Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 24, 2019 Share Posted November 24, 2019 31 minutes ago, Parhelion said: Honestly I'd be afraid of that thing damaging the (rather delicate) headphone jack, spreading/chocking itself in, and the force of whatever attached (plus initial tension) taken partly by the SoC. 3.5mm-jacks tend to lose contact over lifetime just by plugging in and out. Indeed, And If you accidentally rotate the strap you might unwind it unless it is tightened very hard. So not a solution I would dare depend on As the supports arms are made of metal, I would rather put a thin wire around that... (You see a silicon 'soft' shell for a Huawei P20 Pro on the "Final Sample") Quote Link to post Share on other sites
FlyingAntero 871 Posted November 24, 2019 Share Posted November 24, 2019 35 minutes ago, Parhelion said: Honestly I'd be afraid of that thing damaging the (rather delicate) headphone jack, spreading/chocking itself in, and the force of whatever attached (plus initial tension) taken partly by the SoC. 3.5mm-jacks tend to lose contact over lifetime just by plugging in and out. At least the company says that Pluggy Lock does not damage the 3.5mm plugin. But of course it can become little bit loose after use just like with headphones. It is just an option. https://pluggylock.eu/pages/faq/ Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 24, 2019 Share Posted November 24, 2019 ....Took a strap from a camera and tested: Would be better with a longer thin string part, so the 'knot' could be outside, as the four times the string thickness at the 'knot' prevents a complete close 2 Quote Link to post Share on other sites
OliverTypes 152 Posted November 24, 2019 Share Posted November 24, 2019 I would rather not dangle it from any mechanical part on a regular basis. As a pure safety line, this would of course be preferable to a drop. A strap hole integrated into the body would be a much appreciated improvement for any future releases in my book. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 25, 2019 Share Posted November 25, 2019 9 hours ago, OliverTypes said: I would rather not dangle it from any mechanical part on a regular basis. As a pure safety line, this would of course be preferable to a drop. A strap hole integrated into the body would be a much appreciated improvement for any future releases in my book. Yeah, It could be a good idea, for those that wants that. Quote Link to post Share on other sites
Krzysieq 55 Posted November 25, 2019 Share Posted November 25, 2019 Imagine this with Pro1 instead of screen :) 1 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 25, 2019 Share Posted November 25, 2019 13 hours ago, OliverTypes said: I would rather not dangle it from any mechanical part on a regular basis. As a pure safety line, this would of course be preferable to a drop. A strap hole integrated into the body would be a much appreciated improvement for any future releases in my book. ...On second thoughts, it might not be that easy to have it working well, as it swinging might open the device... Better go for a flip case that has the strap. Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 25, 2019 Share Posted November 25, 2019 4 hours ago, Krzysieq said: Imagine this with Pro1 instead of screen 🙂 3 2 Quote Link to post Share on other sites
kashif 350 Posted November 25, 2019 Share Posted November 25, 2019 On 11/24/2019 at 8:28 PM, EskeRahn said: ....Took a strap from a camera and tested: Would be better with a longer thin string part, so the 'knot' could be outside, as the four times the string thickness at the 'knot' prevents a complete close You gonna break the poor hinge! Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 25, 2019 Share Posted November 25, 2019 8 minutes ago, kashif said: You gonna break the poor hinge! It is some sort of steel so the string will almost certainly go first... But still not a good idea with a strap at all, as posted earlier Quote Link to post Share on other sites
Krzysieq 55 Posted November 25, 2019 Share Posted November 25, 2019 23 minutes ago, EskeRahn said: Is it possible to type single-handedly in this setup? :) rubber straps might not be the most solid replica of a pip-boy, but hey - if it ain't broken, don't fix it! Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 25, 2019 Share Posted November 25, 2019 2 minutes ago, Krzysieq said: Is it possible to type single-handedly in this setup? 🙂 rubber straps might not be the most solid replica of a pip-boy, but hey - if it ain't broken, don't fix it! Well did not try to use it, just made the image for fun. but sure it would be possible. But I think it would be better to use re-usable strips (strips that can be opened), so you can get it as firm as possible without stopping the blood circulation too much. And then thread them through some stiff piece of plastic, to secure the distance, so they can not slip over the ends. 1 Quote Link to post Share on other sites
kashif 350 Posted November 25, 2019 Share Posted November 25, 2019 42 minutes ago, EskeRahn said: Well did not try to use it, just made the image for fun. but sure it would be possible. But I think it would be better to use re-usable strips (strips that can be opened), so you can get it as firm as possible without stopping the blood circulation too much. And then thread them through some stiff piece of plastic, to secure the distance, so they can not slip over the ends. @EskeRahn you are hurting the poor thing! Give it to me, ill take better care of it 😛 3 Quote Link to post Share on other sites
OliverTypes 152 Posted November 27, 2019 Share Posted November 27, 2019 On 11/25/2019 at 2:15 PM, EskeRahn said: ...On second thoughts, it might not be that easy to have it working well, as it swinging might open the device... Better go for a flip case that has the strap. The Nokia E7 had one too, should not be much of a problem. It's not for "swinging" anyway but for breaking a fall 😅 Quote Link to post Share on other sites
_DW_ 628 Posted November 27, 2019 Share Posted November 27, 2019 21 minutes ago, OliverTypes said: The Nokia E7 had one too, should not be much of a problem. It's not for "swinging" anyway but for breaking a fall 😅 of course there for swinging 😂 2 Quote Link to post Share on other sites
netman 1,424 Posted November 27, 2019 Share Posted November 27, 2019 24 minutes ago, OliverTypes said: The Nokia E7 had one too, should not be much of a problem. It's not for "swinging" anyway but for breaking a fall 😅 3 2 Quote Link to post Share on other sites
OliverTypes 152 Posted November 27, 2019 Share Posted November 27, 2019 Only one way to be safe. 4 Quote Link to post Share on other sites
ksal95 227 Posted November 27, 2019 Share Posted November 27, 2019 5 minutes ago, OliverTypes said: Only one way to be safe. Truly the safest way of handling your click clack! 1 Quote Link to post Share on other sites
